Want to be able to SEE? DOT Approved Headlights for under $100 BUCKS! VISION X has DO - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > Want to be able to SEE? DOT Approved Headlights for under $100 BUCKS! VISION X has DO
FREE, FREE, FREE EVENT!! Save big on Lockers now till ApriJKS Grand Cherokee WJ, Adjustable Front Trackbar 1"-6Teraflex JK HD Hinged Carrier & Adjustable Spare Tire
Unread 10-06-2014, 07:24 PM   #1
Rockridge4WD
Vendor
Rockridge4WD's Avatar
2010 JK Wrangler
VISION X has DOT Approved Replacement headlights for only $65 a PAIR!
Jeep CJ YJ TJ XJ ZJ
These are SEALED BEAM REPLACEMENT Headlights that Convert your current setup to an H4 Bulb.
These sealed beam housings are designed to not only give your vehicle an updated look but 30% more light output with their Multi-Surface Reflector Technology. No modifications are necessary, just plug-and-play. Add our super white series halogen insert bulbs and get over 60% additional light output over your factory housings.
2 Housings
Glass Lens
Die-Cast Aluminum Housing
Takes VX-LH4 bulb
Do you want to be able to REPLACE your bulbs but can't because you need the full housing! These are it!!
For only $65 for the PAIR of NEW Headlights, then between $20-$29 for bulbs.
This is a great PRICE!!!
Don't want to pay $400-800 for LEDs or HIDS? Then look no further then this setup. You can't go wrong! SERIOUSLY these make your current lights seem like candles.
Click here to view 5x7 Headlights
Click here to view 7" Round Headlights
No convincing needed to get these either. Just plain and simple....DO YOU WANT TO SEE? If the answer is YES, then you need these Headlights for your Jeep!
Just need bulbs? Check out our site! Complete automotive guide as well to get you the RIGHT bulb.
Click here for Automotive Guide
Want a quote contact me Erin@Rockridge4wd.com
sales@rockridge4wd.com
Call us! Toll Free: 888-411-8493
Rockridge4WD is offline   Reply With Quote Quick reply to this message
Unread 10-08-2014, 01:33 PM   #2
Rockridge4WD
Vendor
2010 JK Wrangler
Let rockridge4wd hook you up with some of these SUPER bright headlights!! NIGHT and DAY difference!!
Contact me direct for a deal! Joel@rockridge4wd.com
Unread 12-17-2014, 06:03 PM   #3
Rockridge4WD
Vendor
2010 JK Wrangler
If you guys need new Headlights, but don't want to break the bank with LEDs, and want to be able to change the bulbs? Then check this set up out!
A Sealed Beam Conversion for Jeep! Either in 7" Round or 5x7 Rectangle, Even 4x6" Rectangle available!
These are Glass lens! Get the H4 BULBS (Hight Wattage)
This set up is under $100 bucks shipped! Can't go wrong! Plus with the ULTIMATE Vision X Warranty!
Email me for your quote! Erin@Rockridge4wd.com!
or Click here to view on our site!
Unread 12-17-2014, 07:12 PM   #4
mescobedo90
Do you guys carry any projector s
mescobedo90 is offline   Reply With Quote Quick reply to this message
Unread 12-18-2014, 12:50 PM   #5
Rockridge4WD
Vendor
2010 JK Wrangler
No i'm sorry. From my experience the aftermarket "projectors" don't work very well. They usually are not a fully encased projector lense.
