Quantcast $10 Quick Disconnects - Page 2 - JeepForum.com
Go Back JeepForum.com > General Technical Discussions > Cheap Trick & Fixes > $10 Quick Disconnects
GR8TOPS Introduces the Exogate HD Tire CarrierTruck-Lite's New LED Headlamp SeriesRUBICON EXPRESS Lift Kits and Accessories Available at Bas
Old 10-12-2009, 01:46 PM   #16
tonkaJP
i did this years ago. They weren"t on long. They were noisy so now i just unbolt them now when i wheel. Keep an eye on the parts they will wear down.
06 Khaki Rubicon Unlimited......work in progress
tonkaJP is offline   Reply With Quote
Old 10-12-2009, 02:32 PM   #17
hawk3ye
Take a look at the assembly before you attempt this, I think mine took a torx socket just to take off the OEM bolt holding this piece together. Oh yeah, use lots of WD40 to loosen that bolt up.
Once installed, I noticed they tend to make a lil more squeeky noises but that's about it...personally, I was a little paranoid and bought at least an extra set just in case they popped after a road trip to the OHV spots. I also just re-install my OEM bolts when I know I'm not going out wheelin' for awhile since I'd rather not have these homemade discos break on the freeway when i'm doing 80 on a turn or something, lol!
There is nothing worse than a brilliant image of a fuzzy concept. - Ansel Adams
Bay Area JP Club
hawk3ye is offline   Reply With Quote
Old 10-12-2009, 11:24 PM   #18
tarheelathlete1
not cool i did this and I look under my jeep today to check on them and great the passenger side is completely gone
"When you look good, you feel good, when you play good, when you play good you get the goods."
03 green TJ
tarheelathlete1 is offline   Reply With Quote
Old 10-13-2009, 10:18 AM   #19
DarksAlphas
Brake Lines
I was wondering if anyone knew if the brake lines need to be extended at all on an 08 X unlimited to use these "disconnects". I remember when I went to put disconnects on my 05, the brake lines needed to be extended. I would hate to be heading down a trail and find out I have no brakes.
DarksAlphas is offline   Reply With Quote
Old 11-25-2009, 11:32 PM   #20
tacweapon
Can you guys answer a question about this for me I am an XJ man but I have a buddy with a 03 TJ and we are going to be doing this on his Jeep my question is can this be done to the rear coils also or just the front ?
tacweapon is offline   Reply With Quote
Old 11-27-2009, 09:56 PM   #21
ClimbStuff
I looked at doing it to the rear, but never actually did... I've seen quite a few photos of rear springs popping out under full flex so I decided against it... but the rear sway bar is set up the same way and it could be done.
ClimbStuff is offline   Reply With Quote
Old 11-29-2009, 11:48 PM   #22
kking08
2010 JK Wrangler
i have a 4 inch RC lift with a 1 inch body lift, would these still work or not
kking08 is online now   Reply With Quote
Old 01-25-2010, 11:38 AM   #23
thetrashman
i know yjs better than tj's
but yeah its a very simple set up to do for any year with any lift.
with 5in's of lift its be a good idea. you might wanna pick up a new set for your tj.
quadratec sells them for lifter wranglers.
95' Little Red Yj.
"My Jeep Doesnt Leak, Its Just Marking Its Territory"
Mostly Stock,With A Few Things
My Build Thread
thetrashman is offline   Reply With Quote
Old 08-01-2011, 08:41 PM   #24
thrown_hammer
I just wanted to post I am going to have a couple 1/2" clevis pins turned down on a lathe to the .480" dia. Of the bolts. Also going to tig weld a washer on the head of the pin. I will post results when I get then done and deployed.
thrown_hammer is online now   Reply With Quote
Old 08-04-2011, 12:00 AM   #25
Netrix
Some brake grease might help with the squeaking.
Netrix is offline   Reply With Quote
Old 12-10-2011, 01:56 PM   #26
dreadsNropes
see i knew there was a way to do it. i took mine completely off. makes for some really fun street driving. hahaha. but offroad the flex is incredible for stock
dreadsNropes is offline   Reply With Quote
Old 12-11-2011, 06:14 PM   #27
Azzy
Kamen Rider
Azzy's Avatar
I wonder if heat treating the pins would help at all. Heat till red, quench in oil sort of thing. Or heat in charcoal, and case harden.
If the metal is viable for that.
My build and troubles thread: http://tinyurl.com/AzzysJeep
"It is my right to be uncommon—if I can. I seek opportunity—not security. I do not wish to be a kept citizen, humbled and dulled by having the state look after me..." - Dean Alfange, An American Creed
Azzy is offline   Reply With Quote
Glock Forum
