$7 In Cab Winch Controls - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Cheap Tricks & Fixes > $7 In Cab Winch Controls
Spartan Locker Promo Running now @ ROCKRIDGE 4WD plus FREEYukon Ultimate 35 axle kit for c/clip axles with Yukon ZipNitro Gear Packages Now Available at Rockridge 4wd
Unread 05-15-2012, 12:19 AM   #1
Anticanman
Follow me
Anticanman's Avatar
I don't know if this has been mentioned here or in the electrical section but I figured it's at least one of the correct sections to give this a try so here goes:
I'm going to be basing this quick write up on the smittybilt xrc winch platform and from what I've seen they're pretty similar inside the solenoid box. I know most people despise these winches or the company altogether so I'll tell you that this review from here on out isn't for you. Keep in mind for those that are following along, I didn't take many pictures because I figured it out pretty quick. And it was really hot in the shop. Ok. Parts list:
Three feet of 14 gauge wire
Three butt connectors that would fit 10 gauge wire
Three female spade connectors
Three male spade connectors (preferably shielded)
One smittybilt #97203-31 (replacement handlebar controller for xrc 3.0 winch)
One drywall screw about 1.5" long
Some zip ties for cleaning up your wiring
I started with the hand control piece itself and cut the proprietary end off the winch side exposing the three wires and mounted the toggle section inside the cab with the drywall screw. Found a nice little nook for it to go
Next I routed the wiring through the engine bay toward the bumper where the winch is mounted. Pretty simple.
Then after opening up the solenoid cover I tapped into the wired that the remote control uses on the inside of the cover itself. There are two red wires on my particular model and one black wire. The black was the constant hot because I could trace it to the power bus and the two reds were a guessing game, really.
After pulling leads out with the butt connectors, I attached the shielded spade connectors to the ends of the leads. The wires that came from the toggle switch are as follows:
Red-power
Black-out
Green-in
The spade connectors made it easy to line up the colors because I knew the power wires were clear and the in/out situation was just seconds of trial and error.
I was careful to reinforce the connection to the plug and ultimately to the winch itself. As it was my first go at this project, I used crimp connectors but I will eventually solder the connections to make it a little more permanent and stable.
That's pretty much it. A five dollar switch and a couple bucks in wire and connectors. Well, assuming you don't already have them sitting around. Here is a pic of the switch in its virgin form:
Luck Favours The Prepared
[SIGPIC][/SIGPIC]
Anticanman is offline   Reply With Quote Quick reply to this message
Unread 05-15-2012, 12:51 PM   #2
dagr8tim
dagr8tim's Avatar
1997 XJ Cherokee
Red-power
Black-out
Green-in
That's pretty much it. A five dollar switch and a couple bucks in wire and connectors. Well, assuming you don't already have them sitting around. I hope to take a picture of the extra switch I have tomorrow so you know where I started and to give you a better idea how to mount it in your jeep.
Looks good, I'd do the connectors up in heat shrink tube for extra protection.
Jeeping - The art of getting dirty & going broke while slowly heading nowhere, and taking all day to do it.
97 XJ SE - DD/Light Trail Rig - The War Wagon
75 CJ5 with a badly chopped CJ7 Tub - Pandora
96 Land Rover Discovery - Black Dog; possible trail toy
dagr8tim is offline   Reply With Quote Quick reply to this message
Unread 05-15-2012, 12:57 PM   #3
Anticanman
Follow me
Anticanman's Avatar
I'm going to solder them next week
Thanks!!!
[SIGPIC][/SIGPIC]
Unread 05-18-2012, 04:16 AM   #4
shadowulf
Pretty cool. I'm trying to figure out a way to mount a electric lock switch in the center gauge section to do the same thing. As soon as I have enough days off in a row to start/finish it. ( I'll also clean and "white skin" the gauges at the same time)
shadowulf is offline   Reply With Quote Quick reply to this message
Unread 05-18-2012, 08:11 AM   #5
Burlbook48
Burlbook48's Avatar
Nice, clean, simple.
Have you thought about adding a main power off switch so the on/off/on control can't be turned on by an accidental bump or someone else touching the switch?
You have to start somewhere to get to the middle of nowhere.
Burlbook48 is offline   Reply With Quote Quick reply to this message
Unread 05-18-2012, 09:37 AM   #6
Anticanman
Follow me
Anticanman's Avatar
Thought about it but the guards that are on there prevent that in the position it's mounted. It would be easy to do though. Id like to we someone else do it and post pics.
[SIGPIC][/SIGPIC]
Unread 05-22-2012, 05:02 AM   #7
sitedzn
That's what I did with mine. Have a on/off toggle for power to the momentary in/out switch beside it.
88 YJ, 4.2L, AX-15, NP231[COLOR="Red"] w/ SYE[/COLOR], 3.5" RC lift, [COLOR="red"]1" booms[/COLOR]
[COLOR="red"]Cut down XJ shaft in rear
Ford 8.8 LS & Spartan Locked[/COLOR] D30
[COLOR="red"]Big Daddy Off Road rock sliders[/COLOR]
35x12.5 BFG A/T KOs, XRC-8000
[COLOR="red"]I love installing new stuff.[/COLOR]
sitedzn is offline   Reply With Quote Quick reply to this message
Unread 10-11-2012, 01:57 AM   #8
AmmitOsiris
I like your panel
AmmitOsiris is offline   Reply With Quote Quick reply to this message
