TJ, YJ & LJ Drop Down Tail Gate Conversion Kit
#16 | |
What about this setup?
Troy,
I have a Soft top, and really am not interested in a hard top. I am not overly concern about it being difficult to open, as I was considering welding it from the inside so the jeep looked like it still had a functional tailgate, but dont have the funds to perform properly. I am ok with the latch on the passenger side you have, and would consider the same on the Driver side to hold the tailgate inplace. My Perfered thought would be the Classic Chain on the outside, and TJ hood Latches on the inside to do the actual holding of the tailgate close (to reduce the rattles). Any thoughts on the second Idea of the Chain and hood latches? Also, I am purhcasing the CJ tailgate hindge kit. Would your hindges use the factory holes that I am going to be drilling into the tub? I am assuming your hindges are more than $40 for a pair (which is what I plan on paying). My tub has title that has been totaled. I have to go thru state inspection to get a Rebuilt Title. And I am buying NEW body parts to make passing state inspection easy. But it drives up the cost, so I have to save as much as possible when it comes to all the small parts such as hindges and hood latching kits. BTW: I like the web hindges. Thanks, John
John Moore ~ Real Men Still Crawl... 88 XJ (Babe) 4.0L w/AW4 4sp Auto Dana 30/35 2.5 inch Flowmaster Exhaust 4 inch Lift w/ 32inch tires & RS5000 Shocks 92 YJ (BOSS) 4.0L H.O. w/AX-15 5sp Manual, 231 TCase, Dana 30/8.8 (3.73) 2.5 inch Flowmaster R.E. 2 inch lift and 2 inch body lift for CJ clip XJ http://www.cardomain.com/ride/2634588 YJ http://www.cardomain.com/ride/3322306 |
#17 |
Would this conversion work with a stock spare tire mount? I have around a 32" spare, think it would hit the bumper or would this kit even work with the stock monted spare tire carrier?
#18 | |
Vendor
Troy
Swagoffroad.com Innovative fabrication tools, & Drop down tailgate kits for YJ's, TJ's and JK's. Visit us on Facebook |
#19 |
" Volkswagen "
I want one! I'm sure we will be in touch. I look forward to having one of these soon.
Jeep build up...ONGOING Jeep build up...ONGOING R.I.P. Tow Pig Dually build Rear bumper/spare tire carrier build Track bar bracket fabrication AtoZ cage install/build NeetoCJ was a generous guy and renewed my membership..... Blame him for your troubles! |
#20 | |
Vendor
Troy
#21 |
Any Idea on my request?
Hey, did you see my request for how I would like my YJ done? Is it possible do have external chain and internal latches?
Do your hindges use factory mounting holes on the CJ tailgate? Thanks, John
#22 | |
Vendor
John, Any deivation from the standard kit will need to be done on your end. I could run myself ragged trying to come up with unique solutions for every request that comes my way. The hinges I use do fit the factory mounting holes for the CJ tailgate. Troy
#23 | |
Thanks
Thanks, John
#24 | |
cost ~ thanks
Thanks, John
#25 |
I have a somewhat odd question I guess. Would it be possible to make a kit that works both ways, swings out, and also drops down. Obviously not at the same time, but maybe a setup where there is two set of hinges. One pin can pull from either set of hinges, and allow it to swing one way, put it back in, pull the other pin, it swings the other way. You could even put both pins in, and keep it from opening at all, a small form of security. Or take both pins out, and be able to take the gate off fully without a hassle. I know that kind of kit would be more expensive, but my dad and I were talking about creating a kit like that one day (if we ever got a welder), and he has seen the kit before in person, and he said it looks very solid and would be really cool with a dual swing option. Let me know if this would one day be possible, I know for sure I wouldn't be able to order for quite some time though.
JFI Member #7: Helping out the Scammed 2004 Rubi: Ready to Kill the Chrome! Totaled and Gone: Mostly Stock 2005 I6 Patriot Blue TJ: Monstaliner (Write-Up) BESRK Rear Bumper, Hella 500s Do the Jeep Wave :D 0|||||||0 Take 95% of what I say as a joke/sarcasm!-Thomas |
#26 | |
Vendor
If you left your stock hinges on the passenger side in place and made a removable center pin, as well as a removable center pin on the bottom two hinges, then yes you could have a kit that is able to swing down or out depending on which center pins you pulled. Simular to this picture. This modification would be easy for you to do. Troy
#27 | |
#28 |
Vendor
The kit does use the factory latch.
Let me know when you are ready to order. Thanks Troy
#29 |
I really like this kit other then the latch on the right side. It screams HEY LOOK AT ME. Is there any other option availible?
AMSOIL DEALER |
#30 | |
Vendor
Troy
| Thread Tools | |
Previous Thread
Next Thread
| Suggested Threads |
