Air and Heat won't blow! Fans turn on! - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Cheap Tricks & Fixes > Air and Heat won't blow! Fans turn on!
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineWIN a Rough Country Forged Track Bar - ExtremeTerrain!1987-2016 Wrangler Jammock Black 2.0 Jeep Hammock (YJ, TJ
Unread 03-04-2013, 12:16 PM   #1
IHatemyJeep4lfe
1993 XJ Cherokee
I a have seen endless amount of post on this. I am going to set my Jeep on fire if I can't figure this thing out. I have a 1993 Jeep Cherokee 4.0 4x4, green POS. When I turn the a level controls up and down nothing happens. No air no heat, but I can hear the fan engaging. I changed the resistor a few months ago because the controls only worked on level 2 and high. After changing it they still only worked on 2 and high. I have looked for vacuum leaks and all the fuses are good.
The Jeep is the bottom of the line model everything manual, no cruise, no ABS. Please help I have tried eveything! Thank you guys very much in advance!
IHatemyJeep4lfe is offline   Reply With Quote Quick reply to this message
Unread 03-07-2013, 05:07 PM   #2
Indy
If the fan is running but no air is coming out of the vents it would likely be a stuck diverter.
I'm the only gay eskimo.
Indy is offline   Reply With Quote Quick reply to this message
air conditioner , fan setting , heater , wont engage
