Badass Shift Knob - JeepForum.com
post #1 of 302 Old 05-15-2006, 11:11 AM Thread Starter
bokey
Badass Shift Knob
Well, I've been wanting to change over my shifter knob to something more cool. I was thinking about using the 8 and 9 ball from a pool set but couldn't find any extra and didn't feel like paying $$$ for a set of balls. So I was in my local Army/Navy store and came across one of these bad boys for $10
'94 Wrangler - Traded
'87 Trans Am - SOLD
'99 Cherokee Classic
bokey is offline
post #2 of 302 Old 05-15-2006, 11:23 AM
TellyDSP
Poland and PPV!!!!
I would remove the pin. Heard the rattling will really get to you.
-Craig-
95 Rio Grande
07 Ram 1500
Originally Posted by Jeeples
n00bs bashing n00bs, it's a pitifull thing.
TellyDSP is offline
post #3 of 302 Old 05-15-2006, 11:46 AM Thread Starter
bokey
Actually, it doesn't bother me at all. I hear either the wind blowing, the radio or people trying to talk lol. Also if I do take the pin out, the handle will fall out (unless I glue it in). I dunno, a gernade isn't a gernade without the pin. I'm also thinking about putting it side ways like a t-handle; not sure yet.
'87 Trans Am - SOLD
bokey is offline
post #4 of 302 Old 05-15-2006, 12:56 PM
92 Green YJ
92 Green YJ's Avatar
yeah I used to have a grenade too and the pin rattling did get really annoying after a while
92 YJ. High Output 4.0L
Rubicon Express 4" Lift Kit, 2" Body Lift,15x8" AR 767s, 35x12.50 Xterrains, Home Made Snorkel, Sanden OBA, Home made rocker gaurds. 8.8 Rear with Discs, 4.10s F&R, ARB rear, Detroit EZ Locker front, WarnM8000 with Viking Synthetic Line, Beadlocks, Tons of Mods
My
Score: 682RRv1.0 with a BOA of 13.47
I'm now doing custom bumpers and lift installs in So-cal
92 Green YJ is offline
post #5 of 302 Old 05-15-2006, 02:56 PM
Rockiholic
I understand that. My favorite pastime is listening to the loose baffles in my exhaust rattle, or trying to predict the next backfire (unfortunately I pretty much fixed this problem so it doesnt happen too much). Nice shifter though.
Rockiholic is offline
post #6 of 302 Old 05-16-2006, 12:36 PM Thread Starter
bokey
thanks
'87 Trans Am - SOLD
bokey is offline
post #7 of 302 Old 05-16-2006, 01:08 PM
Mudweiserjeep
Mudweiserjeep's Avatar
1970 CJ5
I like the shift knob!
Just a thought on the rattle.......maybe you could get some plastic dip (used for tool handles) and coat the ring part. Would still look good and would also be quiet.
Tim - KC8UXU
1987 XJ (Evil) (Parting out)
1970 CJ5
231 V6
2.5"bds lift, 0.75" shackle lift, 4:88 gears
31" Old tires..... need newer ones....going 35"
Mudweiserjeep is offline
post #8 of 302 Old 05-16-2006, 07:05 PM
jmanimal
jmanimal's Avatar
Could also super glue the pin in situ-no more rattles and still looks "natural"
Now:2011 JKU
Gone:2001 TJ;1998 5.9 ZJ;1995 5.2 ZJ
matanzasjeepclub.com
jmanimal is offline
post #9 of 302 Old 05-17-2006, 03:23 AM
gatmog
I'm not sure, but i think the shell is made of lead--i'd put a nice thick coat of od green on it just to make sure.. but i could be wrong...great shifter!!!
gatmog is offline
post #10 of 302 Old 05-17-2006, 07:24 AM
nodoor94
yeah i made one of those for my transfer case shifter, i heard that it gets annoying to grab at a grenade to shift all the time, an when im on the trail, an i have to grab at the stick fast, i dont want to accidentaly jab my hand on a pin or handle. looks good tho, an i made my for 8 or 10 bucks too. (can you believe they cost 45 bucks in the quadratech catalog?!!??)
94 YJ, 4.0L, 5-speed maunal, 4WDHardware 3.5'' lift, 33'' BFGoodrich M/T, JKS Quick-Disconnects, Rockcrusher Diff Covers for D30/D35, K&N FIPK Intake, Hesco Throttlebody Spacer, Silverstar Headlights, Warn Rear Bumper, Trackbars gone, Home-cut front bumper
Blue Jeep Club Member #194
nodoor94 is offline
post #11 of 302 Old 05-17-2006, 12:44 PM
rjt36
rjt36's Avatar
2009 JK Wrangler
Two questions:
1. Did you tap the grenade so it screws on, or is it just glued?
and
2. How would you go about making it your T-case shifter?
rjt36 is offline
post #12 of 302 Old 05-17-2006, 01:23 PM
mad scientist
mad scientist's Avatar
I just recently did the same thing on my TJ, however I drilled and tapped a hole in the side to use it as a T-handle. If you do it that way, just remember to put it at a bit of an angle, not just straight across so that it's easier/more natural to grab onto and shift. Plus it looks pretty sweet with the hand throttle lever just below it. I removed the ring cause it annoyed the heck outta me. All I did was RTV the trigger handle underneath, the re-inserted the cotter pin, then bent it around into one of the extra holes in it to get it out of the way. Hasn't rattled since.
'97 TJ
'05 WK
mad scientist is offline
post #13 of 302 Old 05-17-2006, 04:15 PM
SGT Superman
SGT Superman's Avatar
So how does it feal in the hand? Are there any spots that would do better if ground down? And if anyone has tried it as stright up and as a T handle which did you like best.
I think I would like to try this as a T-handle.
Now you know, and knowing is half the battle. G.I. Joe!
Green Jeep Club Member #174
GO COUGS!
SGT Superman is offline
post #14 of 302 Old 05-17-2006, 05:36 PM
wwiihistory
wwiihistory's Avatar
Shell was cast iron.
If you want to make it more non-training looking...get rid of the light blue and also paint a yellow band around the neck just under screw in fuse.
Happiness is a belt-fed weapon
95 Sahara, 4.0L, 5 spd, Olive/Tan, HT,HD's, 31's,3.07s
Military Jeep club member 1941,1942,1943,1944, and 1945
wwiihistory is offline
post #15 of 302 Old 05-17-2006, 09:14 PM
Marauderk
Well i would hope the grenade was cast iorn and not lead
89 YJ Islander Yellow, 258 Clifford intake holly carb MSD 6
Smittybilt flat fenders, Dick Cepek 3.5 in lift, Warn 8000I
2007 Rescue Green 2d Rubicon 6 speed soft top
Rubicon express 3.5 superflex system,35 in interco truxs mt's, skidrow skid plates, Killby muffler plate
Marauderk is offline
Home-made wooden shift knob flatlander757 Fabrication Shop 31 01-15-2010 11:13 AM
Aftermarket Shift Knob CherokeeClassic Street Jeep Forum 3 08-15-2007 08:54 PM
transfer case shift lever hard to shift phant0omx Engines & Drivetrain 1 08-18-2006 07:59 PM
Shift Knob RoverJeep90 Cheap Tricks & Fixes 10 04-20-2006 10:54 AM
shift knob highroller84 Cheap Tricks & Fixes 4 01-04-2006 10:40 AM
