2006 Jeep Wrangler Death Wobble - JeepForum.com
post #1 of 19 Old 09-23-2010, 09:37 PM Thread Starter
sdrasal
Has anyone heard of a 2006 Jeep Wrangler Death Wobble. It occurs after hitting a bump going between 40-50 miles per hour. Thought the problem was unbalanced wheels, had that taken care of a still does the shaking. Read somewhere that a owner had his steering damper replaced, and it fixed the problem for a little while. Any help anyone??? Thank you in advance for your input.
Steven
sdrasal is offline
post #2 of 19 Old 09-23-2010, 10:02 PM
NEI10
my '06 had death wobble. a front end alignment fixed it. is yours lifted? what size tires? what size & offset of rims? do you have a heavy duty bumper and/or winch? did you replace your pitman arm? give us more info on your rig.
2013 10th Anniversary Edition Rubicon
Jan/Feb '06 JP Magazine Cover
NEI10 is offline
post #3 of 19 Old 09-24-2010, 07:57 AM Thread Starter
sdrasal
Specs
Not really sure on the back spacing on the wheels, but the rims are 17" with 265 70 R17. No lift
Not custom front bumper
Did not change the pitman arm
Thanks for the help
Steven
sdrasal is offline
post #4 of 19 Old 09-24-2010, 08:56 AM
tymekeepyr
I had the same type of issue for a while.
It was almost bad enough to rip the wheel out of my hand.
After taking a good, hard look, I noticed that the front tires were "cupped". (lack of rotation on previous owner's AND my part)
I rotated front tires to rear and viola, problem solved.
tymekeepyr is offline
post #5 of 19 Old 09-24-2010, 05:57 PM
NEI10
i would have the front alignment checked and adjusted if needed.
NEI10 is offline
post #6 of 19 Old 09-24-2010, 06:32 PM
YellowX
YellowX's Avatar
You'll get better responses if you post this in the TJ Tech forum.
DW is typically caused by the trackbar needing rebuilding/replacing/tightening. Unbalanced tires, misalignment and seriously loose joints can also add to this.
Fred
JAFGJ
YellowX is offline
post #7 of 19 Old 09-25-2010, 04:42 PM
Ocean120
I have a 2006 TJ and had the same problem. I had the tires road force balanced and rotated and it stopped.
Ocean120 is offline
post #8 of 19 Old 10-12-2010, 08:15 AM
GSGZZLR
Mine was solved by a new steering dampener.
GSGZZLR is offline
post #9 of 19 Old 10-12-2010, 10:34 PM
Kevin925
Allignment straitened mine right out
Kevin925 is offline
post #10 of 19 Old 10-27-2010, 09:24 AM
codylalonde
Steven
i have a 1998 jeep wrangler and i had that same problem .. put new tired rides like a cloud if thats any help to you
codylalonde is offline
post #11 of 19 Old 11-04-2010, 07:56 PM
BBG-C5
Location: Observing from a distance taking copius notes.
Steering stabilizer.
BBG-C5 is offline
post #12 of 19 Old 11-06-2010, 03:49 PM
NEI10
steering stabilizers help, but most times it will just mask what could be something more, like a bent tire rod, tires/rims unbalanced, ****ed control arm etc.
check, and then double check all the hardware first, then get it aligned, and then add a steering stabilizer.
NEI10 is offline
post #13 of 19 Old 11-06-2010, 11:15 PM
Jeffjeep07
I had a wobble that was terrible with mine(97) a alignment and dual skyjacker steering stabilizers fixed it.
Jeffjeep07 is offline
post #14 of 19 Old 11-07-2010, 05:59 PM
Bigbob
Bigbob's Avatar
Check list:
1. Check alignment.
2. Check Tire balance and bent wheels
3. Check Track Bar bushing and rod end
4. Check control arm bushings
5. Steering stabilizer
Being you have the common 40-45 mph wobble if the rig is not wandering or pulling at other speeds your alignment is probably okay.
Jeep tires go out of balance all the time, but they are out of balance at all speeds, not just 40-45 mph
Track Bar bushings on the axle end are famous for causing DW. Also check the frame end for looseness. No play should be felt.
Control arm bushings can go out really quick if you ever hit the trails. Just a little play there is gonna give you the 40-45 mph boogie-wooky you have.
Don't spend fortunes on a steering stabilizer. Monroe makes one for 30 bucks that works great. Pep boys sells them. ST2928 part number IIRC But remember, the stabilizer is only a mask if you have other issues. Being you have a 5 year old Jeep just replace it.
Track Bar issues and ruined stock control arm bushings are the number one culprit. And absolutely a 2006 Jeep can get DW fast if any of those components are bad. Other issues that can cause it are the ball joints on your knuckles and the wheel bearings.
2006 Solar Yellow Rubicon Unlimited
Jeep Club Member #1340
6 Speed, Hardtop
Mods done: Hurst tee handle, cheap hand throttle, Rokmen Merc front bumper, Warn 9.5 TI winch with 3/8" X 100 worth of Viking yellow rope, DPG OME Ultimate with JKS ACOS up front, Kilby Gas Tank Skid, Kilby Steering Box Skid, Jeep Medic Belly Up, Skidrow Engine Skid, Rockcrusher Diff Skid in the rear, Warn Diff cover in front, , AR Outlaw II's and MTR 12:50/15's, Homemade rear Bumper, Cheap Cobra CB, Puma OBA, Sirius Radio, Locker Defeat, Rockhard cage, Rockmen short corners, homemade tire swing/tailgate hinge affair, Airlift air bags on the rear- - - - - - and more to come!
Bigbob is offline
post #15 of 19 Old 11-07-2010, 06:44 PM
flatlander757
NO NO NO!
Steering stabilizer NEVER IS and NEVER WILL BE a cause of death wobble. It's just there as a convenience to "dampen" the road feel through the wheel.
It may "fix" your wobble... temporarily but there is something else you are covering up.
I drove my Jeep on 40s with NO STABILIZER with no problems for over 1000 miles.
Because my front end is set up RIGHT and it is TIGHT.
Read this and get edumucated
http://www.jeepforum.com/forum/f9/en...ng-read-663777
SOLDThe lumbering steel-laden pig - 2003 TJ - 40" LTBs - D60/D70HD - 5.86s - Detroit lockers - 110" wheelbase
Originally Posted by 2006 Sport
Being able to make vroom vroom noises in Tonys Jeep was the highlight of my life.
Currently Jeepless.
flatlander757 is offline
2006 Jeep Wrangler Unlimited 4x4 Tire/Wheel Question badboytires Tires & Wheels 12 08-29-2011 11:20 AM
Jeep death wobble ... shadez1460 General Jeep & Off-Road Equipment 0 01-28-2010 05:16 PM
Death Wobble - 2006 Rubicon w/ 3" teraflex lift teflont General Jeep & Off-Road Equipment 1 11-03-2008 08:58 AM
2006 Jeep Wrangler X 4.0 4WD cdduffman Engines & Drivetrain 0 10-02-2008 12:23 PM
