Air intake - JeepForum.com
post #1 of 9 Old 10-16-2013, 08:40 AM Thread Starter
1999jeepxj98
Air intake
What do i need to make a cold air intake for a cherokee?
1999jeepxj98 is offline
post #2 of 9 Old 10-29-2013, 02:07 PM
misfit77
too many options. I would google image seatch.
I tried various version, the one i liked the most is running a tube from the hood cowl to the oem air box.
I did something like this
Scepture makes one that is a little above $100.
misfit77 is offline
post #3 of 9 Old 11-01-2013, 06:04 PM
holysirsalad
+1 DIY cowl "snorkle". Retains the large filter area of the stock filter, gets you cold, dry air, and is very cheap.
holysirsalad is offline
post #4 of 9 Old 11-09-2013, 11:48 AM
whiskytango785
1994 XJ Cherokee
I keepgetting water in my airboxhow did you seal the factory lid?
whiskytango785 is offline
post #5 of 9 Old 11-09-2013, 01:20 PM
holysirsalad
Have you done the cowl snorkle mod? The stock air box has a bunch of drain holes in the bottom.
post #6 of 9 Old 11-10-2013, 09:59 AM
whiskytango785
1994 XJ Cherokee
Not yet because because my filter keeps getting wet. Im not sold on cutting into the cab because if the air box fills with water through the drain holes what am I gaining? would I be better off elimnating the airbox?
post #7 of 9 Old 11-10-2013, 10:12 AM
holysirsalad
So you're on the stock setup? What are you doing when the filter gets wet? Getting the Jeep in water up to the headlights or driving in the rain or river crossings or what?
The cowl mod does NOT draw air from the cab. The cowl is a separate plenum attached to the firewall. Generally one seals the airbox after doing this.
post #8 of 9 Old 11-11-2013, 10:01 AM
whiskytango785
1994 XJ Cherokee
We like to get on train tracks and see where they go and most of the bridges are gone so crossing a creek is pretty common the water never goes above the hood line so it has to be comeing from the bottom of the box
post #9 of 9 Old 12-21-2013, 05:52 PM
SmitsXJ
I have a kn system i will sell you. PM me
SmitsXJ is offline
