VISION X has DOT Approved Replacement headlights for only $65 a PAIR!
Jeep CJ YJ TJ XJ ZJ
These are SEALED BEAM REPLACEMENT Headlights that Convert your current setup to an H4 Bulb.
These sealed beam housings are designed to not only give your vehicle an updated look but 30% more light output with their Multi-Surface Reflector Technology. No modifications are necessary, just plug-and-play. Add our super white series halogen insert bulbs and get over 60% additional light output over your factory housings.
2 Housings
Glass Lens
Die-Cast Aluminum Housing
Takes VX-LH4 bulb
Do you want to be able to REPLACE your bulbs but can't because you need the full housing! These are it!!
For only $65 for the PAIR of NEW Headlights, then between $20-$29 for bulbs.
This is a great PRICE!!!
Don't want to pay $400-800 for LEDs or HIDS? Then look no further then this setup. You can't go wrong! SERIOUSLY these make your current lights seem like candles.
Click here to view 5x7 Headlights
Click here to view 7" Round Headlights
No convincing needed to get these either. Just plain and simple....DO YOU WANT TO SEE? If the answer is YES, then you need these Headlights for your Jeep!
Just need bulbs? Check out our site! Complete automotive guide as well to get you the RIGHT bulb.
Click here for Automotive Guide
Want a quote contact me Erin@Rockridge4wd.com
Jeep CJ YJ TJ XJ ZJ
2 Housings
Glass Lens
Takes VX-LH4 bulb
