Tired of cranking the handle on your tubing bender over and over again? Are you using a 6 foot cheater bar slid over the factory handle to gain mechanical leverage while trying to read the degree wheel that is ~ 8 feet away?
This kit is designed out of pure necessity and built to be the best kit out on the market.
Designed to fit either the JD-2 Model 3, JD-2 Model 32, Pro Tools 105, Pro Tools 1050 HD and JMR manual tubing benders. The brackets are laser cut out of high strength 1/4" steel and formed on a CNC press brake. You are able to bend up to 70 degrees on the first stroke. Sold in two configurations, welded or unwelded
Kit is 100% complete with the exception of the 8 Ton Air/Hydraulic ram which cam be purchased HERE.
"Great mount works better than expected. I own a Pro-tools 105 and can say this mount is by far easier to setup and use than another mount I had on my bender. Keep the ideas coming"
Quit justifying your manual tube bender as work out equipment, you my friend need to learn and embrace the art of drinking a beer and watching that bender work for you instead of the other way around.
The JD-2 Model 32 is now listed on the website for sale. The JD-32 Air/Hydro tube bender ram mount is unique in that it has two additional 3/8" plates, bronze bushings, unique tube support brackets and related fasteners, hence the increased price on this model only.
All orders for the JD-32 should ship out late next week.
Are you looking to take your metal fabrication tools to the next level? If you tired of using your tube bender like a rowing work out machine then take a look at our air/hydraulic ram mount.
Keep us in mind for the holiday season. Our line of fabrication tools make a great gifts for friends, family or the old man in your life who taught you how to make sparks and stick metal together.
We have all models of our Swag Bender Ram Mounts in stock and ready to ship. We Also offer them welded and ready to install for anyone looking to save some time.
Tired of manually retracting your tube bender every time you need to re-pin your die set. The 100 pound of resistances offer by this return spring is backwards compatible with our Air/Hydro tube bender ram mount.
Just hook it up to your bender and the back side of your 8 ton ram and your done.
The springs are made of rubber tubing that's encapsulated in a polypropylene fabric sleeve for excellent wear resistance.
Related Threads
Jeep Enthusiast Forums
18.5M posts
726.7K members
Since 2000
