17mm alan key - JeepForum.com
post #1 of 4 Old 10-04-2004, 03:41 PM Thread Starter
bockwho
bockwho's Avatar
17mm alan key
I decided it was well past time to change my lube in the TJ with a standard trans. unable to locate a 17mm alan key at 3 differnt auto parts stores
I was able to find a 17 mm bolt and two nuts actually the bolt was off a old set of stock fog light mounts off my MJ and two nuts. Get you buddy with a welder to zap the end a bit and you my friend have a 17mm hex key. suitable to remove the drain and fill plug on a standard trans.
00 TJ Sport
96 XJ classic
65 corvair (if you don't know don't ask)
My Life is Hard
bockwho is offline
post #2 of 4 Old 10-06-2004, 06:33 AM
BamaJeeper
BamaJeeper's Avatar
Nice!
You are one resourceful sum*****. just testing the censor nazi program
Out of the darkness comes light.
BamaJeeper is offline
post #3 of 4 Old 10-06-2004, 10:12 AM
wyldejackyl
Welder? Just take two nuts and put them on a 17mm lug bolt (BMW/VW), and tighten them against each other. I've been doing this for years!
If you can't find two nuts, use a stud removal tool. It has teeth that'll dig into the side of the bolt.
Everyone needs a little ghetto!
..::2007 JK Unlimited X::..
1500W inverter
Midland 1001LWX CB
55/100W H4 Hella headlamp conversion w/ dual relays
wyldejackyl is offline
post #4 of 4 Old 10-06-2004, 02:48 PM Thread Starter
bockwho
bockwho's Avatar
i tried the two nuts ..but these have never been removed so i needed a little more toruq on them.. stud puller .. i have a few of those laying around not sure if every one else dose .. but that is a very excelent idea. of course once you break it loose for the first time the two nuts should work
kb
00 TJ Sport
96 XJ classic
My Life is Hard
bockwho is offline
