Broken Shock Mounts - JeepForum.com
post #1 of 5 Old 08-16-2013, 09:27 AM Thread Starter
droopydawg
2015 KL Cherokee
Broken Shock Mounts
99 Cherokee. 147k on it. Pretty sure the shocks on it are original. Everything seems to need PB Blaster rust dissolver and a little heat. Installing shocks are one of the easiest jobs to do on a car, but even the fronts turned out to be a PITA. They are done.
While trying to remove the old rear shocks, all 4 upper mounting bolts broke off, as well as one of the lowers. The uppers can be carefully drilled out, retapped to clean out the original threads and be just fine. Done this plenty on old motorcycles and VW bugs.
My concern is the lower. It broke off right at the threads, so the portion that the shock slides onto is still there.
Had the same thing happen on a '77 FJ40. I just used a "U" clamp and it was all good. Even a FJ mechanic that I ended up selling the FJ to said that it was fine.
I plan on doing it again, since the only JEEP solution is to replace the entire axle, since the lower mount is welded to it.
I could cut off the remaining length of the mount and drill out what is left, and install a big bolt and nut, but I am afraid I might make the problem worse and be royally you-know-what.
Is there a better Cheap Trick or Fix? This jeep is going on a 1800 mile road trip to Arizona this sunday.
Thank you.
Drew Mobley
Lake Forest, Ill-annoying (Chicago)
'99 Cherokee Classic 4.0, '05 Nissan Frontier SE 4x4, '12 VW Beetle (wife's car), A bunch of motorcycles
droopydawg is offline
post #2 of 5 Old 08-16-2013, 11:08 AM
CJ7-Tim
Real Jeeps have dents
CJ7-Tim's Avatar
Originally Posted by droopydawg View Post
.... cut off the remaining length of the mount and drill out what is left, and install a big bolt and nut
This will work, I have done it several times. I weld the bolt to the mount. Or, you can cut a shock mount off of another axle and weld it in the correct location. You can also purchase new shock mounts and weld them on.
CJ7-Tim is offline
post #3 of 5 Old 08-16-2013, 11:16 AM Thread Starter
droopydawg
2015 KL Cherokee
JEEP said that you can not do that. Looking at it, it looks like you can. Of course, they would rather you go the more expensive route.
How many drill bits will I ruin by drilling it, and installing a big bolt? Isnt the metal that is used really hard core metal that takes 30 minutes to drill through using a $80 craftsman drill?
Drew Mobley
post #4 of 5 Old 08-16-2013, 04:40 PM
tjcj
If the bolt is broke off can't you just grab a punch and BFH and beat the bolt out? I've done it before on a previous rig.
Sent from my XT881 using JeepForum
Yakima Valley Mountaineers.
tjcj is offline
post #5 of 5 Old 08-16-2013, 05:05 PM
CJ7-Tim
CJ7-Tim's Avatar
No, you can't do that, the rear shock mount is not an actual bolt, it more like a welded stud.
Using a set of good quality drill bits, and a powerful drill, you can drill through the remains of the stud and bracket in under 10 minutes.
Most any website that sells axle brackets, also has shock brackets.
CJ7-Tim is offline
