TJ Bumper/Winch Special! CCOR 706-207-4140 - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > TJ Bumper/Winch Special! CCOR 706-207-4140
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineIncome tax season is upon us. We got what u needGet 5% Back On Rugged Ridge-Omix-ADA-Alloy at ExtremeTerra
Unread 08-28-2013, 01:21 PM   #1
CCOR
Vendor
TJ front bumper, Rear Tail plate,Winch fair lead mount, and 8500lb Winch $550 Shipped! + $20 Mail in Rebate!
Great way to get ready for those club rides! Tow points on all 4 corners!
TJ Front Bumper is laser cut from 3/16" and is formed on a CNC Press Brake. This is a high clearance bumper that offers the protection that you need without getting in the way on the trail. Our bumper uses eight factory mounting holes to attach the bumper to the frame. This bumper can be used with both factory and aftermarket sway bars. This design keeps the winch close to the grill for improved protection and low to maximize air flow. D-ring mounts are 3/4" thick welded inside and out and accept a 7/8" D-ring
The TJ LJ rear Tail Plate Bumper provides maximum departure angle, two recovery points and adds rigidity to the back of your frame. These are made of 3/16” steal and the clevis mounts ore ¾” and accept a 7/8” D-ring.
Winch Fairlead Mount installs between the winch and the bumper so you can mount your Hawse or roller fairleads. Winch mounting bolt pattern is 10.0" x 4.5".
Durable 5.5 HP Series Wound motor for long life and extra pulling power
Tough 3 stage planetary gear box with a 172.8:1 gear ratio delivering power and reliability
Includes 94' of 5/16" diameter wire rope and latched hook
Automatic load holding brake system (in the drum brake system)
Exclusive light mount roller fairlead included- allows for easy no-drill mounting of up to 2 off road lights!
Tough stainless hardware is used on the body of the winch to eliminate rust
Each winch includes a durable 12' all weather cable remote solenoid box that can be mounted in multiple positions (over cable or over motor) and angles to accommodate most winch bumpers including the Rugged Ridge XHD Bumper System!
Limited 3 year warranty against manufacturing defects
www.classiccityoffroad.com
To order call 706-559-9609
Randy's Gear Supply
CCOR is offline   Reply With Quote Quick reply to this message
Unread 09-10-2013, 02:05 PM   #2
CCOR
Vendor
Thanks,
Bobby
Sales Manager
CCOR
706-207-4140
Randy's Gear Supply
