Badass Shift Knob - Page 8 - JeepForum.com
post #106 of 302 Old 05-02-2009, 06:20 PM
deerhunter1911
20mm case takes the cake...way cool.
I am slowly, but surely fixing everything Jeep f'd up...
My super slow build:
Red Jeep Club member # 389
FLY NAVY!
deerhunter1911 is offline
post #107 of 302 Old 05-04-2009, 07:20 PM
green89yj
How about a lax ball? Anyone tried one of those? I have an orange and a white one. They make glow in the dark ones. They are about the perfect size for your hand and have just enough heft. They are solid as a rock.
Herc.Custom Green paint. RC 4". 5 Goodyear 33X12.5 MT/R w/Kev. Cragar V5's. Corbeau Moab seats. Optima Yellow.XRC8 Comp Winch. XJ 4.0/AX15
WTT: 4" springs for 6"
WTS: 4.2 parts. Fuel lines, pump, block, head, accessories, just ask
green89yj is offline
post #108 of 302 Old 05-13-2009, 06:01 PM
Joe1167
lax ball works great. played all my life. drilled a hole, and epoxied in the threaded insert. let it fully cure....
they are the perfect size....
Joe1167 is offline
post #109 of 302 Old 05-13-2009, 07:36 PM
green89yj
yeah. I was thinking that they are just right to palm. So you just epoxied in a nut or a sleeve or what? looks good. You ever play a team called Sav Lax or Spartans or anything like that?
post #110 of 302 Old 05-23-2009, 09:19 PM
jeepdavetj
1991 XJ Cherokee
Originally Posted by asf06 View Post
Any dippers out there?
You are my new hero. Gotta ask what you did to make that work? Did you cut out the bottom and fill it with an epoxy. Then add a thread insert? Skoal Straight FTW
I don't blame people for their mistakes, but I do expect they pay for them.
Ash from Army of Darkness
Alright you Primitive Screwheads, listen up! You see this? This... is my boomstick! The twelve-gauge double-barreled Remington. S-Mart's top of the line. You can find this in the sporting goods department. That's right, this sweet baby was made in Grand Rapids, Michigan. Retails for about a hundred and nine, ninety five. It's got a walnut stock, cobalt blue steel, and a hair trigger. That's right. Shop smart. Shop S-Mart. You got that?
jeepdavetj is offline
post #111 of 302 Old 05-24-2009, 05:59 AM
JeeperDon
Think Outside the Catalog
JeeperDon's Avatar
I use one from a '92 Integra. I like the bigger numbers for my old eyes, and I still need the numbers as I forget where the gears are. [This is the Dodge Durango forum, right?]
'93 YJ, '02 GM 4.3V6, SOA, dual ARB's, 8.8+D30(WarnHubs), 4.88s, 35" BFG KM2s, AX15, NP231+4:1+SYE+2LO, York OBA, Warn M8000.
Web Admin for
JeeperDon is offline
post #112 of 302 Old 05-24-2009, 10:52 AM
Mtnduey
hehe, could almost be prophetic. Grenade your engine/tranny/t-case
looks cool tho
-D2
Mtnduey is offline
post #113 of 302 Old 05-26-2009, 02:48 PM
asf06
I did a "write up" on the dip can on the jeep smokeless group forum. With pictures!
http://groups.jeepforum.com/index.ph...32&groupid=264
its simple all u need is a nut a drill and a piece of wood or metal
1993 YJ, too broke to swap the tranny and my 60s
Originally Posted by Rob99 View Post
It can't be a scam. There's pictures of Asian people in business suits pointing at charts and graphs.
PIKE Jeepers #1
Jeep Smokeless #4
asf06 is offline
post #114 of 302 Old 06-13-2009, 07:16 PM
Slickbr
Check out the Custom Shifter Knobs that I created.....
Guiness & Grenade
Slickbr is offline
post #115 of 302 Old 08-07-2009, 06:12 PM
Jeep2003
1946 CJ2A
1967 cj-5, 1946 Willys Jeep cj-2a, 1982 911sc turbo look, 1958 impala, 1987 k5 blazer
Jeep2003 is offline
post #116 of 302 Old 08-10-2009, 03:03 PM
Pathfinders
Just a boring old cue ball. Fits the hand pefectly though.
Pathfinders is offline
post #117 of 302 Old 08-11-2009, 01:41 PM
YJake
I have a baseball and pineapple grenades in my garage just can't figure out how to mount them because my origonal bolt was sheared off...
I have a LAX ball on there now until I figure out how to put the grenade on there.
/l , [____],
l---L--[]lllllll[]-_
()_) ()_)==@=)_)
Originally Posted by clemsonfan16 View Post
The 4banger only whines because it wants more!
Originally Posted by Opihi59 View Post
3 Things to know about the forum: Always PB blaster, Always check the FAQ, Always do a search, and if none of that works, ask Mean Max.
YJake is offline
post #118 of 302 Old 08-11-2009, 04:36 PM
JeeperDon
JeeperDon's Avatar
Originally Posted by MosinMe View Post
...just can't figure out how to mount them because my origonal bolt was sheared off...
I'd grind the top of the stub smooth, then drill and tap it, then cut the head off a bolt and use the threaded part as a stud. It should be fine if kept tight. Don't use a shift ball that needs to be facing a certain way, so you can just hunker it down with no lock nut.
Web Admin for
post #119 of 302 Old 08-11-2009, 05:06 PM
YJake
Good idea!
I could take the head off the grenade and use a nut with a large washer to stick the thing on there then adjust the top of the grenade for comfort...
Briliant!
/l , [____],
()_) ()_)==@=)_)
YJake is offline
post #120 of 302 Old 08-11-2009, 05:13 PM
CoolContractor
Automatic shift knob.
2006 TJ Rubicon
CoolContractor is offline
Home-made wooden shift knob flatlander757 Fabrication Shop 31 01-15-2010 11:13 AM
Aftermarket Shift Knob CherokeeClassic Street Jeep Forum 3 08-15-2007 08:54 PM
transfer case shift lever hard to shift phant0omx Engines & Drivetrain 1 08-18-2006 07:59 PM
Shift Knob RoverJeep90 Cheap Tricks & Fixes 10 04-20-2006 10:54 AM
shift knob highroller84 Cheap Tricks & Fixes 4 01-04-2006 10:40 AM
