any tricks to make your jeep look lifted? - Page 2 - JeepForum.com
post #16 of 92 Old 12-16-2011, 04:04 PM
DoctorTim
trim fenders, bigger tires, and whatever non-suspension related items that effect your clearence (high-clearence transfer case crossmember/skid, small bumpers that show off all the linkage and suspension... )
96 XJ, geared, 8.8, 5", 33s, dash
DoctorTim is offline
post #17 of 92 Old 12-16-2011, 04:05 PM
DoctorTim
also, you have all leaf springs, I can install a 2" lift in 20 mins on one of those things, but get a block of aluminum with a hole through the center and bolt it right in!
post #18 of 92 Old 12-17-2011, 06:35 AM
Photog2000
Are you a complete idiot?
Never put blocks in the front to lift any vehicle.
Photog2000 is offline
post #19 of 92 Old 12-17-2011, 11:28 AM
DoctorTim
XJs dont have leafs in the front, i wouldn't know that dip****. So no, I'm not a complete idiot, not as much as you anyways..
post #20 of 92 Old 12-17-2011, 10:28 PM
Photog2000
You just proved my point. He has a YJ with all leaf springs as you pointed out for yourself above. You then go on to point out that I was the moron for pointing out your shortcomings. Maybe you should go back to the beginning of the thread. I stand by my first post.
post #21 of 92 Old 12-18-2011, 04:59 PM
BSInc
just wait until he figures out that YJ's are spring under.
2" block = 2" lowering kit.
check out flare and highline options like www.genrite.com and modernclassicenterprises.com to open up the wheel opening allowing bigger rubber like others have mentioned.
BSInc is offline
post #22 of 92 Old 12-18-2011, 06:58 PM
04WJny
1987 YJ Wrangler
^lmao
You can get some midgets to drive your jeep so it looks bigger
2004 WJ I6 4.0L DD
1987 YJ I6 4.2L Weber 34 DGEC carb, 4in RC, Custom 1 inch BL,Custom Steering box skid, homemade rear bumper with tire carrier, 33x12.5x15 KM2's on
Cragar Soft 8's, and a few other things
In the process of putting in an 8.8, d30, 4.10's, SOA, and a homemade belly up skid
04WJny is offline
post #23 of 92 Old 12-20-2011, 05:51 PM
bpmichael
Originally Posted by 04WJny
^lmao
Very nicely done.
bpmichael is offline
post #24 of 92 Old 12-20-2011, 06:28 PM
BrianBFD
Do all of this and smaller tires, small tires will also show more of your linkage/suspension thingys...
If fishing is a sport, does that make me an athlete?
BrianBFD is offline
post #25 of 92 Old 12-20-2011, 07:53 PM Thread Starter
strhodes
so i assume that would be relatively simple then? i've been thinking about installing a 2" body lift but i dont know how that would effect stearing, leaf springs, fuel efficiency.
strhodes is offline
post #26 of 92 Old 12-21-2011, 05:23 AM
BrianBFD
2" really isn't that much and will have little effect that you can actually notice. What happens is, a 2" lift with stock tires will look a little odd and leads to bigger tires (less mpg's), then you decide that looks o.k. but 4" would look better than the wimpy 2", with the 4" lift comes, yep, that's right, bigger tires, and this will continue on until you are out of money or you have created something you can't even drive on the street anymore....
This scenerio does not even address the other changes that you will HAVE to do, like roll cage upgrade, flat fenders, etc...
BrianBFD is offline
post #27 of 92 Old 12-21-2011, 01:47 PM Thread Starter
strhodes
well i allready got the tires i like and i just want the 2" lift to fit them better. i'm 16 and my dad doesnt want me to "go crazy" with mods. but thats mostly because he thinks that any kind of lift will screw up the fuel efficiency and he thinks its more complicated than it actually is. he also thinks it will mess up the steering column. would it?
"Over, under, or thru, never around."
strhodes is offline
post #28 of 92 Old 12-21-2011, 02:42 PM
CrawlingForward
It's a good idea not to go crazy in the beginning. Wheel it a few times and decide what you're looking for before doing much.
In terms of the steering column, it'll make your steering wheel off by a bit at first, but an alignment will fix that (which you should do anyhow after a lift). But that's almost in the aesthetics category.
95 YJ, Rio Grande - The Wannabe Sleeper Wheeler
2010 JKU, Islander Edition - The Burly Stock Overlander
Build/Wheel/Break/Educate/Upgrade/Repeat
CrawlingForward is offline
post #29 of 92 Old 12-21-2011, 03:26 PM Thread Starter
strhodes
ok. thanks.
strhodes is offline
post #30 of 92 Old 12-21-2011, 03:39 PM
timmysyj
Paint some vertical stripes on it. Works for short people wearing striped shirts.
SO FAR
35" Toyo MT's, 6" lift, and some other shi..
police scanner & CB in my homemade overhead console
timmysyj is offline
Removing diff gaskets. . .any tips or tricks to make it easier??? atomicjoe23 Engines & Drivetrain 11 04-24-2012 04:05 PM
Just got first jeep, Any tips,tricks i should know Skytard Cheap Tricks & Fixes 35 04-26-2011 01:03 PM
my first jeep! cool tricks?? 04TJrubicon Cheap Tricks & Fixes 8 06-02-2009 02:33 PM
What it takes to make a Lifted 4x4? '93Jeep General Jeep & Off-Road Equipment 3 12-03-2007 09:35 AM
