Best Penetrating Oil? - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Cheap Tricks & Fixes > Best Penetrating Oil?
Unread 06-21-2010, 03:50 PM   #1
Shinner
Got this as a forward in my email....thought I'd pass it along. Hope it's not a repost!
A study done by Machinist's Workshop magazine in their April 2007 issue looked at different penetrating oils to see which one did the best job of removing a rusted bolt by measuring the pounds of torque required to loosen the bolt once treated.
If the study was scientifically accurate, it turns out a home brew works best!
Here's the summary of the test results:
Penetrating oil ..... Average load
None ...................... 516 pounds
WD-40 ................... 238 pounds
PB Blaster .............. 214 pounds
Liquid Wrench ...... 127 pounds
Kano Kroil ............. 106 pounds
ATF-Acetone mix....53 pounds
The Automatic Transmission fluid (ATF)-Acetone mix was a "home brew" mix of 50 - 50 automatic transmission fluid and acetone.
Note the "home brew" was better than any commercial product in this one particular test. A local machinist group mixed up a batch and all now use it with equally good results. The home brew is Highly Flammable---Use Caution !!!
Note also that "Liquid Wrench" is about as good as "Kroil" for about 20% of the price.
His : 1992 YJ (Almighty 4 banger)
Hers: 2004 WJ Columbia Edition (4.7HO)
Black Jeep Society - Black Jeep Club V2.0 #37 - Merry Wacko Jeep Club #37 - Metalhead Jeep Club #37 - 2.5L Low Output Jeep Club #37
Shinner is offline   Reply With Quote Quick reply to this message
Unread 06-21-2010, 03:53 PM   #2
wilywillie
wilywillie's Avatar
HHmmmm....time to make a new concoction
wilywillie is offline   Reply With Quote Quick reply to this message
Unread 06-21-2010, 09:25 PM   #3
Shinner
UPDATE....Not so fast!
Although this article has gotten wide spread coverage on the web there was a follow up in a later issue that hasn't got quite the coverage.
ATF and acetone don't mix. When a reader wrote in to point this out the magazine contacted the author who admitted that he didn't actually use acetone. As it turns out he used 1-1-1 trichlorethane (sp?) which is a rather nasty chemical solvent that is no longer easily available to the general public. So, the test was bogus.
That said, I would think the numbers for the commercially produced penetrating oils should be valid.
Unread 07-13-2010, 09:30 PM   #4
jmonier
Ill stick to my PB, carry a can everywhere
jmonier is offline   Reply With Quote Quick reply to this message
Unread 07-15-2010, 11:13 AM   #5
extsp2
been using PB for a long time and personally think it's much better than liquid wrench or wd40.....never used kroil though and i see a few people on here prefer that.....i'm gonna have to get some and try it i guess....but as far as freeing up stubborn bolts, spraying pb and giving it time to soak (overnight ideally) it hasn't failed me yet.
extsp2 is offline   Reply With Quote Quick reply to this message
Unread 07-15-2010, 09:21 PM   #6
Obnoxious1
1981 CJ5
Marvel Mystery Oil
the stuff is awesome. They have a spray form as well & works great on rusted froze up bolts.
also great for stuck valves, fuel injection ( card & electronic) & all sorts of other uses
[B][SIZE="3"]Jeep[/SIZE][/B] [I]–noun[/I] (jēp)
A Four wheel mechanized device surrounded by glass and metal designed for the frequent consumption of the owner/operator's money. Jeeps are also linked to diseases such as Jeep envy which can be diagnosed by unusual urges for items such as bigger tires,lift kits, shocks and AMC 401s. As well as the urge to pour money into more than one Jeep. Side effects may be spouse accruing numerous "honey-do's", as well as trips to inlaws. Grease under your nails, numerous trips to NAPA and junk yards, and spare parts in the attic may indicate an addiction. There are no known cures. However there are support groups such as JeepForum.com
Obnoxious1 is offline   Reply With Quote Quick reply to this message
Unread 07-15-2010, 09:25 PM   #7
4DoorXJ
PB Blaster is your friend
4DoorXJ is offline   Reply With Quote Quick reply to this message
Unread 07-18-2010, 09:59 AM   #8
ChEaPsK87
1987 XJ Cherokee
PB does everything i want it to. beer does the rest
ChEaPsK87 is offline   Reply With Quote Quick reply to this message
Unread 08-02-2010, 11:59 PM   #9
smartshot
that's exactly what I use at work (where i take old equip apart).
smartshot is offline   Reply With Quote Quick reply to this message
Unread 08-03-2010, 10:47 PM   #10
grymsr
Vintage Member
grymsr's Avatar
are you saying that something from the internet was *gasp* untrue?
How's that Hope and Change workin for ya?
Black Jeep Club v1.0 and v2.0 #1776
grymsr is offline   Reply With Quote Quick reply to this message
Unread 08-08-2010, 09:07 PM   #11
scouperacer1994
1995 XJ Cherokee
I do PB mixed with anti-sieze. If I can get to the threads of a suck bolt, first I'll spread the a-s then hit it with PB it works wonders.
-1995 XJ Country, 4.5 Rusty's Springs and 1.75" spacers Front,4.5" leafs & 1.5"shackles, 33x12.5-15 BFG Mud Terrain T/A Locked and 4.10 geared D30/35
-1997 TJ Sport, 4" Procomp, RE Monotubes, 33x12.5/15 Goodyear Wrangler MT/R Locked and 4.10 geared D30/35.
Anything is possible if you don't know what you are talking about.
scouperacer1994 is offline   Reply With Quote Quick reply to this message
Unread 09-19-2010, 12:25 AM   #12
djoy
maybe finally I can install the receiver hitch. WD40 helped me snap 2 bolts :0
djoy is offline   Reply With Quote Quick reply to this message
Unread 09-19-2010, 01:02 AM   #13
Colbruski
Pb all the way. Just went into the garage to turn the light off and smelled gas thought to myself uh oh but then remembered I used half a can today ha!
Colbruski is offline   Reply With Quote Quick reply to this message
Unread 10-01-2010, 01:38 AM   #14
wordo30
what about that that new loctite stuff that freezes it and then sprays in lube when it is shrunk
wordo30 is offline   Reply With Quote Quick reply to this message
Unread 10-15-2010, 08:09 PM   #15
r00ster
mines cheeper
I love my PB blaster but, I had an old Mexican show me another trick when I lived in Tucson. He was a parts puller in the junkyard I got my yard parts from. I made a comment about howmuch WD 40 he must go through and he cussed the stuf. He used old antifreeze out of the cars in the yard. When an older car or truck came in he sprayed the blots down during the heat of the day with a squirt bottle and came back the next day and unbloted them. Call it recycleing going green if you will, antifreeze green
r00ster is offline   Reply With Quote Quick reply to this message
