The ULTIMATE "Selectable" Locker System! Brought To YOU By ROCKRIDGE 4WD! - Page 5 - JeepForum.com
post #61 of 138 Old 01-14-2014, 02:25 PM Thread Starter
Rockridge4WD
Vendor
Rockridge4WD's Avatar
2010 JK Wrangler
So lets talk AIR!! Air Operated Lockers (of any kind) require some sort of on board air or air source to work (duh). Some people think that compressors are allot and they can be expensive trust me. If you are looking just to turn your lockers on and off then you do NOT need anything fancy. Any sort of comressor will work. The most reasonable one that we sell is $161 which isn't bad. If you want to pump up your tires to then the next price point would be about $255. Then air compressors just go up from there on what you are wanting to do.
So if you are letting on board air stop you from getting an air operated locker DON'T LET IT! Air doesn't compare to any other locker out there PERIOD. When choosing selectable air is the way to go!
With that is mind OX AIR OPERATED LOCKER is the a GREAT Locker. As air never enters the locker it self makes for less components to fail. Air only stays in the cover which then moves a piston to lock or unlock the locker.
Also never be stuck on the trail again with OX. You can get a drive a way lock that allows you to manually lock or unlock your locker and drive out of the trail. NO OTHER LOCKER CAN DO THAT!
Take a look at this video created by ROCKRIDGE 4WD
Click here to find your Locker!
Contact Erin@Rockridge4wd.com for your quote!
Call us! Toll Free: 888-411-8493
Rockridge4WD is offline
post #62 of 138 Old 01-30-2014, 05:32 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
If you're thinking locker, THINK OX!! This is what the Rockridge4wd JK runs and we wouldn't have it ANY other way! For the BEST possible price on the BEST selectable locker on the market, CONTACT me direct!!!
Joel@Rockridge4wd.com
post #63 of 138 Old 02-25-2014, 04:32 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
post #64 of 138 Old 03-26-2014, 11:07 AM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
OX has stepped it up HUGE with their selectable air locker system. BIG time upgrade from their old cable system!! OX has taken this system to a whole new level! NO air enters your axle housing. the air goes into the cover, pushing a fork into the carrier, engaging the lock. There's no delay, and if you have catastrophic failure, you simple remove the diff cover to fix instead of taking apart the ENTIRE diff like most selectable air lockers.. AND ox offers a drive away lock! In the event of failure, simply manually lock your ox and drive back to your place of safety and refuge! (Your garage).. If you're considering a selectable locker, OX is the ONLY choice!
Let me hook you up with a deal!! Contact me today!! Joel@Rockridge4wd.com
CLICK HERE TO VIEW ARB COMPRESSORS!
post #65 of 138 Old 04-15-2014, 05:39 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
In Stock at Rockridge 4wd and ready to ship to your door! Contact us today for your very own quote!
Derran@rockridge4wd.com
Like Us On FACEBOOK --> www.Facebook.com/rockridge4wd
post #66 of 138 Old 04-18-2014, 03:47 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
post #67 of 138 Old 04-30-2014, 05:11 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
IN stock at Rockridge 4wd and ready to ship to your door!
post #68 of 138 Old 05-09-2014, 11:01 AM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
IN stock at Rockridge 4wd and ready to ship to you door!
post #69 of 138 Old 05-13-2014, 03:29 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
In stock at Rockridge 4wd and ready to ship to your door! Contact us today for your very own quote!
post #70 of 138 Old 05-14-2014, 02:33 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
At Rockridge 4wd and ready to ship to your door!
post #71 of 138 Old 05-15-2014, 11:50 AM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
post #72 of 138 Old 05-19-2014, 05:17 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
post #73 of 138 Old 05-21-2014, 10:49 AM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
Looking for the Right Locker for you and Your Jeep? Want to Keep that Ride Quality? Dont mess around with Mechanically Lockers simply by the Best Selectable Locker in the industry. Contact Rockridge 4wd today for your very own quote!
post #74 of 138 Old 05-29-2014, 12:42 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
Want the best locker in the industry? Contact Rockridge 4wd for your Ox Locker complete package!
Name:  OX INSTALLED.jpg
post #75 of 138 Old 05-29-2014, 04:31 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
Rockridge4wd is proud to be a supplier for OX-USA. Their Selectable air locker is the best design in the industry. With you get a drive away lock. For example, if you experience severe failure in the middle of no where, Ox's drive away lock allows you to simply manually engage or disengage the ox locker so you can safely drive back to safety. Second, with ox, NO air enters the axle housing. Air is pushed into OX's air tight diff cover, slides a fork from the cover into the OX and engages the locker. If you experience failure, there's no need to rip your diff down.. simply remove the diff cover and examine the situation, repair or replace, and throw the cover back on.. EASY!! Why would you chose any route other than OX selectable air??
Contact me direct and i'll get you set up with a quote. Hey, might as well re-gear while you're in there! Lets make it a package deal! Contact Joel@Rockridge4wd.com
axles , gears , locker comparison , lockers
Aussie Lockers Now Available Directly From Rockridge 4WD. Get "Only the best..." Rockridge4WD Vendor Display 54 01-12-2016 06:22 PM
New Wurton LED Pod Lights Brought To JF By Rockridge 4WD! Rockridge4WD Vendor Display 20 08-26-2013 05:16 PM
The Rockridge 4WD JK Gets Some Wurton LED 5" Dual LED's. GET YOURS TODAY! Rockridge4WD Vendor Display 7 06-20-2012 06:33 PM
You may not post new threads
