95 wrangler no high beams - JeepForum.com
post #1 of 5 Old 02-12-2013, 10:10 PM Thread Starter
jaws2167
ok so im new to this site and trying to seek some advise. alright so my jeeps low beams work fine but i have no high beams just got around to replacing both headlamps, all the grounds and wires are in good shape but when i go to use the lever(it clicks btw) nothing happens the high beam indicator on the dash also does not come on all the other lights work fine as they should any tips tricks i should try? im at a dead end
95 jeep wrangler rio grande 2.5L 5 speed
jaws2167 is offline
post #2 of 5 Old 02-14-2013, 03:59 PM
ToothlessJoe
Have you checked the actual lever or switch connecting to the steering column? I had a similar issue on my TJ, and it just turned out that when I moved the lever towards me, it wasn't engaging completely.
ToothlessJoe is offline
post #3 of 5 Old 02-14-2013, 06:47 PM Thread Starter
jaws2167
thanks for the tip ill give it a shot then ill let you know if it works
jaws2167 is offline
post #4 of 5 Old 02-14-2013, 07:01 PM Thread Starter
jaws2167
so i took a look under the dash at the steering column i found the switch and i pulled on the lever and it moved as it should it seemed but i did notice that there is nothing pluged into it. should there be a plug there? i believe i saw three prongs inside the switch. i looked around i didnt see anything to plug into but i will look again any ideas?
jaws2167 is offline
post #5 of 5 Old 02-14-2013, 07:30 PM Thread Starter
jaws2167
ok i found the problem turns out the P.O had the pigtail all taped up and hidden in there i did find it and it had wired connected to it seem like he had an idea to power some type of aux light source after i took all of his mistakes apart cleaned it up a bit plugged it in and it works!! i have my high beams now what a great feeling thanks for the help lol!!
jaws2167 is offline
headlamp , high beams , low beam
