WIRED HDH Flat Switch Panel (8 Switch) FSP series - Programmable - MADE IN THE USA - JeepForum.com
post #1 of 7 Old 10-19-2012, 03:54 PM Thread Starter
Rockridge4WD
Vendor
Rockridge4WD's Avatar
2010 JK Wrangler
WIRED HDH patent pending Flat Switch Panel (FSP) is the easiest, most versatile switch panel on the market today! No thicker than a credit card, a footprint smaller than a dollar bill, flexible, and programmabe makes our line of switch panels the best for ANY application!
Being programmable, the FSP series gives you options on how to control any of your accesories. No other panel on the market gives you so many features straight out of the box!
Key Pad: Eight programmable buttons in a single membrane key pad that is the thickness of a credit card. Each button is a tactile dome rated for 1,000,000 presses. Each button is programmable to make it either (1) a sustained button (like a rocker or toggle turning on/off an accessory) or (2) a momentary button (like a horn or winch in/out button) AND each button can be programmed to make it active either (1) all the time (a.k.a. wired battery direct) or (2) only with the ignition activated (a.k.a. when you turn your key on). Programming takes less than 30 seconds per switch.
Control Unit: A small, remote-mounted control box which is the brain that allows the programmability of the key pad. All accessories added to a vehicle are routed to the Control Unit. The outputs of the Control Unit correspond with a button on the Keypad. Each output is rated to handle 2.5 amps and is auto current limiting. This means if you are powering something that requires more than 2.5 amps, or if you develop a short, the output will automatically turn off. Once the problem is solved, the output will regain power. Add a relay, and control any number of high powered accessories!
Harness: A 5' harness with 2 locking connectors to link the keypad to the control box. The harness allows you to mount the Control Unit in an easily accessible area in the vehicle for easy addition of multiple accessories, whether the accessories are added all at once or added over a period of time.
Blake
sales@rockridge4wd.com
www.rockridge4wd.com
Call us! Toll Free: 888-411-8493
Rockridge4WD is offline
post #2 of 7 Old 04-02-2013, 05:55 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
These are KILLER!!! Awesome little "command" center. Thin, Discrete, SEXY
Click here for more info!
This is installed in the ROCKRIDGE JK and works AWESOME!
Contact Erin@Rockridge4wd.com
post #3 of 7 Old 04-02-2013, 06:00 PM
sjones26573
That's pretty slick! Think I'll consider that over the sPod when the time comes.
The Offroad Club @ NC State; Founder
The Yellowtail Build
Jeep-Owner.com
sjones26573 is offline
post #4 of 7 Old 07-23-2013, 10:43 AM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
Have you actually looked into these? Virtually cleans up any wiring mess with a nice little programmable switch panel. We love ours!
We have a great deal on these right here. WIRED HDH Flat Switch Panel (8 Switch) FSP series - Programmable - MADE IN THE USA
Watch this video!
Jeff
Sales@rockridge4wd.com
post #5 of 7 Old 08-13-2013, 01:08 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
Like Us On FACEBOOK --> www.Facebook.com/rockridge4wd
post #6 of 7 Old 08-19-2013, 05:16 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
post #7 of 7 Old 08-20-2013, 04:54 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
You may not post new threads
