Bumper = Portable Air Tank - JeepForum.com
post #1 of 18 Old 08-25-2004, 08:21 PM Thread Starter
Orange Juice
This idea was given to me the other day by a friend. I haven't tried it, but don't see any reason that it will not work.
Son has 4" x 4" x 1/4" square tubing welded to front bumper. Friend said why not weld the ends up solid, add an air chuck, and then hook it up to a compressor before going wheeling. If it is pressurized up to about 120 psi, it should fill at least 1 tire on the trails. All you would need is an air hose to couple to it to transfer air to the tire.
Orange Juice is offline
post #2 of 18 Old 08-25-2004, 09:40 PM
balloo93
Little Red Menace
balloo93's Avatar
1993 XJ Cherokee
Here's one done on a XJ:
http://www.pirate4x4.com/tech/billav...rearbumper.htm
93 Sport
Beer is proof that God loves us and wants us to be happy............Ben Franklin
Specs in Profile.
balloo93 is offline
post #3 of 18 Old 09-20-2004, 02:01 PM
vballman
i had a friend that did that. works well.
vballman is offline
post #4 of 18 Old 09-20-2004, 02:35 PM
igofshn
Locked @ both ends
igofshn's Avatar
You would be lucky to fill even 1 tire. There isn't enough volume. I have a 2.5 gal tank with compressor and if the compressor is off the air in the tank is not enough to fill a tire.
2007, 4 door, powered by a minivan engine, locked and riding on 35's.
igofshn is offline
post #5 of 18 Old 09-20-2004, 03:10 PM
wyldejackyl
That would make for a hell of a rear-end collision! Imagine the look on the person's face after they rupture your pressurized bumper!
..::2007 JK Unlimited X::..
1500W inverter
Midland 1001LWX CB
55/100W H4 Hella headlamp conversion w/ dual relays
wyldejackyl is offline
post #6 of 18 Old 09-20-2004, 11:33 PM
Qman
i seriously doubt any collision with a car or truck would cause that thing to Rupture 1/4" steel is thinker than any stock Bumper i have seen on the road. i doubt there would be much if any damage to the Bumper.... probably worst damage would be done to the Frame......
anyone have a link to Roll cage air tank, thought about that a couple times.. thought i saw something about it somewhere once..i would think there would be 2-3 gallons in a stock roll bar and if you could link it to the Front Down tubes would give you anther 1-2 gallons maybe....
bumpers are a good idea if you have big enough ones but mine are small and the rear would be more difficult to seal with the D-rings and tire carrier and i would probably only get a gallon out of them....... suppose you could get crafty and hook the bumpers to the Cage via hose and fittings combined you could fill up a tire or 2 or hook it to a air compressor and have a ton of reserve any of you engineer types care to calculate how many gallons you could get out of a cage a bumper Combo my bet is 3-5 gallons of course bumper size would make a huge differance...
Qman is offline
post #7 of 18 Old 09-21-2004, 01:47 PM
JSBlu974X4
seems like too much work for me. id rather just keep my stock bumper and buy a powertank or outback air co2 tank.
2005 Unlimited Rubicon Hard N Soft Tops, Clayton Long Arm on RE Coils, Warn Bumper/Tire Carrier, Warn Winch N Bumper, Currie Steering, JKS Quicker Disconnects, JKS Front Trac Bar, Bilsteins, CO2 System..Yada Yada Yada
JSBlu974X4 is offline
post #8 of 18 Old 09-21-2004, 10:06 PM
DiegoYJ
Junior Member
Then why even have a tank?
DiegoYJ is offline
post #9 of 18 Old 09-21-2004, 10:38 PM
igofshn
Locked @ both ends
igofshn's Avatar
It provides a good blast for setting beads and you can also run air tools. The compressor fills the tank as it is being used.
igofshn is offline
post #10 of 18 Old 09-21-2004, 11:44 PM
DiegoYJ
Junior Member
OH IC!
I'm a CO2 guy so I wasn't too sure how well the OB compressors worked in conjunction w/ the tank.
DiegoYJ is offline
post #11 of 18 Old 09-22-2004, 12:57 PM
DestructoJr
The Thin Blue Line
DestructoJr's Avatar
Maybe not enough to fill a tire but at least a good flotation device in case of water landing????
Originally Posted by LandRover
3rd graders? Any self-respecting high school teacher could punt them like footballs. :laugh:
Originally Posted by Marneaus
10 because you're awesomely conservative and bash all the liberals. hoorah!
War is an ugly thing, but not the ugliest of things. The decayed and degraded state of moral and patriotic feeling which thinks that nothing is worth war is much worse. The person who has nothing for which he is willing to fight, nothing which is more important than his own personal safety, is a miserable creature and has no chance of being free unless made and kept so by the exertions of better men than himself.
--John Stewart Mill--
DestructoJr is offline
post #12 of 18 Old 09-23-2004, 09:01 PM
Hoxviii
Think about it like this. Say one tire holds 5 gallons of air at 30 PSI. If you have a 5 gallon tank at 30 PSI you can fill one tire. At 60 PSI, two tires. At 90PSI, three tires. See where I'm going? You don't necessarily need volume as much as you need pressure.
My front bumper is 4" 5/16 continuous weld. It's rated to 1200 PSI working pressure, i can fill it to the limits of any shop/home compressor out there without worrying at all. That's 200 PSI ish and it holds about 4 gallons. I can fill two 35/12.50's off the tank no problem, but i have OBA so i can fill as many as i want .
Justin
I don't do Jeeps, but i'm here to help.
Remember, anywhere a car can go a 4x can go, only slower and more deliberately. The ONLY advantage of a 4x is to be able to go where the car can't.
Hoxviii is offline
post #13 of 18 Old 09-24-2004, 05:16 AM
BIGJMCCONNELL
1977 CJ7
Not exactly. The pressure would equalize between the the tire and the tank. You would have 15 in the tire, 15 in the tank (if you had a tire with zero pressure) I will agree that you can make up for some volume with pressure as long as you can trust the tank.
--BIGJ
1977 CJ-7 with Ford 302 engine
2.5 inch springs Matkins Frame with 1.5 inch body lift and all Fiberglass body D30/M20 w/3.54 gears, Moser 1-piece and Rear Aussie Locker, Jeep T-18w/Dana 20 and 35" tires Dual Flowmaster Exhaust, 6 point roll cage, OBA and a bunch of other stuff.
BIGJMCCONNELL is offline
post #14 of 18 Old 09-24-2004, 10:08 AM
denverd0n
The problem is that filling a single 235/75x15 tire from dead empty to 30 psi takes almost 60 gallons of air at ambient pressure. That means that if your tank is at, say 120 psi, then you still need a 7.5 gallon tank to fill just one tire.
Of course, it doesn't take as much air to fill the tire from, say, 15 psi that you might air down to back up to 30 psi for driving home. Still, if you expect to air down and then fill back up 4 tires you will need a VERY large air tank to be able to do it without a compressor to make up the difference.
denverd0n is offline
post #15 of 18 Old 09-24-2004, 02:02 PM
Hoxviii
i realize the equalization between the tank and the tire, i was just simplifying the concept.
Justin
Hoxviii is offline
Looking for an 4x4 portable water tank pajero2800TDI General Jeep & Off-Road Equipment 2 12-17-2009 01:11 PM
air tank out of cylinder bumper?? willyb8 General Jeep & Off-Road Equipment 3 12-14-2007 08:54 PM
Rear JK Bumper / Air Tank Prot General Jeep & Off-Road Equipment 1 04-22-2007 08:55 AM
11 gallon portable tank 03Wrangler General Jeep & Off-Road Equipment 4 03-24-2007 06:25 PM
Bumper/Tank Kahu Fabrication Shop 4 07-19-2005 07:29 PM
