WJ Grand Cherokee Bolt in Dana 60 - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > WJ Grand Cherokee Bolt in Dana 60
Rough Country Jeep Suspension Deals at Rockridge 4WD!Nitro Gears now available in stock at JeepHutOnly 2 Days left to win $3,800 Jeep Parts!
Unread 12-15-2010, 04:26 PM   #1
ECGS
Vendor
ECGS's Avatar
THE ULTIMATE WJ GRAND CHEROKEE REAR AXLE SWAP
BOLT IN - DANA 60- 35 SPLINE CHROMO AXLES-ABS COMPATIBLE-ACCEPTS FACTORY BRAKE COMPONENTS
Built to your specs here! http://eastcoastgearsupply.com/i-616...-assembly.html
Benefits:
*Ring and Pinion Dana 60- 9.75" vs JK44- 8.89, D44a- 8.5, D35- 7.6
*Huge Pinion Bearings, Carrier Bearings, and Spider Gears found in 1 ton axles
*Big Set 20 Axle Bearings rated for double the load rating of SET 10 found in JK 44, TJ 44, and the SET 9 axle bearings found in WJ D44a and D35 factory axles.
*5x5 or 5x5.5 double drilled 4340 Chromoly 35 Spline Shafts 1.5" Diameter- the ultimate upgrade shafts come standard
*Uses your stock Coil Spring Isolators to give you a smooth quiet factory ride and has incorporated bump stops
*The upper truss is 1/2 inch plate w/ additional lateral supports, threaded for upper link mount and uses lock nuts to insure it never comes loose.
*The Lower Control Arm Brackets are 1/4 Inch and will accept your factory Arms, or aftermarket, sway bar mounts and shock mounts are installed in factory
*locations with hardware included.
*All our production axles are welded in a solid mount jig to insure proper fitment
All these added features and still ABS compatible and E-brake compatible.
THE ULTIMATE WJ GRAND CHEROKEE FRONT AXLE SWAP
Built to your specs here! http://eastcoastgearsupply.com/i-735...-assembly.html
Benefits:
*Ring and Pinion Dana 60- 9.75" vs JK44- 8.89, D30- 7.5
*1 TON balljoints, wheel bearings, Tierod ends, and Brakes
*35 Chromoly shafts 1.5" Diameter- Big 806x joints
* Ability to run lockouts and Chromoly U-joints for ultimate strength
*The upper truss is 1/2 inch plate w/ additional lateral supports, Bolted and welded to housing
*The Lower Control Arm Brackets are 1/4 Inch, sway bar mounts and shock mounts are installed in factory locations
NOTES:
** Front axle only requires a 6 inch Lift, Radius arm link systems such as clayton kit or other may require upper link to be moved inch on lower link to allow for yoke clearance.
** Front axle is not ABS compatible (However tying rear ABS signal to front Input Signal does eliminate dash lights)
** Lug pattern is 5x5.5 , 6x5.5, 8x6.5 do to the large size of a dana 60 hub a 5x4.5 or 5x5 wheel will not fit over the hub. If you want to truly upgrade your axle to larger ujoints one of the largest failure points of D30 and D44 this is the only option.
Differential Sales & Service
Quality Gears, Lockers, Axle Shafts, and other drivetrain products at a fair Price
http://www.eastcoastgearsupply.com
919-672-2705
ECGS is offline   Reply With Quote Quick reply to this message
Unread 02-02-2011, 09:35 AM   #2
rcking323
rcking323 is offline   Reply With Quote Quick reply to this message
Unread 06-23-2011, 07:24 PM   #3
WJwheelin
X2
How wide is the axle? has it been cut down to the WJ width?
I looked on the website and I didn't find any specs on the dimensions
WJwheelin is offline   Reply With Quote Quick reply to this message
Unread 06-23-2011, 07:40 PM   #4
Nick
2006 WK
I want one.
Ummmmm. If you guys need a WJ to prototype on.....
2001 WJ | 4.7L V8 | Utah Jeepcrew #19 | Hemi Club Member 60
1990 White XJ Laredo [Sold]
2000 Silverstone XJ Classic [Sold]
2006 Dodge Charger RT Hemi [Sold]
2001 Jeep Grand Cherokee [Current]
Xbox Live gamertag: XJ Nickk
Originally Posted by DcMuff View Post
Banned for being the cooler Nick
Nick is offline   Reply With Quote Quick reply to this message
Unread 06-23-2011, 08:11 PM   #5
rcking323
i want a front one soon! lol
Unread 06-24-2011, 06:10 PM   #6
ECGS
Vendor
ECGS's Avatar
WJ 60 AXLE is factory width or your desired width.
The Front is coming we are finishing up bracket kits and getting the brakes squared away. We should be able to release the front in 30-60 days and have fast lead times after that. Anyone ready to pull the trigger for the test dummy locally should contact us. Otherwise my wifes bone stock WJ is going to be way over built; she is already sporting the rear 60.
We are very excited about the front and we think WJ owners will be too when they see the price.
919-672-2705
Unread 06-26-2011, 02:28 PM   #7
cj777
1977 CJ7
Any plans for bolt-in 60s for TJs?
Wanna cracker?
'74 CJ5
'81 CJ7
'03 TJ
cj777 is offline   Reply With Quote Quick reply to this message
Unread 06-27-2011, 06:49 AM   #8
ECGS
Vendor
ECGS's Avatar
The TJ front 60 will be released at the same time as the only difference will be the brackets. Both bracket kits are being developed together. We are hoping the TJ kit will be finished today.
919-672-2705
Unread 06-27-2011, 09:22 AM   #9
Diehard
Diehard's Avatar
What lockers are compatible/available with/for this?
2004 GC Spec. Edit. V8 4x4 Quadra-Trac II. Bright Silver Metallic Clear Coat, 4" lift, RE shocks, adj. JKS CAs all around, 265/75/16, 10 ply., Maxxis Bighorns, ProtoFab winch bumper, Vortex 10,000 lb. winch, dual OME steering stabilizer, Rockyroad rockrails, skids, JKS Discos. Addco front & rear sway bar, & Aussie locker. Next year? : Rear bumper with tire carrier.
Diehard is offline   Reply With Quote Quick reply to this message
Unread 06-27-2011, 02:08 PM   #10
cj777
1977 CJ7
If you need a test dummy for the TJ kit, I'm up for it.
Wanna cracker?
'74 CJ5
'81 CJ7
'03 TJ
Unread 06-27-2011, 09:48 PM   #11
GraKee99
Rapist Wit
GraKee99's Avatar
I would test the WJ axles but I'm not local. I can give them a good test though. I would also need a payment plan.
Happy to be a guinea pig though.
Brian
WJ, WK, CJ5
GraKee99 is offline   Reply With Quote Quick reply to this message
Unread 06-28-2011, 03:52 PM   #12
MountainMan864
Whats the point of 60s in a grand cherokee when you gotta chop it to death and lift soo much to fit tires necessary for 60s? GC= luxury not rockcrawler.
MountainMan864 is offline   Reply With Quote Quick reply to this message
Unread 06-28-2011, 04:21 PM   #13
rcking323
I love how these comments only seem to come from people that have lightly or not modded wranglers with your superiority complex. You have to remember that the V8 HO in a WJ has ALOT more power than your 4.SLOW, therefore, where it may be safe for you to run a certain sized tire with a such and such axle, we would need stronger axles for the same tire size
Unread 06-28-2011, 04:44 PM   #14
ECGS
Vendor
ECGS's Avatar
B/C the D35 or D44HD are not up to the task of being under a Grand in stock form. We repair them all the time for dealerships and private individuals that have nothing to do with offroading.
Add 33's or 35's and they are a time bomb. Or the stock V8 w/ trailer hitch and small boat and your asking for problems.
So what is the solution......... A regular dana 44 is still barely up to the task, and it is nearly the same cost as a 60.
I personally like having leather, A/C, and ARB 60's in my luxury vehicle but thats just me!
But dont worry the TJ 60 will also be released.
919-672-2705
Unread 06-28-2011, 06:18 PM   #15
GraKee99
Rapist Wit
GraKee99's Avatar
Don't forget my comment, ECGS!
AndMountainMan864, who says you can't have both luxury and crawl? Guess I never got the memo.
Brian
WJ, WK, CJ5
