Upgrade your Ford 8.8 axle with the Ultimate C-Clip Eliminator Kit! - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > Upgrade your Ford 8.8 axle with the Ultimate C-Clip Eliminator Kit!
Ruffstuff Axle Simple Swap Kit!TJ BDS 2" suspension lift!! FINALLY a GREAT 2" lNitro Gear Packages Now Available at Rockridge 4wd
Unread 03-20-2015, 05:30 PM   #1
Rockridge4WD
Vendor
Rockridge4WD's Avatar
2010 JK Wrangler
This is an absolute incredible kit! It addresses many of the common issues with the 8.8 axle. It gets you back to stock width if swapping the 8.8 into a Jeep, it gets rid of the c-clips, and gets you alloy shafts with stronger bearings! The install is a breeze too and the instructions are very simple to follow. Best upgrade for the 8.8 yet!
Ultimate 88 axle kit 95-02 Explorer, 4340 Chrome-Moly (Double drilled axles). The Yukon Ultimate 88 kit eliminates the factory c-clips and converts your housing to use two 4340 Chrome-Moly bolt in axles. No welding is needed, just a little cutting to remove the factory axle bearing seat. The result is a super strong setup to give you years of hard use on the trail! Yukon 4340 Chrome Moly alloy rear axles come with a limited lifetime warranty against manufacturing defects.
The axles in this kit are double drilled for 5 x 4.5" & 5 x 5.5" bolt patterns. The kit eliminates the factory c/clips and increases the overall axle width 1" per side.
Anyone that is doing an 8.8 Swap should seriously consider this kit. Get's your converted axle to where it needs to be and bolt on! Can't go wrong with this upgrade!
CLICK HERE TO VIEW ON OUR SITE!
Contact Erin@Rockridge4wd.com for your quote today!
Jeff@rockridge4wd.com
Call us! Toll Free: 888-411-8493
Rockridge4WD is online now   Reply With Quote Quick reply to this message
