any tricks to make your jeep look lifted? - JeepForum.com
post #1 of 92 Old 12-15-2011, 10:56 AM Thread Starter
strhodes
does anyone have any tricks to make your jeep look lifted or more lifted than it already is? i have a jeep yj with 30" BF Goodrich Mud-Terrain tires, no lift, and stock fender flares.
strhodes is offline
post #2 of 92 Old 12-15-2011, 11:31 AM
theshaolin
Try installing a lift kit.
1996 Cherokee Sport - 4x4 4.0L - Wheeling Project
1986 Mazda RX-7 Turbo - 400RWP project - 2000 Saturn SC1 - Turbo RWD project
1996 Suzuki Bandit 600 - Frame up restore project - Too Many Projects!!
1991 Chevrolet K1500 - 4x4 5.7L 5spd - For Sale (Cheap!)
theshaolin is offline
post #3 of 92 Old 12-15-2011, 11:34 AM
Tdog02
Try trimming your flares or get some flat ones👍
it is what it is except when its something else
Tdog02 is offline
post #4 of 92 Old 12-15-2011, 11:46 AM
BrianBFD
"Ghetto" coil spring boosters...
As long as you stay on flat pavement and don't do any flexing, strictly for posing. You'll want to buy extras, these sometimes pop out when you hit a pothole. When they come out it's only a problem for the person behind you.
If fishing is a sport, does that make me an athlete?
BrianBFD is offline
post #5 of 92 Old 12-15-2011, 02:45 PM
nottusyeroc
Put on really small tires you'll look lifted from far away.
nottusyeroc is offline
post #6 of 92 Old 12-15-2011, 06:15 PM
austonreeves
If you have running boards...take them off... Mine looks taller without them
austonreeves is offline
post #7 of 92 Old 12-15-2011, 06:40 PM
nottusyeroc
You can also fill tires with helium and it will look bigger.
post #8 of 92 Old 12-15-2011, 06:50 PM
Irongrave
start cutting sheet metal and get bigger tires
Current
2002 WJ 2wd DD
Irongrave is offline
post #9 of 92 Old 12-15-2011, 06:55 PM
CrawlingForward
I'm confused....
1) You said "coil" when it's a YJ and 2) Even with coils, how the hell do those things work?
95 YJ, Rio Grande - The Wannabe Sleeper Wheeler
2010 JKU, Islander Edition - The Burly Stock Overlander
Build/Wheel/Break/Educate/Upgrade/Repeat
CrawlingForward is offline
post #10 of 92 Old 12-15-2011, 07:37 PM
superj
they screw in between two of the coils on the spring and make the space larger, like wedging something in there and spreading them apart.
I don't feel like working on anything at this time so i sold my yj.
superj is offline
post #11 of 92 Old 12-15-2011, 09:02 PM
BrianBFD
Originally Posted by CrawlingForward View Post
I'm confused....
You are right, YJ's don't have coils. I didn't think to look at what type of jeep the OP had.
As for how they work, the previous post is correct they twist in and gap a section of the spring further apart. These things are typically meant to be used for weak or failing spings to give you a little extra life out of the springs. I was simply attempting to have a little fun with this.
BrianBFD is offline
post #12 of 92 Old 12-15-2011, 10:40 PM
Indy
Indy's Avatar
Cut 4 pieces of 2*4 into desired length and install between axle and frame with a sledge hammer.
I'm the only gay eskimo.
Indy is offline
post #13 of 92 Old 12-16-2011, 03:46 PM
attentionwhore
photoshop
attentionwhore is offline
post #14 of 92 Old 12-16-2011, 03:51 PM
1HouseMouse
3-D Specs!
1HouseMouse is offline
post #15 of 92 Old 12-16-2011, 03:58 PM
merckx9
Why bother?
When I was 20 I knew everything, when I was 30 I knew something, at 40 I know nothing!
merckx9 is online now
Removing diff gaskets. . .any tips or tricks to make it easier??? atomicjoe23 Engines & Drivetrain 11 04-24-2012 04:05 PM
Just got first jeep, Any tips,tricks i should know Skytard Cheap Tricks & Fixes 35 04-26-2011 01:03 PM
my first jeep! cool tricks?? 04TJrubicon Cheap Tricks & Fixes 8 06-02-2009 02:33 PM
What it takes to make a Lifted 4x4? '93Jeep General Jeep & Off-Road Equipment 3 12-03-2007 09:35 AM
