UCF Ultra High-Clearance Transfer Case Skids
#31 | |
Vendor
I would love to see pictures. I thought some clearancing would be required. Did you measure the total clearance gain?
Matt Walton http://undercoverfab.com http://blog.undercoverfab.com sales@undercoverfab.com (334) 797-7113 Check us out on Facebook
#32 | |
Oh and my skid arrived today. I agree with jhendrix05, its a beautiful product, I was planning on painting it, but I may have to leave it bare aluminum to show it off its barely taller than a hockey puck ![]() |
#33 | |
Vendor
Thanks,
#34 |
i am really excited too...
now I know which one to order |
#35 |
This made me just order one!
Hold onto something... Quick!!! |
#36 |
Vendor
#37 | |
WTB: HP Dana 30, Long Island/New York Area detours backbone system for sale |
#38 |
#1 Lawn Crawler
My pictures kinda really suck. hope this helps. The transfer case has about 3/4 inch at the highest point before hitting the tub.
Side View from frame on Driver side. ![]() Back View ![]() From top of transfer case forward. ![]() From the Front D/S to the Back. ![]() I hope this will show that no clearancing is needed on my 97 TJ with auto with a 1 .25 JKS BL and MML . Here is the added ground Clearance with 35s. ![]() ![]()
"HomeBrute" TJ truck Build INDYORV Rear main seal If you weld read this JEEP CO-OP Parts |
#39 |
Any updates on the LOPRO mount? This is the only thing that I am waiting on before ordering my 1" skid. I will be stuffing a 241 behind my NV2550 with a 1"MML and 1.25"BL. I am shooting for no tub clearancing. I will post pics when I get it all in.
'01 TJ, Waggy 44 front, D44 rear, Both locked and loaded, Savvy Armor, SuperWinch LP8500, MetalCloak bumper, and a heavy foot. |
#40 |
Vendor
I am working on it right now. Actually headed to the hardware store to get some bolts in a few minutes for that very project.
#41 |
#1 Lawn Crawler
Matt, Do you ever get to sleep? How about that prototype is it coming my way?
#42 |
Vendor
It went out tonight... I sleep when I'm not working.
#43 |
#1 Lawn Crawler
Thanks Matt, I got the email right after I posted. I will get it Thursday and Post new picts. I will email you a set for reference. I can put my Jeep up on a lift so the pictures will be straight on. Thanks John
#44 |
#1 Lawn Crawler
I purchased the UHC 1 inch deep skid, then found out UCF was making the engine skid also here are the first pictures of the skids together on my 97 TJ.
"HomeBrute" TJ truck Build INDYORV Rear main seal If you weld read this JEEP CO-OP Parts Last edited by Hendrix; 03-22-2010 at 05:13 PM.. |
#45 | |
I have very similar set up as you. What did this do to your rear driveshaft angle at the cv joint (transfer case end)? Did you measure before/after or even just-after angle from TC output shaft to rear drive shaft angle? Did you feel any increase in driveline vibration at highway speeds? Did you use adjustable control arms to bring the angle of the rear u-joint to zero degrees after install? How about before and after driveshaft length from centerline of rear u-joint to centerline of the forward bearing caps of the cv joint at the transfer case end? Sorry for all the questions. If you could just answer the ones that you can, it might help me with my decision. Thanks alot! Jess |
