VISION X Optimus Round LED Fog Light Replacements! Ask ROCKRIDGE 4WD for BEST PRICE! - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > VISION X Optimus Round LED Fog Light Replacements! Ask ROCKRIDGE 4WD for BEST PRICE!
TERAFLEX JKU 2.5" Elite LCG Long FlexArm Lift Kit w/ March Madness LOCKER SALE + FREE SHIPPING + $30-$50 REBATEFLASH SALE! Open thread to reveil the Newest Sale @ ROCKRI
Unread 11-03-2014, 04:45 PM   #1
Rockridge4WD
Vendor
Rockridge4WD's Avatar
2010 JK Wrangler
Ok I have been asked multiple times about a good LED Fog Light Replacement!
Yes other companies (and Vision X in the past) were making brackets to convert the Square 4" LED's to fit the Round Holes of the JK Bumpers.
Well not anymore! VISION X has a line series called OPTIMUS! Now these are available in Square (truck) or Round.
These little lights are Killer! Coming in 10, 20 or 60 Degree patterns. (10 meaning spot, and 60 meaning flood).
They fit perfect in any Jeep Wrangler JK Stock Bumper from 07-15. With the exception of the 10th anniversary bumpers (which brackets are being made and they quite possibly could be done and ready to go). They are a Plug-n-Play install. You are able to install them directly to your current fog light switch. Making no extra switches or unnecessary wiring.
Also they have snap on cover's just like the Cannon's. You are able to change your beam pattern or color filter. You can run these lights with the cover on, in your JK bumper as well!
Why Optimus
The Optimus Series are LED Driving Lights, advancing lighting technology to the next level. Utilizing Vision X Lighting's all new proprietary IRIS Reflector Technology, the Optimus series provides the ultimate focus for long range lighting by producing 693 ft. of usable light from a single 3.5" tall, 10-watt LED. Compared to a standard 55 watt low beam headlight reach of 88 ft. and a standard 65 watt high beam reach of 153 ft, the Optimus propels light further than any single 10-watt LED light fixture in existence. Optimus lights also feature Vision X Lighting's Prime Drive technology for integrated thermal management and dimming capabilities.
Compact, Bold Design
Small Doesn't Mean Weak
The new Optimus Prime doesn't sacrifice light output to achieve an ultra-compact housing. Actually, the opposite. The Optimus Prime outperforms traditional Halogen Off Road Lighting solutions in both distance and output, all while fitting within a housing that doesn't look bulky and in the way. So put away the huge, awkward looking lights, and get the driving lights that will amaze you every time you light them up.
Distance
The Single Optimus Prime throws 1 lux of light 693 feet. For comparison, a motorcycle headlight low beam measures 1 lux at 88 feet, and high beam 1 lux at 153 feet. The Optimus Prime is truly "lighting evolved".
Prime Drive
The More Powerful and Long Lasting LED
The Optimus Prime with Prime Drive drives the LED more efficiently while managing heat levels. This means more light from the LED and a longer lifespan. This is advanced LED technology in action.
Electronic Thermal Management
ETM monitors the heat output of the LEDs and makes use of integrated Pulse Width Modulation circuitry in order to maintain safe operating temperatures in order to prolong the LED life span to its full 50,000 hour potential.
The Optimus Prime utilizes integrated Pulse Width Modulation (PWM) dimming circuitry to manage heat levels. PWM works by flashing the LED at a frequency faster than the human eye can detect, reducing the time that the LED is operating while still delivering 100% light output.
This kit Retail at $288 for the PAIR. You will get 2 lights, Plug-n-Play wire harness, along with 2 JK specific brackets.
Now of course you will be getting an INSANE amount of light from these lights. 693' of Usable Light from 10-watt LED. With the latest (PATENTED) technology. The use of Proprietary IRIS Reflector Technology, PWM Integrated Dimming Circuitry and Integrated Electronic Thermal Management (ETM).
Click here to view these on our site!
Email Erin@Rockridge4wd.com DIRECT to get your quote and the hook up on these lights!
What do you think? Do you need a set?
Jeff@rockridge4wd.com
Call us! Toll Free: 888-411-8493
Rockridge4WD is offline   Reply With Quote Quick reply to this message
