1998 TJ Fuel Tank Skid Plate Bolt Issue - JeepForum.com
post #1 of 6 Old 08-02-2013, 03:55 PM Thread Starter
wmweiler
I have an issue trying to drop my fuel tank on a 1998 TJ. One of the seven bolts holding the skid plate on just spins when I try to loosen the nut. There doesn't appear to be any way to get to the head of the bolt. Any suggestions on what to do?
wmweiler is offline
post #2 of 6 Old 08-09-2013, 09:15 PM
JeepNicholson
Cut it or grind it off. Be careful and have a fire extinguisher ready!
Don't forget to put some anti-seize on the new bolt!
Also I believe the skid bolts are held in with nutcerts if that helps.
JeepNicholson is offline
post #3 of 6 Old 09-26-2013, 09:00 PM
Mporter22
You can try to put some downward pressure on the skid plate so that the spinning nut is getting pushed against the inside of the frame. Worked for me then I just never put the bolt back in when I was done
Mporter22 is offline
post #4 of 6 Old 09-27-2013, 09:22 AM
biffgnar
biffgnar's Avatar
Those are carriage bolts. Either the bolt base has rounded or the hole has rounded. Cut it off and you will have access to the top once you drop the tank. If the hole is rounded you'll have to address that before putting the tank back up.
Romney in 2020!
biffgnar is online now
post #5 of 6 Old 09-28-2013, 09:03 PM Thread Starter
wmweiler
Thanks for the suggestions. I'll give them a try and see what happens.
wmweiler is offline
post #6 of 6 Old 11-18-2013, 11:32 PM
DonBC
1989 MJ Comanche
I had a similar problem when removing the skid plate on my 89 Comanche. The nuts on two of the bolts into the boxed frame just spun when I tried to get them out. By wedging a couple of screw drivers between the bracket and the frame to force the nut against the frame I was able to get one bolt out. The second one I had to grind the head of the bolt off. Before I go the put the fuel tank and the skid plate back on I may try and weld the nut in place by screwing a long bolt in to hold the nut in place and welding around the edge of the hole in the frame.
DonBC is offline
