ULTIMATE Dana 60 High Steer Arms!!! - JeepForum.com
post #1 of 37 Old 11-29-2010, 10:50 AM Thread Starter
ARTEC
Vendor
ARTEC's Avatar
All right, here they are. These are available for Preorder NOW and will begin shipping in Mid-December.
--------NOW AVAILABLE FOR PREORDER--------
Shipments begin Mid December
THE ONLY HIGH STEER ARM YOU'LL EVER NEED!
Whether you are just starting out with crossover steering or going full hydro, these arms are meant to handle it all and GIVE YOU OPTIONS AS WELL! Paired with our optional Knuckle Bolt Kit, the exclusive design of these arms not only allow you to set how you attach your steering links but where as well and increase overall knuckle and steering strength at the same time. Check out the diagrams below of just some of the steering linkage mounting options.
Rather than use the factory kingpin springs, the knuckle is held together with a springless design that uses a set screw to adjust the torque required to hold together. This eliminates some of the slop that is commonly found in axles that receive moderate offroad abuse. The hardware for a springless conversion is included and consists of a 3/4" set screw, jam nut, grease zerk, .250" thick load washer, and upper kingpin bushing for each arm.
Studs and nuts are not included and are available for purchase separately here. Arms are machined blank to allow custom tie rod and draglink locations. Optional drilling for 3/4" bolt or reaming for GM 3/4 ton TRE's (commonly referred to as 1-tons) available.
The Knuckle Bolt Kit is available separately and comes with a 3/4" grade 8 bolt, a 3/4" all- steel mechanical locking nut, and a 1.25" outer diameter, .250" wall sleeve. The sleeve is machined to allow direct contact and proper mislaignment for a 3/4" rod end (heim) ball. The Knuckle Bolt hole is NOT machined into the high steer arm, and the customer will be required to align and drill their own hole in both their knuckle and high steer arm with a 3/4" drill bit.
NOTE: Wheels with extremely large backspacing should not be used in conjunction with this high steer arm. These arms have been confirmed to fit 17", 4.75" backspaced wheels. Will NOT work with factory backspaced H1 wheels. The bulge on the side of the arm measures 1.25" from the spindle mounting surface. Please confirm you have adequate space between arms and wheels/tires before purchasing.
FEATURES:
•Designed to incorporate Knuckle Bolt Kit increasing strength
•Optional Knuckle Bolt Kit puts full hydro in DOUBLE SHEER
•Crossover Steering or Full Hydraulic Steering compatible
•Machined blank to allow customizable tie rod location
•Optional drilling for GM TRE's or 3/4" bolts available*
•Proper 9 degree angle to compensate for knuckle kingpin inclination
•Springless design eliminates slop caused by preloaded spring
•Springless hardware included
•Grease zerk fitting for kingpin lubrication
•5 tapered stud holes for use with OEM or Reid Racing Knuckles
•Optional 6 holes w/ machined Keyway for Solid Axle Knuckles*
•CNC Machined from 1.25" thick 1018 Cold Roll Steel
•Precision machined Artec Industries Logo
•Aerospace-quality spec machined
•Custom Finishes available upon request**
Some Possible Configurations
*Extra machining is special order and may increase leadtime. Additional costs may apply.
**If you have custom requests, please contact us directly and we can provide you with a quote.
PRODUCT LINK
ARTEC INDUSTRIES
1-855-ARTEC99
Jeepforum COUPON: jeepforum
Follow us on
Quick Links:
ARTEC is offline
post #2 of 37 Old 11-30-2010, 09:55 AM Thread Starter
ARTEC
Vendor
ARTEC's Avatar
Might as well just call it the PREORDER SALE but it also applies to everything else we make as well.....
To celebrate record low temps here in Arizona (and the end of everyone's Turkey comas), we've decided to have an ARTEC FREEZE party and everyone is invited. (Just don't try to order online while wearing mittens, it doesn't work very well)
That's right, we are running 20% off any parts we make for TWO WEEKS ONLY. This includes the NEW ULTIMATE Dana 60 High Steer Arms, the NEW QUART CRATES, the industries largest selection of Battery Mounts, tabs, beadlocks, etc.
The discount will show in the shopping cart when you add an item. Cannot be combined with any other offer.
GET THESE COOL DEALS NOW BEFORE IT WARMS BACK UP AGAIN!!! GREAT CHRISTMAS PRESENT UNDER $20!!!
http://www.artecindustries.com/
ARTEC INDUSTRIES
1-855-ARTEC99
Follow us on
Quick Links:
ARTEC is offline
post #3 of 37 Old 12-01-2010, 03:46 PM Thread Starter
ARTEC
Vendor
ARTEC's Avatar
A great Christmas gift at a very cool price. Treat yourself or get your spouse to treat you.
ARTEC INDUSTRIES
1-855-ARTEC99
Follow us on
Quick Links:
ARTEC is offline
post #4 of 37 Old 12-03-2010, 11:07 AM Thread Starter
ARTEC
Vendor
ARTEC's Avatar
Great response to the sale so far. Get a great deal for the holidays.
ARTEC INDUSTRIES
1-855-ARTEC99
Follow us on
Quick Links:
ARTEC is offline
post #5 of 37 Old 12-14-2010, 09:42 AM Thread Starter
ARTEC
Vendor
ARTEC's Avatar
Wow, these arms have been a hot ticket. 20% OFF REALLY HELPS, BUT ITS ONLY AROUND FOR TWO MORE DAYS!!!
ARTEC INDUSTRIES
1-855-ARTEC99
Follow us on
Quick Links:
ARTEC is offline
post #6 of 37 Old 12-15-2010, 11:41 AM Thread Starter
ARTEC
Vendor
ARTEC's Avatar
ONLY HALF A DAY LEFT!!! 20% off ends tonight at midnight.
ARTEC INDUSTRIES
1-855-ARTEC99
Follow us on
Quick Links:
ARTEC is offline
post #7 of 37 Old 02-17-2011, 12:06 PM Thread Starter
ARTEC
Vendor
ARTEC's Avatar
Machined a big batch right before we went out to KOH and nearly sold through the whole thing.
Guess I need to order more steel to make some more. i still have a couple sets left. First come first serve.
I think the concept was really easy to understand from the way we had it displayed.
ARTEC INDUSTRIES
1-855-ARTEC99
Follow us on
Quick Links:
ARTEC is offline
post #8 of 37 Old 03-18-2011, 11:26 PM Thread Starter
ARTEC
Vendor
ARTEC's Avatar
In conjunction with the release of our new COMPLETE FULL HYDRO MOUNTING KIT in which we are offering 15% off the ULTIMATE 60 arms in combo, we've decided to offer...
15% OFF ULTIMATE HIGH STEER ARMS AND KNUCKLE BOLT KITS ALONE AS WELL!!!!
GET THEM HERE
Here's our new kit. Build it to your needs whether its just a ram mount and high steer arms or the whole system. Plus you save Mucho $$ when ordered together. COMPLETE FULL HYDRO MOUNTING KIT
ARTEC INDUSTRIES
1-855-ARTEC99
Follow us on
Quick Links:
ARTEC is offline
post #9 of 37 Old 03-25-2011, 10:44 PM Thread Starter
ARTEC
Vendor
ARTEC's Avatar
15% OFF Ultimate high steer arms and knuckles bolt kits.
GET the BEST for LESS!
LINK
ARTEC INDUSTRIES
1-855-ARTEC99
Follow us on
Quick Links:
ARTEC is offline
post #10 of 37 Old 04-04-2011, 05:40 PM Thread Starter
ARTEC
Vendor
ARTEC's Avatar
LAST CHANCE TO GET THE SALE PRICE! Ends Tonight. LINK
ARTEC INDUSTRIES
1-855-ARTEC99
Follow us on
Quick Links:
ARTEC is offline
post #11 of 37 Old 05-24-2011, 04:50 PM Thread Starter
ARTEC
Vendor
ARTEC's Avatar
Been a while since I've posted I guess.
ARTEC INDUSTRIES
1-855-ARTEC99
Follow us on
Quick Links:
ARTEC is offline
post #12 of 37 Old 06-21-2011, 11:01 AM Thread Starter
ARTEC
Vendor
ARTEC's Avatar
These arms are receiving alot of positive reviews. Check out our facebook page for more details. http://www.facebook.com/artecindustries
ARTEC INDUSTRIES
1-855-ARTEC99
Follow us on
Quick Links:
ARTEC is offline
post #13 of 37 Old 07-06-2011, 02:33 PM
Joe Dillard
Electric Chair Operator
Joe Dillard's Avatar
Thanks for taking your time to explain your product, Nate.
Joe Dillard is offline
post #14 of 37 Old 07-13-2011, 04:49 PM
Joe Dillard
My D60 high steer arms just came in.
One word - WOW!
Well, two more words....thanks Nate!
post #15 of 37 Old 11-22-2011, 06:12 PM Thread Starter
ARTEC
Vendor
ARTEC's Avatar
ARTEC INDUSTRIES
1-855-ARTEC99
Follow us on
Quick Links:
ARTEC is offline
You may not post new threads
