-   Vendor Display (http://www.jeepforum.com/forum/f43/)
-   -   The ULTIMATE "Selectable" Locker System! Brought To YOU By ROCKRIDGE 4WD! (http://www.jeepforum.com/forum/f43/ultimate-selectable-locker-system-brought-you-rockridge-4wd-1410908/)
Rockridge4WD 08-28-2012 04:47 PM
10 Attachment(s)
1) The OX is simply a carrier, no air enters the locker at anytime resulting in an easy installation.
Attachment 461566
2) OX Includes a Heavy Duty Nodular Iron Cover with recessed bolts and features FILL & DRAIN Ports.
Attachment 461567
3) This is what comes with the OX Integrated Air Shift Kit. (Most of the cost is actually in the machining of the cover)
Attachment 461568
4) Air only enters the cover, unlike an ARB where it goes into the locker. The piston with O-Ring that pushes the shift fork can withstand up to 1500 psi meaning regulating air pressure is a thing of the past, with the exception of using C02. The ideal operating pressure is 85 PSI
Attachment 461569
5) The OX locker comes dual drilled in many applications but more specifically its beneficial for both JK bolt sizes. ARBís require that you drill the ring gear bolt holes to either 7/16Ē or 1/2Ē. (TIME IS MONEY)
Attachment 461570
6) OX uses Lock Tabs on the carrier Fasteners to prevent bolts from loosening up and causing catastrophic failure.
Attachment 461571
7) Here you will see the OX is fully self contained, no air enters the carrier. This makes for quick and easy repairs to the air system unlike ARBís. With this system you don't even need to remove the cover! (Saves the average Joe some serious shop labor)
Attachment 461572
8) OX lockers include a heavy duty nodular Iron differential cover. This is showing what the push lock fitting looks like coming out of the OX cover. It is very small and can be easily replaced in seconds if ever damaged on the trail but it is rather well protected by the steering components anyways.
Attachment 461573
10) This is how we set up the Rockridge 4WD JK. Just like an ARB with an electric solenoid coming off of a Viair ADA JK specific air system. You DO NOT have to install the locker this way. You can keep it fully mechanical with the air toggle that is included with the integrated air shift kit. If you do want to run this setup we can supply you with the air system and solenoids needed to make this all work sweet!
Attachment 461574
11) LAST BUT NOT LEAST. MADE IN THE USA FROM START TO FINISH!
Attachment 461575
:thumbsup:
Conclusion: This is the simplest, most reliable, strongest & easiest to repair or install SELECTABLE Locker on the market. PERIOD. In addition to that, if your entire air system decides to have a catastrophic failure you also have the "Drive-Away-Lock". This allows you to unscrew the pushlock fitting from the cover and simply screw this in and manually lock or unlock your rig. You will not loose oil doing this because the air chamber is sealed from the diff oil!
TRY & tell me that common sense doesn't tell you this is the most reliable locker out there after seeing all of this. :cheers:
CONTACT:
Jeff@rockridge4wd.com
Rockridge 4WD
509-588-7800
Rockridge 4wd Call 888-411-8493
Rockridge 4wd - Automotive Customizing, Automotive Parts & Accessories - Wenatchee, WA | Facebook
Rockridge4WD 09-17-2012 02:32 PM
Do you want the BEST on/off road capability? Then call Jeff today to get hooked up with an OX!
Contact
Sales@Rockridge4WD.com
czjeeper 09-17-2012 02:53 PM
Price for a 1992 YJ HP Dana 30?
This will take 4.88 gear?
Jeeper69 09-17-2012 02:56 PM
That was a damn good sales pitch. I'm going to have to look into this
Rockridge4WD 09-17-2012 04:43 PM
Well thank you sir! When something makes that much sense it is easy to sell. Thats the honest truth! :cheers2:
Want one? :rofl:
Rockridge4WD 09-17-2012 04:50 PM
Thanks for the Interest! I've got a quote all done up for you! Shoot me an email with "Estimate #1269" in the subject heading and I'll email it over. Thanks again! :highfive:
Jeff
sales@rockridge4wd.com
Rockridge4WD 09-19-2012 04:28 PM
Let's break this down for YOU! Check out this setup you can't go wrong!
Contact Jeff today!
Rockridge4WD 10-12-2012 04:45 PM
1 Attachment(s)
:highfive:
Jeff
Rockridge4WD 10-12-2012 04:50 PM
You can try and buy this setup from another company but I can almost guarantee you that you will not get the right setup. If you want what I am advertising you need to contact me. I'm pretty sure i'm the only vendor with experience in this system. Call or email me with questions.
Jeff
Rockridge4WD 11-08-2012 02:35 PM
ROCKRIDGE 4WD now offers FREE SHIPPING on ALL OX Lockers! Don't mess around and get this set up! You won't be disappointed! This system is flawless and the ULTIMATE solution for extreme on/off road use!
Contact us today for your OX!
Sales@Rockridge4wd.com
Rockridge4WD 11-12-2012 05:47 PM
Have you checked this out yet?
Jeff
Rockridge4WD 01-16-2013 11:29 PM
ROCKRIDGE 4WD IS MOVING AGAIN!! This time we are moving to a BRAND NEW MUCH LARGER Building with plenty of room to grow. We will have a nice new sales office with new reps coming on board. Our all new showroom will be able to showcase so many more parts and our 2 new warehouses, thats right 2, will be able to handle much more stock. Much more stock means that we buy more. The more we buy the better wholesale prices we get. The better wholelsale prices we get....the MORE YOU SAVE!! Follow?
GET THE BEST DEAL RIGHT HERE ---> ROCKRIDGE 4WD
TODAY-APRIL 15th!
Heck...lets make it easy...
USE COUPON CODE
"RRTAXSALE"
:cheers2:
ANY QUESTIONS?
JEFF
SALES@ROCKRIDGE4WD.COM
:highfive:
PICS OF BUILDING TO FOLLOW AFTER FEB 1ST. :)
Rockridge4WD 01-31-2013 05:45 PM
BUMP FOR THE COOLEST SYSTEM EVER!
:highfive:
Get your quote today!
Jeff
Rockridge4WD 03-04-2013 10:31 AM
2 Attachment(s)
OX LOCKERS are the ultimate in strength and functionality, But If you ever have a failure in your system they provide a drive away lock to get you out of your hairy situations
Attachment 577925
Attachment 577924
Get yours today at Rockridge4wd.com
Blake
Blake@Rockridge4wd.com
www.Rockridge4wd.com
Rockridge4WD 04-16-2013 05:43 PM
If you guys haven't checked out OX's new Air Locker, well you better!!! This set up is sweet and if it fails you are not stuck out on the trail. Check into and contact Erin for quotes or questions!!
Erin@Rockridge4wd.com
The time now is 07:26 PM.
