Badass Shift Knob - Page 5 - JeepForum.com
post #61 of 302 Old 06-23-2008, 10:56 AM
Mudweiserjeep
Mudweiserjeep's Avatar
1970 CJ5
I like the baseball.
To do a Baseball shift knob.....do you use a theaded insert some how....or just a hole and jam it on the shifter?
Tim - KC8UXU
1987 XJ (Evil) (Parting out)
1970 CJ5
231 V6
2.5"bds lift, 0.75" shackle lift, 4:88 gears
31" Old tires..... need newer ones....going 35"
Mudweiserjeep is offline
post #62 of 302 Old 07-01-2008, 09:09 PM
YJake
I'm intrested in doing this but not sure about threading a hole in the grenades. I'll have yo practice on somethign else first to perfect the art. But I really do like this mod!
YJake is offline
post #63 of 302 Old 07-02-2008, 12:49 PM
Mudweiserjeep
1970 CJ5
Anyone?.......
Tim - KC8UXU
1970 CJ5
231 V6
post #64 of 302 Old 07-02-2008, 12:59 PM
SillyPutty
You'd need an insert. Baseballs are just wound cord. The threads on the shifter wouldn't hold after a while.
The apostrophe key does not mean "Look out, here comes an S"!
SillyPutty is offline
post #65 of 302 Old 07-07-2008, 06:57 AM
ImBroken
Here's mine...
ImBroken is offline
post #66 of 302 Old 07-08-2008, 11:49 AM
Rasilis
Yeah inserts are best, you can do it with epoxy though.
You need to find a bolt with the same threading as your shifter, drill a hold big enough for it in the baseball, spray the bolt with a bunch of wd-40 or Pam or something to make it less sticky, fill the hole in the baseball with epoxy (takes a bit), insert bolt, allow to dry, unscrew bolt and screw onto shifter. Holds well depending on what epoxy and how much you use.
I did my first one with epoxy, then I found the inserts while working at a furniture store and when I decided I needed a new one I used the insert
Rasilis is offline
post #67 of 302 Old 07-08-2008, 12:09 PM
Mudweiserjeep
1970 CJ5
Thanks....I will give the epoxy a try if I can't find an insert.
Tim - KC8UXU
1970 CJ5
231 V6
post #68 of 302 Old 07-14-2008, 10:32 PM
athos76
I just bought a skull carved from smelted quartz on ebay... gonna drill it out and use it as my knob. Go to ebay and do a search... some really cool ones on there... I only paid $1 plus shipping
athos76 is offline
post #69 of 302 Old 07-17-2008, 09:49 AM
flyerboy1522
I found some brand new pistons when I was moving and was thinking about making a shifter out of one! anyone else every done this? I have no clue where they came from or how they got in my garage, but I have 3 of them????
"Man that never made a mistake, never made a discovery!"
- Ty -
flyerboy1522 is offline
post #70 of 302 Old 07-17-2008, 10:57 AM
SpoiledRotten
SpoiledRotten's Avatar
Originally Posted by wil badger View Post
i see you live in New Jersey .remember to keep your old shift knob for inspection day.if you replace the factory shift knob with the pattern on the knob then you have to have the pattern displayed someplace.you might be able to find a sticker in an auto parts store then just stick it on the dash in plain view
Some law makers need to just quit and go home... Have to have the shift pattern on it for inspection. They really don't have enough to do. Good Grief!
Christian Jeepers _ Member #2
United Four Wheel Drive Association _ Member
National Rifle Association _ Member
SpoiledRotten is offline
post #71 of 302 Old 07-17-2008, 11:13 AM
SpoiledRotten
Originally Posted by ImBroken View Post
Here's mine...
Clicky Free
post #72 of 302 Old 07-20-2008, 08:04 PM
jimaug87
I got the grenade from Quadratec. It's tapped in the side and is a T handle. I love the thing. I did take the pin out because of the rattling, and it's much more comfortable now.
2005, I6, 6 Speed, RC 2.5", RC front adj. track bar, 31" Goodyear DuraTracs
"Nobody is comepletly useless. We can always serve as a bad example."
jimaug87 is offline
post #73 of 302 Old 10-23-2008, 08:54 AM
sorrymissfofo
heres mine
sorrymissfofo is offline
post #74 of 302 Old 11-10-2008, 05:06 PM
thetrashman
Steeling from an open top jeep is not cool
AMEN TO THAT!
95' Little Red Yj.
"My Jeep Doesnt Leak, Its Just Marking Its Territory"
Mostly Stock,With A Few Things
thetrashman is offline
post #75 of 302 Old 11-10-2008, 06:51 PM
tigeowner
Is it possible to get an aftermarket shift nob for an automatic?
tigeowner is offline
Home-made wooden shift knob flatlander757 Fabrication Shop 31 01-15-2010 11:13 AM
Aftermarket Shift Knob CherokeeClassic Street Jeep Forum 3 08-15-2007 08:54 PM
transfer case shift lever hard to shift phant0omx Engines & Drivetrain 1 08-18-2006 07:59 PM
Shift Knob RoverJeep90 Cheap Tricks & Fixes 10 04-20-2006 10:54 AM
shift knob highroller84 Cheap Tricks & Fixes 4 01-04-2006 10:40 AM
