Axle breather hose - JeepForum.com
post #1 of 3 Old 12-28-2012, 07:26 PM Thread Starter
joey5639
Axle breather hose
Hello guys i have a 95 yj wrangler and I've been preparing it to go off roading and in mud and water etc i was told i had to extend the axle breather hoses higher so that water doesn't get in i it does my axle will lock up and I'm screwed basically. So i was told there was two hoses one in the front axle and another in the rear.my general question is where and how high should i extended the hoses
joey5639 is offline
post #2 of 3 Old 12-29-2012, 07:28 AM
Feetwet
Enjoying the Ride
Feetwet's Avatar
If your 95 still has the stock setup, you can trace the rubber hoses from the differentials upwards and see where they currently end. The rear should go up behind the driver's taillight, the front should lead forward and end next to the radiator on the driver's side. They should both have check valves at their ends.
They should already end about as high as your headlights, if you get that deep you have other things to worry about as well.
Many discussions about waterproofing your rig can be found using Search.
...and try to fill out your Profile so we can know more about your Jeep.
Fight Crime...Shoot Back
Friends don't let friends roll over without a negative-G strap
Feetwet is offline
post #3 of 3 Old 02-02-2013, 01:53 PM
blakeg38135
they have a plastic check vavle on them ur good inless u go swiming but dude on my transfer case hose the zip tie that holds it to the bell houseing broke an the hose had some slack to move around an the front drive shaft rubed a hole in it an drained my transfer case out of atf i had to replace the seals and the chain but diff check that
blakeg38135 is offline
