WJ Tube Doors Now Available! - Page 3 - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > WJ Tube Doors Now Available!
Only 2 Days left to win $3,800 Jeep Parts!Count Down to KOH Sale!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 04-08-2013, 01:36 PM   #31
MGDWJ
can you ship these out unwelded? i really like them but im a cheap bastard
WJ build thread.
MGDWJ is offline   Reply With Quote Quick reply to this message
Unread 04-12-2013, 12:07 PM   #32
QuadraTokn
1930 WJ
Originally Posted by wickedliljeep View Post
Are the WJ door tubes still available?
Yes. Please PM us and we'll get you a shipping quote and build times.
Originally Posted by bmcasler View Post
Do you guys have any plans on making a tube hatch replacement as well? Something with a tire carrier possibly?
A tube hatch would be nice, but the research we've done tells us that the hatch plays a role in the uni-body's integrity. We don't want to be messing with that.
Originally Posted by rooster51 View Post
Good question, for ZJ as well. But without said tire carrier, that's ridiculous.
What about a tire carrier on the bumper?
The welding is the easy part. Would you want to buy just the bent tubes and the rest of the pieces and do all the trimming, welding, and notching yourself?
QuadraTokn is offline   Reply With Quote Quick reply to this message
Unread 04-12-2013, 09:58 PM   #33
richard_stryker
I don't like the idea of the tube clamp for mirrors. I want to get these doors for my fiances jeep. Would you be able to make a mount so i can use Harley mirrors like i do on my LJ?
richard_stryker is offline   Reply With Quote Quick reply to this message
Unread 04-13-2013, 08:05 PM   #34
MGDWJ
yes that will work for me i have a notcher and can do the trimming and welding.
WJ build thread.
Unread 04-15-2013, 10:09 PM   #35
QuadraTokn
1930 WJ
Sure! After you purchase the doors I will get the measurements and the necessary metal, no problem.
Send us a PM and we will figure out a price.
Unread 04-19-2013, 02:03 AM   #36
Russell84
2003 WJ
Any chance these doors could use the factory hinges and just slide in like the YJ/TJ/JK doors? I'd be fine with drilling out my hinges for a slide in version for easy swapping. Or even aftermarket hinges that can be used for both factory and tube doors.
-Rusty
2003 WJ Overland 4.7 HO, Clayton Long Arms, Teraflex 4.5" coils, JKS adj trackbar, JKS Quicker Discos, 17x9 Eagle Alloy Series 185, 285/70/17 BFG KM2, cut fenders/bumpers
Russell84 is offline   Reply With Quote Quick reply to this message
Unread 04-19-2013, 11:53 PM   #37
QuadraTokn
1930 WJ
I would love to but there's not enough interest at this time. I designed a hinge but I would need to redesign the doors. I'm not aware of anything aftermarket that would work.
Sent from my phone using JeepForum
Unread 04-23-2013, 12:07 PM   #38
Russell84
2003 WJ
That's a bummer. I can only do tube doors if I can swap them out 1)by myself and 2)in less than 15 minutes.
-Rusty
Unread 04-23-2013, 12:12 PM   #39
QuadraTokn
1930 WJ
Well you're in luck because it takes about 10 mins per pair, after the initial install. It takes me less than that because I don't have door checks and I use half of the bolts/nuts.
Unread 04-23-2013, 02:54 PM   #40
Russell84
2003 WJ
How do you take the factory doors off by yourself? Need someone to hold them up while you unbolt the hinges, don't you? And the door wiring harness is kind of a PITA to disconnect with it behind that rubber boot. I'm not doubting you, just curious. I've never actually pulled my doors off. Can you not just drill the factory hinge pins out and use quick release pins in their place? Then just get another set of factory hinges from a junkyard to use on the tube doors?
-Rusty
Unread 04-24-2013, 04:20 PM   #41
QuadraTokn
1930 WJ
It's much easier with a second person. By yourself, simply unbolt everything except for the top most bolt, roll the window down, then hold the door in place with one hand while you remove the last bolt with your second hand (it's not heavy since the studs are holding the door up within the hinges). Then use both hands and remove the door by pulling the studs out and away from the hinges.
As far as the wiring, this is taken from our installation instructions: "Pinch the top & bottom of the rubber boot at the door and pull the connector out of the door. Slide the red pin on the connector over, squeeze the release tab, and pull the connector apart." Send us your email and we will send you a copy.
Your idea for the hinges could be implemented, but we went with a design that doesn't require any additional work for the customer. Plus, the added cost would make the doors too expensive.
Unread 04-30-2013, 02:44 PM   #42
mrJ
2002 KJ Liberty
sample
Build In Progress...[url]http://www.jeepforum.com/forum/f22/03-wj-limited-build-she-needs-name-1113549/[/url]
It's a Jeep, it's not supposed to work right all the time.
Live in Florida? Check out Florida4x4.org!!!
mrJ is offline   Reply With Quote Quick reply to this message
Unread 05-05-2013, 06:49 PM   #43
Russell84
2003 WJ
Could the doors be ordered without the angle iron or hinges so I could fab up my own hinge system? I want to modify both the factory doors/hinges and the tube door hinges so that they can slide into the hinges like Wrangler doors. How much would the doors run if I were to order them like that?
-Rusty
Unread 05-05-2013, 08:53 PM   #44
misfit4lo
Beautiful! You guys make any bumpers?
misfit4lo is offline   Reply With Quote Quick reply to this message
Unread 06-23-2013, 10:50 AM   #45
ayycharlay92
are these for permanent installation or am i still able to swap back and forth with my stock doors?
ayycharlay92 is offline   Reply With Quote Quick reply to this message
