$6.00 Bumpstop Extensions - ZJ/TJ/Probably others :D - Page 2 - JeepForum.com
post #16 of 33 Old 11-13-2010, 08:39 PM
buckshot500
I just picked up a two pound rubber mallet ($6.00 at Northern tool). It measures about 4-1/2" from face to face.
I'm going to cut it in half & have one 2-1/4" spacer for each side. Of course I could use a whole one for each side or cut those down to 3" or whatever.
I'm sure I'll find a use for the left over handle.
Originally Posted by 5point1 View Post
Well after I drained the oil, I ran water through the engine to clean out the gunk. (the guy who owned before me obvioulsy didn't know how to maintain the engine).
90YJ98XJ
buckshot500 is offline
post #17 of 33 Old 11-13-2010, 10:16 PM Thread Starter
FPKites
ZJjazzyJim
FPKites's Avatar
That would work well.
The thing I like about hockey pucks is, with a little work, you can slip them in one at a time without needing to droop the axle or pull the spring. If you're already dropping the suspension though, a mallet head would work well.
Jim Karlin
"Duh! Big RED Jeep!!!"
or
96 ZJ Laredo
5" lift, Claytons, KOR radiator support, rear bumper, steering brace, etc, etc, etc.
04 WJ Overland
Clean.... :D
FPKites is offline
post #18 of 33 Old 11-15-2010, 08:22 AM
Area.3.Fiftyone
What the "puck"?
I've heard of them being used for body lifts, but never this.
Good idea.
I'm building up a trussed HP30 and will be going with something like this:
At about $87 it's s lot more money than your $6.00 fix.
79' CJ7 - 82' CJ8 - 94' YJ - 96' ZJ
Diagonally parked in a parallel universe.......
Area.3.Fiftyone is offline
post #19 of 33 Old 11-15-2010, 06:08 PM Thread Starter
FPKites
ZJjazzyJim
FPKites's Avatar
As far as bumpstops go, I haven't ever had a problem - if it clunks, it's not as noisy as my other ones, so I don't ever hear it
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
post #20 of 33 Old 11-15-2010, 09:19 PM
DoctorTim
this thread is genius. Any ideas for a leaf spring cheap bumpstop?
96 XJ, geared, 8.8, 5", 33s, dash
DoctorTim is offline
post #21 of 33 Old 11-16-2010, 05:48 PM Thread Starter
FPKites
ZJjazzyJim
FPKites's Avatar
Rubber mallet head comes to mind - pucks would work too. Been a while since I looked at leaf spring bumpstops - are they bolted in?
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
post #22 of 33 Old 11-16-2010, 06:43 PM
DoctorTim
not sure, I'll check and post later.
post #23 of 33 Old 11-16-2010, 07:30 PM
dagr8tim
dagr8tim's Avatar
1997 XJ Cherokee
Square tubing and longer bolts? Replacement bumpstops are $9.99 at quadratec.
Original Replacement Parts 52002393 - 4.1" Rear-End Axle Snubber for 87-01 Jeep® Cherokee XJ (Bump Stop) - Quadratec
Here's my quadratec rear XJ bumpstops.
Originally Posted by dualtjs View Post
You can also get generic hard rubber feet for saws/drill presses/lathes etc from Northern Tool for $10 for a pack of 6. The are a little more that 2 1/2" in diameter and are predrilled with holes in the center. I'm using them in place of the tire stops on the tailgate of my TJ (factory stops are too thick to mount a 31" tire that's on stock wheels). They are slightly smaller than a hockey puck but should work.
I can't find the feet on their tool, do you happen to have a PN?
Jeeping - The art of getting dirty & going broke while slowly heading nowhere, and taking all day to do it.
97 XJ SE - The War Wagon
98 TJ - Mall Crawler/Light Trail Rig
dagr8tim is offline
post #24 of 33 Old 08-06-2013, 04:36 PM
chadcmb
why would you do this on a zj that wheels? wouldnt that stop the tire from tucking into the fender?
chadcmb is offline
post #25 of 33 Old 08-06-2013, 06:50 PM Thread Starter
FPKites
ZJjazzyJim
FPKites's Avatar
Wow - old thread
Extending the bumpstops keeps the tire from tucking through the fender
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
post #26 of 33 Old 08-09-2013, 10:06 PM
spdcat01TJ
Just buy rubber boat trailers at WalMart, and cut them to whatever thickness with a jig saw. Buy longer bolts, and space the cups down,
If guns kill people, then pencils misspell words, cars make people drive drunk, and spoons made Rosie O' Donnell fat!
NRA Member
'01 TJ Sahara, 3" BB front, 2.25" BB rear, 1.25 JKS BL, 1" MML, Skyjacker Hydro shocks,33/12.50x15 BFG TA/KO All Terrains homemade disco's, Hi-Lift, CB, GPS
spdcat01TJ is offline
post #27 of 33 Old 08-10-2013, 06:31 PM Thread Starter
FPKites
ZJjazzyJim
FPKites's Avatar
The biggest thing I like about using loose hockey pucks is when you're putting everything back together after replacing arms, coils, etc, and you have everything all buttoned up...until you look behind you and see your bumpstop extensions saying "Hey doofus! You forgot me!!"
A BFH and some muscle gets your extensions back in where you need them.
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
post #28 of 33 Old 03-19-2014, 02:51 AM
BROWNING3250CAL
I'm all about saving money and DIY where possible. Everyone says to jack it up and pull the springs, compress the shocks etc etc to figure out how much bump stop extension to add. There has to be a simple way of calculating this. I added a 2.5" budget boost to stock susp. and have 35" tires instead of 32" stock. Based on these numbers can anyone give me a good idea of how many 1" hockey pucks would be needed? I like simplicity what can I say... Also being lazy lol.
BROWNING3250CAL is offline
post #29 of 33 Old 03-19-2014, 08:09 PM Thread Starter
FPKites
ZJjazzyJim
FPKites's Avatar
I use a rule of thumb, don't know of any kind of fancy-schmancy calculator. Try to match the length of bumpstop extension to the amount of lift. After that, I carry some extra hockey pucks on the trail with me
Jim Karlin
or
96 ZJ Laredo
04 WJ Overland
Clean.... :D
FPKites is offline
post #30 of 33 Old 03-19-2014, 08:20 PM
BROWNING3250CAL
Makes sense. Thanks.
Bumpstop question tjbrotha Tires & Wheels 1 11-09-2007 11:00 AM
RE 3.5 ..Bumpstop Q's EG00TJ Tires & Wheels 3 08-30-2007 04:32 PM
How much bumpstop extension to run 35s on ...? planman Tires & Wheels 1 01-14-2007 11:59 PM
TJ cheap Brake line Extensions mike481 Cheap Tricks & Fixes 2 06-14-2006 01:13 PM
Rocky Road BB and BPE shock extensions Dtowncats Tires & Wheels 1 10-31-2005 01:30 PM
