99 TJ Battery problems - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Cheap Tricks & Fixes > 99 TJ Battery problems
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineJeep parts, deals and more at JeepHut.comTJ BDS 2" suspension lift!! FINALLY a GREAT 2" l
Unread 03-18-2015, 12:21 PM   #1
eldanimal
I roughly cleaned my corroding terminals on Sunday to fix a sluggish start. It worked for two days. Last night I had to hit the throttle to turn the engine over. This morning the battery was dead, and I was unable to jump it.
I was unable to get the positive cable off the terminal and will try again tonight, but it was strange that everything worked for the first two days and then nothing.
The only thing I can guess is that the battery acid wasn't fully neutralized before I rinsed it off and it got into something else.
I really appreciate any advice.
eldanimal is online now   Reply With Quote Quick reply to this message
Unread 03-21-2015, 01:21 AM   #2
OMNIMAN
Junior Member
OMNIMAN's Avatar
How old is the battery?
I'm not your buddy, friend !
I'm not your friend, Pal !
I'm not your pal, buddy !
OMNIMAN is offline   Reply With Quote Quick reply to this message
Unread 03-21-2015, 01:26 AM   #3
OMNIMAN
Junior Member
OMNIMAN's Avatar
One time about a year ago my battery kept dying. I got a new battery... after a few days it was dying again. Checked and recheck ed everything twice. Everytime i would go more than a day without driving my battery was dead. After a few months i got under the jeep looked up and realized that my under the hood light was activating when the hood was down and off when it was up. Finally cut the thing off and my battery stopped dying. Everything has been good ever since.
Unread 03-27-2015, 02:38 PM   #4
eldanimal
It turns out I DEFINITELY did not clean my terminals well enough. I think that I loosened up the corrosion enough to work, but without removing it all it reset between the terminals and the posts.
Redid the job right and everything worked without a jump. Thank you both for the help.
