| Rough Country TJ Belly Pan Skidplate Giveaway - NEW PRODUCT RELEASE |
| Best place to buy Rubicon Express! Don't Fear the Jeeper! | Insane Rough Country Deals Call for more Info!!! so insan | Barnes 4WD Universal 4 Link Kit |
| Jeep Registry | Register | Blogs | FAQ | Mark Forums Read | Search Members |
LinkBack | Thread Tools |
#1 | ||
$10 Quick Disconnects
#2 |
Y2KXJ
wow, great budget option for discos!
WARNING - The above post may contain trace elements of biting sarcasm. Those with known sensitivities should avoid staring directly at it. My fiancee wants to know where she can buy Jeep-scented perfume, so I will pay more attention to her. |
#3 |
Stupid newb' question here, but you just install the quick disconnects on the bottom only? Or at both the top and bottom? Just wondering if that sway bar link (or whatever it's called) just hangs there when disconnected, or is totally removed.
thx. |
#4 |
I run this same setup. It has been around for awhile. Great alternative to disconnects.
Trikebubble- you only do the bottoms. Then you pivot the sway bar up and attach it somewhere or else it will get in the way and hang down. I just swing it up and hold it with a few zip ties. |
#5 |
Im doing this hopefully this weekend, thanks I havent seen this before
#6 | |
#7 |
To the originial poster, is it just me or is your tie rod bending? Might just be the angle of the pic but once those start to bend they aresupposed to be like a paper clip. Just sayin.
A note on the dissconnects. I have been running them for about a year now. Before you install, go to home depot and get some various thickness washers so that you can shim the space between the hitch pin and the disconnect. Otherwise it will be loose. I also recommend picking up a few extra hitch pins just to be safe. I have had a few get bent on me. |
#8 | |
Here's the video of the bending... |
#9 |
Anyone done this on a 95 YJ?
I plan to do this on my 03 Sunday, my son has a 95 YJ hoping to do a homebrew disconnect job for him -- any catches?
#10 | |
Its easily done in 10min time. |
#11 |
#10 Quick Disconnects
Thanks ClimbStuff! Appreciate the response - I will post up when we do the the 2 Jeeps, guess I'll do the Daughter's 02 when she gets home from College in the spring also --- good stuff,
#12 |
awesome! i need these
#13 | |
Shellback
Original writeup-4x4xplorer.com
U.S. NAVY JEEP HULL # 980
GEAUX TIGERS P.S. The plane will fly! |
#14 |
2 quick newbie questions.
1. Do these rattle at all when driving on the street? 2. Can I use the bolts off of the front to replace my rear sway bar bolt? One of my rear ones siezed on and have to cut it off. . Thanks |
#15 |
Mine do not rattle at all, or at least not enough to hear. I do shim them with various size washers though. As far as the bolt, I am not 100% positive but I am pretty sure the rear bolts are smalled in diameter than the front. Just run to home depot or lowes and pic up a new bolt.
One pointer to the guys wanting to do this. I have found it better if you run it the opposite way as it is set up in the picture. Have the retainer pin on the other side of the axle mount thing. Kinda hard to describe but if you look in the picture at the top of the page how the clevis pin and retainer pin are, if you swap it you will have less problems. My main issue is that the retainer pin can sometimes get bent up on the side its on in the picture and that makes the quick dissconnects not so quick. |
| Thread Tools | |
| Thread | Thread Starter | Jeep Forums | Replies | Last Post |
| Quick Disconnects | MDcracker | General Jeep & Off-Road Equipment | 7 | 03-13-2008 09:02 PM |
| quick disconnects | snakester14 | Tires & Wheels | 26 | 07-11-2007 09:09 PM |
| quick disconnects | tjboy | Tires & Wheels | 1 | 03-04-2005 07:34 PM |
| Quick Disconnects | blackrubi | Tires & Wheels | 6 | 08-01-2004 07:27 PM |
| quick disconnects...yes or no | idcx3 | Tires & Wheels | 3 | 06-11-2003 08:54 AM |
Jeep, Wrangler, Cherokee, Grand Cherokee, and other models are copyrighted and trademarked to Jeep/Chrysler Corporation. JeepForum.com is not in any way associated with Jeep or the Chrysler Corp. |
