Cant get hood open - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Cheap Tricks & Fixes > Cant get hood open
FS: 2007-2013 Jeep Wrangler "HALO" Angel Eye KitTHE NEW! VANCO DUAL MODE 15/16″ Big Brake Kit w/BlaFS: Wranger BRIGHT License Plate LED! Just $3! Great value
Unread 06-12-2014, 12:06 AM   #1
cherokeesport94
Cant get hood open
Can't get my hood to open on my 94 xj any ideas how to get it open?
cherokeesport94 is offline   Reply With Quote
Unread 06-12-2014, 05:52 PM   #2
daven75
Theres a trick, if you take the headlights out, theres two screws that hold the part that holds the hood down on, and you can remove them which should release the hood and you can then open it like you normally would once you pop it.
daven75 is offline   Reply With Quote
Unread 06-12-2014, 09:11 PM   #3
cherokeesport94
yeah that what I think I'm going to do
Unread 06-24-2014, 03:55 AM   #4
jeepster425
Or if you have skinny arms, reach your hand up between the motor and radiator, and unlatch it right there in the middle. Happened to me when the cable came unlatched up underneath the hood.
Sent from my iPad while creepin....
D30 front/ D44 rear
__=====,o00o,
//__l_l_,\____\,_____
l_/-\_l__l_/-\_|
lllllll|
{o}_} {o}_}--o-}_}
jeepster425 is offline   Reply With Quote
Unread 06-26-2014, 11:38 AM   #5
jeep50
To you hear the 'Klick' when you are trying to open?
Try to ask someone to pull the hood while you are trying to open
jeep50 is offline   Reply With Quote
Unread 06-27-2014, 08:03 PM   #6
MyKeyB
Pound on the hood right above the catch while someone else pulls the release back and forth. 9 times out of 10 this will work.
Rust never sleeps...
MyKeyB is offline   Reply With Quote
Unread 06-28-2014, 10:58 PM   #7
cherokeesport94
got it open I grabbed the cable and pulled and it popped open. The plastic cable holders aren't holding cable
Unread 07-05-2014, 08:01 PM   #8
watkinstj
A little lube on those latches goes along way. Spray them each oil change with spray lube and you shouldn't have an issue
watkinstj is offline   Reply With Quote
