Truck Lite 5x7 LED Head Lights for Jeep Cherokee XJ, MJ Wrangler YJ DOT APPROVED!! - JeepForum.com
post #1 of 6 Old 11-02-2013, 04:14 PM Thread Starter
Rockridge4WD
Vendor
Rockridge4WD's Avatar
2010 JK Wrangler
ROCKRIDGE 4WD now carries Truck Lite for the Cherokee guys and the YJ guys!!
Now you can guys can experience the revolution of LED! These make driving at night safe and enjoyable!! Truck Lite are extremly durable as they were made for the Military to take a bullet and still shine.
Truck-Lite's 27450CK LED Headlamp kit utilizes a completely new light delivery method, adopting parabolic reflector technology to create a smooth, even light output. The use of metalized reflector optics provides a clean and homogeneous spread of light, more uniform than other options, without any targeted or focused beams or projector-type color artifacts. Truck-Lite Used the latest in computer-assisted optics design software to create a reflector-based system that provides an optimum lighting pattern. We essentially increased visibility to the driver, while minimizing glare to oncoming traffic, providing illumination that's safer to everyone on the road. The lamps are designed with Omni-VoltĀ® technology to accommodate both 12 and 24 volt headlamp applications, providing crisper and whiter light output than halogen alternatives, while extending product life and adding greater dependability. The maintenance-free lamps use a solid-state, bulb-free system that's impervious to damage caused by shock and vibration, with a military grade, die-cast aluminum housing, non-yellowing polycarbonate lens and a scratch-resistant hard coating to protect against damage from impact, roadside debris and other hazards. Advanced LED technology has significantly reduced LED headlamp current draw compared to halogen products, to 3.6a high beam and 1.8a low beam, allowing more power for other vehicle requirements & extending alternator life. 5" x 7" rectangular release, meets or exceeds FMVSS-108 and CMVSS-108 DOT requirements for both low and high beam performance.
Sold? Click here to view on our site!
Contact Erin@Rockridge4wd.com for your quote!
Call us! Toll Free: 888-411-8493
Rockridge4WD is offline
post #2 of 6 Old 11-14-2013, 02:13 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
For all you XJ and YJ peeps! Here is the best light ever!!
Check it out!
post #3 of 6 Old 11-21-2013, 01:24 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
Nice Christmas gift for the Jeep Cherokee guy or YJ guy!
Check them out here!
Or contact Erin@Rockridge4wd.com
post #4 of 6 Old 01-08-2014, 02:03 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
We now carry these killer lights in the 5x7 Rectangle for YJ and XJ!!
Check out the comparison picture!
post #5 of 6 Old 02-06-2014, 05:16 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
Your factory head lights just aren't cutting it for ya?! Can't take to the streets with those NON DOT approved light bars?! Check out these LED headlights by TRUCK LITE!! These things ARE DOT approved and they are SWEET!! Check out these pictures to find TRUE justice in the TRUCK LITE LED headlights!!
EMAIL ME direct for a DEAL on these bad boys! Joel@Rockridge4wd.com
post #6 of 6 Old 02-13-2014, 03:17 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
FINALLY a DOT approved remedy to the dim factory jeep headlights!! These lights are extremely bright and efficient. If you're looking to increase your night drive visibility, CHECK THESE OUT!!
Looking to light it up legally?! Contact me DIRECT! Joel@Rockridge4wd.com
You may not post new threads
