Toxic Offroad Made in USA Coated Braided Stainless Steel Brake Line Kits from $84.99 - JeepForum.com
post #1 of 19 Old 05-29-2013, 10:47 AM Thread Starter
Baseline 4x4
Baseline 4x4's Avatar
1979 CJ5
Experience the benefits of Toxic Offroad Stainless Steel Braided Brake Lines.
Toxic Off Road Brake Lines are proudly made in the USA in accordance with all Federal and DOT regulations. It is our commitment to you to provide a top quality product designed to meet the extreme performance requirements that you demand from your vehicle. Each hose is specifically designed and tested to fit your application.
Top 10 Benefits of Toxic Offroad Stainless Steel Performance Brake Lines are:
1. Replacing OE rubber hoses with Toxic Off Road hoses eliminates pedal sponginess under having braking due to less volumetric expansion for improved braking and firmer pedal .
2. Teflon inner core makes these brake lines compatible with all DOT approved brake fluids including DOT 5 Silicone.
3. Suitable for all applications including extreme racing.
4. Each brake line is designed to meet DOT Standard FMVSS-106 and SAE J1401.
5. Every hose is pressure tested to 3000 psi.
6. Each brake line kit is designed to physically fit the application it is designed for without any additional fittings or adapters.
7. All fittings are zinc plated for corrosion resistance.
8. All Toxic Off Road Brake Lines come with a Lifetime Warranty. If your hose fails for any reason, simply return it and we will send you a replacement Hose.
9. Every kit is designed, manufactured and assembled in the USA!
10. Chicks dig them!
2007-2013 Jeep JK Wrangler and JKU Unlimited Toxic Brake Lines
1997-2006 Jeep TJ Wrangler and LJ Unlimited Toxic Brake Lines
1987-1995 Jeep YJ Wrangler Toxic Brake Lines
1984-2001 Jeep XJ Cherokee Toxic Brake Lines
1993-1998 Jeep ZJ Grand Cherokee Toxic Brake Lines
1976-1986 Jeep CJ Toxic Brake Lines
Baseline 4x4 Outfitters
Baseline 4x4 is offline
post #2 of 19 Old 05-31-2013, 12:35 PM Thread Starter
Baseline 4x4
1979 CJ5
Toxic Offroad Brake Hoses come with a Limited Lifetime Warranty.
Contact Baseline 4x4 Outfitters at 866-554-5946 for more information on this item.
post #3 of 19 Old 06-05-2013, 09:42 AM Thread Starter
Baseline 4x4
1979 CJ5
Get your Heavy Duty Brake Lines now at www.baseline4x4.com
post #4 of 19 Old 06-11-2013, 06:50 AM Thread Starter
Baseline 4x4
1979 CJ5
Contact Baseline 4x4 Outfitters to order your Toxic Offroad Stainless Steel Brake Hoses.
We have a kit available for most of the popular Jeep Models.
New kits being added daily!
post #5 of 19 Old 06-21-2013, 12:47 PM Thread Starter
Baseline 4x4
1979 CJ5
Get your Heavy Duty Stainless Steel Brake Lines at www.baseline4x4.com
post #6 of 19 Old 06-27-2013, 03:33 PM Thread Starter
Baseline 4x4
1979 CJ5
Get your American Made Stainless Steel Brakes from Toxic Offroad.
post #7 of 19 Old 07-04-2013, 08:37 AM Thread Starter
Baseline 4x4
1979 CJ5
Toxic Offroad Stainless Steel Extended Brake Hoses
Celebrate Independence Day with a new set of Toxic Offroad Extended Stainless Steel Brake Hoses.
Made in the USA!
Call Baseline 4x4 Outfitters at 866-554-5946 for more information.
post #8 of 19 Old 07-10-2013, 06:52 AM Thread Starter
Baseline 4x4
1979 CJ5
Toxic Offroad Stainless Steel Extended Brake Hose Kits
If you want the Best Stainless Steel extended Brake Hose in the industry then you need to check out these Brake Hoses from Toxic Offroad.
Contact Baseline 4x4 Outfitters at 866-554-5946 for more information!
post #9 of 19 Old 07-14-2013, 08:45 AM Thread Starter
Baseline 4x4
1979 CJ5
Toxic Offroad Brake Hoses use a Teflon inner core that is suitable with all types of brake fluids.
Contact Baseline 4x4 Outfitters at 866-554-5946 for more information![/QUOTE]
post #10 of 19 Old 07-15-2013, 07:09 AM Thread Starter
Baseline 4x4
1979 CJ5
Get your new custom Brake Lines at www.baseline4x4.com
post #11 of 19 Old 07-16-2013, 11:57 AM Thread Starter
Baseline 4x4
1979 CJ5
Toxic Offroad offers Reinforced Stainless Steel Brake Hoses for all Jeep XJ Cherokees and ZJ Grand Cherokees.
post #12 of 19 Old 07-23-2013, 07:03 AM Thread Starter
Baseline 4x4
1979 CJ5
www.toxicoffroad.com makes heavy duty Made in the USA Stainless Steel Brake Hoses for your Jeep.
post #13 of 19 Old 07-25-2013, 07:52 AM Thread Starter
Baseline 4x4
1979 CJ5
Free shipping on these brake line kits at www.baseline4x4.com
post #14 of 19 Old 07-29-2013, 06:36 PM Thread Starter
Baseline 4x4
1979 CJ5
Get your American Made Toxic Offroad Brake hoses at www.toxicoffroad.com
post #15 of 19 Old 08-02-2013, 12:23 PM Thread Starter
Baseline 4x4
1979 CJ5
Free shipping on Jeep Stainless Steel Brake Hose Kits at www.toxicoffroad.com
You may not post new threads
