any tricks to make your jeep look lifted? - Page 3 - JeepForum.com
post #31 of 92 Old 12-26-2011, 08:32 PM
Bama1987
Park it next to a honda
Bama1987 is offline
post #32 of 92 Old 12-31-2011, 01:01 PM
Pelikan
Marry a midget.
2013 JKU, billet (silver), Teraflex 2.5" llift, Teraflex lcr's, ATX Artillery wheels, 33x12.5x17 Mickey Thompson MTZ's, Smittybilt XRC rear bumper, Rock Hard front bumper w/ Warn M8000, N-Fab nerf bars, OR-Fab swingout tire carrier
Pelikan is offline
post #33 of 92 Old 12-31-2011, 08:46 PM
BrianBFD
Originally Posted by strhodes View Post
well i allready got the tires i like and i just want the 2" lift to fit them better. i'm 16 and my dad doesnt want me to "go crazy" with mods. but thats mostly because he thinks that any kind of lift will screw up the fuel efficiency and he thinks its more complicated than it actually is. he also thinks it will mess up the steering column. would it?
2" Won't do anything to your MPG's. It is also pretty easy to install. I will not do anything to your steering column. The only thing altered by a 2" lift is the looks and you will have to have an alignment afterwards.
If fishing is a sport, does that make me an athlete?
BrianBFD is offline
post #34 of 92 Old 12-31-2011, 08:51 PM
ruthole
Originally Posted by Photog2000
Are you a complete idiot?
Never put blocks in the front to lift any vehicle.
It will lower it if SUA any how
Edit somebody beat me to it. And if SOA he wouldn't have made this thread
94 yj, 4" RC lift 1" shackles, 33's interco M/T's, SRC front bumper, custom built rear bumper, cb, Hi-lift, D30 OX locker, 8.8 LSD,
Lone jeep club member #1
Originally Posted by TMSquy View Post
If parts aint flyin you aint tryin!
ruthole is offline
post #35 of 92 Old 01-20-2012, 09:06 PM
XJnoob2012
What color is the vehicle?
The reason I ask is this: I have a white XJ that I recently did some exterior work too that unintentionally made it look slightly "taller." In this case, I sprayed bedliner on the rocker panels on each side of the vehicle just up to the first body line. This was meant to start the process of protecting it from salt, as the vehicle was previously driven only in the south, and to break up the absurd amount of whiteness on this vehicle. Anyway, to get to the point, the contrast between the white body paint and the black bedliner on the bottom of each side made it look like it has a bit more clearance without actually doing anything complicated/expensive.
Not sure if that is what you are looking for, but just a thought.
At some point in the not too distant future I will be looking to do a boost also; noticed some deals in the vendor section on budget boosts. Another idea, which you may have already looked at, is a junkyard boost. Should be relatively cheap, just gotta figure out what parts you want. Search the forum, there is tons of info on what will work.
XJnoob2012 is offline
post #36 of 92 Old 01-21-2012, 06:46 PM
johnoh
really long shackles?
johnoh is offline
post #37 of 92 Old 01-22-2012, 10:33 PM
Anticanman
RIP one good jeeper
Anticanman's Avatar
I'd say trim your flares. It helped me fit some bigger rubber. Jonzjeepyj did a custom cut flat fender job up front and it looks pretty awesome. It's definitely an improvement and it costs only time. Also adding tj flares will open the wheel wells and give the impression of lift in a sense.
Luck Favours The Prepared
Anticanman is offline
post #38 of 92 Old 01-24-2012, 06:55 PM
Shilohsho
Jump the jeep and have someone take a picture while it is in mid air. If you want it to look lowered then have the same photographer snap a pic at landing. This should do the trick.
Shilohsho is offline
post #39 of 92 Old 01-28-2012, 10:07 PM
OsteKuste
LMFAO!! Even better, park it on a Honda!
2000 TJ Sahara 4.0
1961 Willys CJ5
2004 WJ Grand Cherokee Laredo, Freedom Edition
OsteKuste is offline
post #40 of 92 Old 01-30-2012, 11:41 AM
speedbucket
Jack it up by the frame til your tires are barely touching the ground
Then take a picture.......wit midgets and some mini Dobermans and say they are full size
Or take a picture of a hotchick in bikini with your low rider Jeep in the background. Nobody will see the Jeep
V8 zj at 6" . Double tri rear and true 3 link front. Stretched to 108"
speedbucket is offline
post #41 of 92 Old 02-06-2012, 04:04 AM
nacheswheelin
so i assume that would be relatively simple then? i've been thinking about installing a 2" body lift but i dont know how that would effect stearing, leaf springs, fuel efficiency.
instead of the body lift buy some shackles it will look better and get your drivetrain up a little higher not just the body
REMEMBER the higher you go the easier to flip!!
nacheswheelin is offline
post #42 of 92 Old 02-06-2012, 05:35 PM Thread Starter
strhodes
sounds like a good idea! i was thinkin about a 2" lift but i cant find any shackles that would give that much. the most i found was 1.25" for a YJ (which is what i have). 1.25" would be ok but if anyone happens to find something around 2" please let me know!
"Over, under, or thru, never around."
strhodes is offline
post #43 of 92 Old 02-06-2012, 06:22 PM Thread Starter
strhodes
nevermind. found a bunch on ebay. just wondering, what kind of effect would tha have on the jeep? the same as a body lift i assume? and this might be a stupid question but dont you need 4 up front and 4 in the back or just 4 to go all around?
strhodes is offline
post #44 of 92 Old 02-07-2012, 05:13 AM
nacheswheelin
yes you will need two per leaf spring which is 8 total, when you change the shacles it helps to have a punch to get that bolt out without scarring.
post #45 of 92 Old 02-07-2012, 08:20 AM
Anticanman
RIP one good jeeper
Anticanman's Avatar
Why don't you contact BESRK or VACJ5 in the CJ section and have them set you up with shackles? It'll be a lot cheaper and you'll be supporting JF members.
On the yj's you have to use a sawzall or cutoff wheel to get the rear passenger bolt out. It's just a bad factory design.
Removing diff gaskets. . .any tips or tricks to make it easier??? atomicjoe23 Engines & Drivetrain 11 04-24-2012 04:05 PM
Just got first jeep, Any tips,tricks i should know Skytard Cheap Tricks & Fixes 35 04-26-2011 01:03 PM
my first jeep! cool tricks?? 04TJrubicon Cheap Tricks & Fixes 8 06-02-2009 02:33 PM
What it takes to make a Lifted 4x4? '93Jeep General Jeep & Off-Road Equipment 3 12-03-2007 09:35 AM
