any tricks to make your jeep look lifted? - Page 6 - JeepForum.com
post #76 of 92 Old 05-02-2012, 01:08 PM
RedlegWJ
Don't allow your girlfriend to where her high heels.
Gray 99 Laredo with '04 driveline wap. Tons of fun coming soon. Steel bumpers. 5 1/2" IRO coils, IRO adj. track bar. Rancho RS9000 Addco rear sway. 2"x.250" DOM long arms with johny joints. Custom A-arm with ball joint delete (J-joint). JK Moab wheels/ 33x 12.5 x 17 Cooper SST. Bushwacker Flares.
RedlegWJ is offline
post #77 of 92 Old 05-06-2012, 02:06 PM
tangJKU
Originally Posted by strhodes
well i allready got the tires i like and i just want the 2" lift to fit them better. i'm 16 and my dad doesnt want me to "go crazy" with mods. but thats mostly because he thinks that any kind of lift will screw up the fuel efficiency and he thinks its more complicated than it actually is. he also thinks it will mess up the steering column. would it?
What fuel efficiency? It's a Jeep
tangJKU is offline
post #78 of 92 Old 05-06-2012, 08:30 PM Thread Starter
strhodes
good point. lol
"Over, under, or thru, never around."
strhodes is offline
post #79 of 92 Old 07-26-2012, 10:49 PM
guillot1994
good point. lol
Just watch the alignment after my lift the steering wheel was always slightly turned until my alignment. You don't want the tires to wear uneven and that will eventually make for a rougher ride!
guillot1994 is offline
post #80 of 92 Old 10-29-2012, 06:29 PM
jeeper06
I bought mine used with a aev finder and heat reduction hood. I could fit 35" with out any lift they rub a little but not to bad. But I can fit 37" with a 4" lift
06 tj 4.56 dana 44s 2.5" inch lift on 35"
jeeper06 is offline
post #81 of 92 Old 11-01-2012, 02:05 PM
TheRealKTrain
JK Wrangler
Stop posting bad information. You have a ****load of rub unless you're running 3" backspacing on your 35s. There is a difference in being able to install 37s, and being able to USE 37s.
"We are what we repeatedly do. Excellence, then, is not an act, but a habit." Aristotle
Μολὼν λαβέ
TheRealKTrain is offline
post #82 of 92 Old 11-02-2012, 10:53 PM
tarrant
You can easily fit 35s with the right back spacing just as long as you don't love your flares. And as for the lifted look, why not use a bodylift? Your dad can't say **** then, and it will look good, fit bigger rubber and not affect handling (as much) keeps your centre of gravity low. Probably cost like $80 to get a bodylift kit or make one
tarrant is offline
post #83 of 92 Old 11-04-2012, 06:18 PM
Irongrave
i still say DIY highline
Current
2002 WJ 2wd DD
Irongrave is offline
post #84 of 92 Old 11-18-2012, 04:58 PM
JimTim
2011 JK Wrangler
I'm 19 and i've been building lifted 4x4s and worked on the "low and slow" (well not so slow.. Evos and M3...) since i was 16 and can give you this advice, PAY IT OFF before you build it even if the moneys to you're father because you don't want to blow all your money makin it go up then be stuck when he takes the keys. And most defiantly research everything before you buy. But as far as lifts and loans i'm in the same boat so good luck and do it right!
"Supporting the troops has got to mean more than bumper stickers on our pickup trucks"
JimTim is offline
post #85 of 92 Old 11-27-2012, 09:54 AM
chibucket
i know everyone else has said it but... just save your money and get a lift you will be happier and wont be "that guy"
4.5" RE Springs, OME Shocks, SYE, Tom Woods driveshaft, Adjustable Everything,
33" Wrangler MTR's Flat Fenders, K&N Intake, 4:56's, KC Daylighters
chibucket is offline
post #86 of 92 Old 12-02-2012, 12:49 PM
jemello89
Just stop trying to look cool and go out and lift it. Not trying to be harsh but the amount of time trying to deceive people to think ur lifted u could have put a lift kit in. Personally I think lifting a yj is pointless. Xj, zj, tj way to go
jemello89 is offline
post #87 of 92 Old 12-02-2012, 12:59 PM
connor0770
Originally Posted by strhodes View Post
how does this work?? haha doesnt make sense
you dont know what helium is?
You said you are 16 which means you are in highschool! How do you not know this?
Im assuming you want your Jeep to look bigger so you can impress the ladies?
97 TJ Dana 30 w/ARB Solid Cover, Currie 4" lift, Ford 8.8 w/ Riddler Cover, Currie Steering, Trail Gear Front Bumper, LOD Rear Tire Carrier, Smittybuilt XRC8, 35" KM2's, 5100 Bilsteins, Teraflex Oil Pan Skid, Poison Spider Sliders, Rock Lights etc.
connor0770 is offline
post #88 of 92 Old 12-23-2012, 07:14 PM
Stinkbug
Stinkbug's Avatar
Originally Posted by Indy
Cut 4 pieces of 2*4 into desired length and install between axle and frame with a sledge hammer.
Awsome suggestion
Sent from my iPad using JeepForum so please excuse any stupid iPhone autocorrect spelling errors
Stinkbug is offline
post #89 of 92 Old 12-30-2012, 08:24 AM
vman88888
1994 ZJ
budget boost
"could've had a v8"
vman88888 is offline
post #90 of 92 Old 12-30-2012, 02:14 PM
brokenujoint
cut off your legs
If @ 1st you don't succeed, grind it, hammer it, weld it, drink a beer and try again.
brokenujoint is offline
Removing diff gaskets. . .any tips or tricks to make it easier??? atomicjoe23 Engines & Drivetrain 11 04-24-2012 05:05 PM
Just got first jeep, Any tips,tricks i should know Skytard Cheap Tricks & Fixes 35 04-26-2011 02:03 PM
my first jeep! cool tricks?? 04TJrubicon Cheap Tricks & Fixes 8 06-02-2009 03:33 PM
What it takes to make a Lifted 4x4? '93Jeep General Jeep & Off-Road Equipment 3 12-03-2007 10:35 AM
