TJ Dana 60 - BOLT IN REAR - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > TJ Dana 60 - BOLT IN REAR
Jeep Wrangler Bushwacker Flat Fender Flare Sale at BaselinNEW KOR LED Lights from KrawlOff-Road.comWIN a Mammoth Lift Kit for your Wrangler at ExtremeTerrain
Unread 07-15-2011, 12:46 PM   #1
ECGS
Vendor
ECGS's Avatar
THE ULTIMATE TJ JEEP WRANGLER REAR AXLE SWAP - BOLT IN - DANA 60- 35 SPLINE CHROMO AXLES-DISC BRAKE W/ E-BRAKE
JEEP TJ BOLT IN DANA 60 - COMPLETE AXLE ASSEMBLY Built to your specs here! http://eastcoastgearsupply.com/i-686...4-5-5x5-5.html
Benefits:
*Ring and Pinion Dana 60- 9.75" vs JK44- 8.89, D44a- 8.5, D35- 7.6
*Huge Pinion Bearings, Carrier Bearings, and Spider Gears found in 1 ton axles
*Big Set 20 Axle Bearings rated for double the load rating of SET 10 found in JK 44, TJ 44
*5X4.5 / 5x5.5 4340 Chromoly 35 Spline Shafts 1.5" Diameter- the ultimate upgrade shafts come standard - Fits your current lug pattern with option to upgrade
*Braided Stainless soft lines and Nickel hard lines pre ran w/ mounting locations
*HEAVY DUTY Brackets with Adjustable trac- bar mount
*All our production axles are welded in a solid mount jig to insure proper fitment
Differential Sales & Service
Quality Gears, Lockers, Axle Shafts, and other drivetrain products at a fair Price
http://www.eastcoastgearsupply.com
919-672-2705
ECGS is offline   Reply With Quote Quick reply to this message
Unread 07-17-2011, 06:00 PM   #2
Timeless
1987 MJ Comanche
Badass, Chase.
Timeless is offline   Reply With Quote Quick reply to this message
Unread 07-17-2011, 06:18 PM   #3
ActionJackson
Stock width? Different width options?
RED JEEP CLUB MEMBER #519
ActionJackson is offline   Reply With Quote Quick reply to this message
Unread 07-17-2011, 08:11 PM   #4
cj777
1977 CJ7
Awesome. Hoping for a matching front
Wanna cracker?
'74 CJ5
'81 CJ7
'03 TJ
cj777 is online now   Reply With Quote Quick reply to this message
Unread 07-18-2011, 03:38 PM   #5
ECGS
Vendor
ECGS's Avatar
The TJ front is about 90% complete, the bracket kits are done and welded on an axle, the brake bracket has been designed and protyped we need someone who can manufacture them out of 1 inch plate. After the brake bracket is complete all we have left is to test fit.
The Rear 60 can be 61-63 inches. Anything wider will need to be full float. The TJ 60 is going to be 63.5 inches.
919-672-2705
Unread 07-19-2011, 01:11 AM   #6
wrangler1988
what brand axle shafts are you using and what size is the size of the axle tubes?
wrangler1988 is offline   Reply With Quote Quick reply to this message
Unread 07-19-2011, 02:44 AM   #7
07wurubi
07wurubi's Avatar
Dam, where was this when I ordered my 8.8? Looking good Chase.
I'll keep an eye out for the front one now.
Mike Fox
My Jeep:
00 Wrangler Sport 4.0L NV3550
4" RC LA full suspension system
Bilstein 5100 shocks all around
axles (30,8.8) with 4.88 gears ARB F/R
SYE and CV rear driveshaft from Drivelines NW
Currie HD steering (Thanks Savvy, Awesome customer service)
Savvy LED tail lights (Thanks again Savvy)
GY MT/R Kevlar 35x12.50x15 on 15x10 American Racing AR23
Bestop soft top with tinted windows
Smitty front and rear bumpers w/rear tire carrier
Smitty XRC8 winch w/synthetic rope
Smitty rear corners and rock sliders with step
Genrite aluminum 6" tube fenders front/rear
Dodge Durango steering box with Pure Jeep skid and M.O.R.E. steering brace
07wurubi is offline   Reply With Quote Quick reply to this message
Unread 12-23-2011, 01:28 PM   #8
bigredjeep1
Super beefy very nice!
bigredjeep1 is offline   Reply With Quote Quick reply to this message
Unread 12-23-2011, 06:32 PM   #9
freedommachine
1930 XK Commander
About how much does the axel weigh?
freedommachine is offline   Reply With Quote Quick reply to this message
Unread 01-19-2012, 11:09 AM   #10
wrangler97
Overbuild
wrangler97's Avatar
Does ECGS have any intention of making a matching front d60?
1997 Wrangler 6cyl 5-spd; 4" short arm, 35X12.50's: White Jeep Club Member #95
"Every normal man must be tempted, at times, to spit upon his hands, hoist the black flag, and begin slitting throats"
wrangler97 is offline   Reply With Quote Quick reply to this message
Unread 03-21-2012, 04:04 PM   #11
RX4ROCS
How much for a used FF D60, narrowed to 65" WMS/WMS w/ Detroit, 5'13s, TJ brackets and discs shipped to 95901?
RX4ROCS is offline   Reply With Quote Quick reply to this message
Unread 03-22-2012, 02:12 AM   #12
Davetha
Davetha's Avatar
I would be more interested with a front one to go with it
Davetha is offline   Reply With Quote Quick reply to this message
Unread 03-22-2012, 02:43 AM   #13
LostJeeper
I would like d44 but trying to get rid of outers i want locking hubs
Armed Forces Jeeps
MT WAVE SAR
KF7IRO
LostJeeper is offline   Reply With Quote Quick reply to this message
Unread 04-03-2012, 03:26 PM   #14
RX4ROCS
Agreed...but judging from the lack of response either the front D60's are not available or maybe they're out of stock because they're free?...lol
Can anybody explain the justification behind the outrageous prices for aftermarket D60's ($6500-$9500)? A junkyard 60 costs $500 (yes, here on the west coast), shorten the housing and passenger side axle shaft for $200, add an ARB locker $750, set of gears $250, throw some TJ brackets on it for $375, rebuild the kingpins $75, Warn premium hubs $200, rebuild and use the factory 3/4 ton brakes and calipers $150, throw the vendor a $500 bone for labor, and you have a frontend ready to bolt in for $3000.
Unread 04-03-2012, 04:04 PM   #15
RWKHausSupply
1990 XJ Cherokee
A junkyard 60 costs $500 (yes, here on the west coast), You cant find these in so cali in "junk yards" so you pay 1100$ typically.
Shorten the housing and passenger side axle shaft for $200, For a true axle shop to cut off a C and short the tube is a lil over 200$. You still need some 35 spline inner shafts about -350$.
Add an ARB locker $750, Last I checked they were about 950-1200 plus tax and or shipping
set of gears $250, about right, plus a master kit at 150$
Throw some TJ brackets on it for $375, for Just the brackets maybe, but a closer true estimate is 600$ for currie to supply and weld on all the brackets needed.
Rebuild the kingpins $75, About right, maybe a bit more.
Warn premium hubs $200, A Waste, run slugs or Yukons new selectable hubs
rebuild and use the factory 3/4 ton brakes and calipers $150, yes
Throw the vendor a $500 bone for labor, You better add at lil to that.
and you have a frontend ready to bolt in for $3000. Not even close
You forgot..
Outer stubs - 200$
hub bearings - 75$
Ujoints - 150$
Its not as cheap as you would think, IF YOU DO IT RIGHT...
Yeah if you just want a 30 spline outer, stock 1040 inner axle frankenstien, that was in Perfect condition when you get it, you can get away for a more resonable price.
RWKHausSupply is offline   Reply With Quote Quick reply to this message
