ABS light came on whats wrong - JeepForum.com
post #1 of 9 Old 12-01-2011, 05:49 PM Thread Starter
jeepgirl1321
after a slight trail ride in my jeep the abs light came on next time i started the car. and it wont go off...help..
jeepgirl1321 is offline
post #2 of 9 Old 12-08-2011, 12:51 PM
xjmatt720
your brakes is what is wrong. but get down and into your brakes with a high pressure hose. sometimes mud. snow or sand gets in the sensor and there is no actual problem. especially if you were spinning your wheels alot.
xjmatt720 is offline
post #3 of 9 Old 12-08-2011, 01:14 PM
Jacobite
1990 XJ Cherokee
My ABS started going out a couple months ago. At first braking was kinda scary, but now that the ABS is completely gone the brakes work pretty good, except I need new pads. I plan on replacing with standard power brakes. Never liked the ABS.
Jacobite is offline
post #4 of 9 Old 12-18-2011, 09:04 AM
BandGauto
Most likely a wheel sensor. Have someone with a scanner that reads ABS plug into OBDII port under the dash and it will tell you which wheel sensor is at fault.
BandGauto is offline
post #5 of 9 Old 12-29-2011, 07:37 PM
Griff1918
Wheel speed sensor. Check for mud, loose or broken wire.
Griff1918 is offline
post #6 of 9 Old 01-02-2012, 08:43 AM Thread Starter
jeepgirl1321
yeah thats what i believe it iss! thankss
post #7 of 9 Old 01-03-2012, 03:15 PM
Spiffums
I have had the light on my Explorer for years. Apparently the only thing to do is take the bulb out...... both times I have had it "fixed" this is what they did.
Zombie Outbreak Response Unit
Spiffums is offline
post #8 of 9 Old 01-03-2012, 03:59 PM Thread Starter
jeepgirl1321
well i cheaked my senores and i think the one on my drivers side is broken but there pricy to replace /:
post #9 of 9 Old 01-03-2012, 11:59 PM
Griff1918
Just for the part, cause its easy to install
whats wrong with my cb... Unii Audio, CB & Ham Radios, GPS, & Electrical 1 04-27-2010 03:55 PM
not sure whats wrong with the I6 lovesa02wj Engines & Drivetrain 2 07-25-2009 01:18 AM
whats wrong with my winch? FritzTJ General Jeep & Off-Road Equipment 5 06-11-2009 04:52 PM
whats wrong with my radio??? whitefiesta Audio, CB & Ham Radios, GPS, & Electrical 5 02-27-2009 04:19 AM
whats wrong with this setup gumby General Jeep & Off-Road Equipment 2 10-04-2004 03:42 PM
