TJ Bolt in Dana 44JK - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > TJ Bolt in Dana 44JK
Savvy Billet LED Tail LightsRough Country Jeep Suspension Deals at Rockridge 4WD!Alloy usa heavy duty ball joint kits
Unread 05-01-2014, 10:31 AM   #1
ECGS
Vendor
ECGS's Avatar
The TJ Dana 44 JK complete bolt in axle assembly is a perfect upgrade for the hardcore off road enthusiast. Don't waste money on your Dana 35 only to find out you need to upgrade again.
Benefits:
* Confidence in having a USA MADE OE 8.89 Ring Gear W/ Dana 60 size pinion shaft
* OE DANA SPICER USA MADE RING AND PINIONS AND CASTINGS!!!
* 3/8 WALL DOM TUBE
* Set 10 Wheel Bearings - which will retain the wheel if a shaft were to fail
* 35 spline Chromoly shafts - the upgraded shafts come standard
* Retains stock brakes to retain ebrake, or can be upgraded to a Disc brake set-up SET 10 OR SET 20 W/ Ebrake compatibility
* Stock Lug pattern 5x4.5 with the option to change to 5x5.5 whenever you choose
****NOTE: Disc brake Upgrade this is the most complete kit on the market. Brakes will be installed, Axle will bolt in and brakelines are already plumbed.
****NOTE: THIS HOUSING AND COMPONENTS ARE ALMOST 100% USA MADE AND IS THE STRONGEST DANA 44 AXLE ONE CAN BUILD, VERY CLOSE TO DANA 60 STRENGTH. THE OX AIRSHIFT OPTION IS THE EASIEST TO ACTIVATE AND STRONGEST OPTION(USA MADE). IT IS ALSO THE BEST VALUE AS YOU GET THE HD COVER WITH LOCKER PURCHASE!
http://eastcoastgearsupply.com/i-165...35-spline.html
Differential Sales & Service
Quality Gears, Lockers, Axle Shafts, and other drivetrain products at a fair Price
http://www.eastcoastgearsupply.com
919-672-2705
ECGS is offline   Reply With Quote Quick reply to this message
Unread 05-01-2014, 12:29 PM   #2
crackedcornish
available for the YJ?
Orange Jeep Club #88
˙ɹǝʌo ɹǝʇndɯoɔ ɹnoʎ dılɟ sıɥʇ pɐǝɹ uɐɔ noʎ ɟı
crackedcornish is offline   Reply With Quote Quick reply to this message
Unread 05-01-2014, 12:31 PM   #3
ECGS
Vendor
ECGS's Avatar
yes and ZJ and WJ working on getting those up on the web
919-672-2705
Unread 05-10-2014, 09:22 AM   #4
aparke4
aparke4's Avatar
I have a full traction truss for a wishbone style 3 link- it is a bolt on truss in stock mounts. Do you guys offer a weld on truss?
aparke4 is offline   Reply With Quote Quick reply to this message
Unread 05-12-2014, 08:38 AM   #5
ECGS
Vendor
ECGS's Avatar
We have done 10-12 Full traction truss axles.
They have a weld on truss that just needs to be shipped to us. The angle of that truss varies depending on the version of your kit and the correct angle should be verified with full traction.
We stock the clayton trusses and can weld those on no problem
919-672-2705
Unread 05-12-2014, 02:38 PM   #6
aparke4
aparke4's Avatar
Great!
Have u guys bolted on a full traction truss to your mounts?
Unread 06-02-2014, 10:05 AM   #7
ECGS
Vendor
ECGS's Avatar
ready to build for your application
919-672-2705
Unread 06-06-2014, 01:37 PM   #8
SpeedJeep
SpeedJeep's Avatar
How soon before a front option is available?
With sufficient thrust, pigs fly just fine.
SpeedJeep is offline   Reply With Quote Quick reply to this message
Unread 06-23-2014, 10:37 AM   #9
ECGS
Vendor
ECGS's Avatar
We currently Offer the Rubicon TJ 44 front, and a Dana 60 Front
919-672-2705
Unread 06-23-2014, 12:41 PM   #10
SpeedJeep
SpeedJeep's Avatar
I was contemplating a JK44 front with JK spindles and brakes for a TJ. It just seems a waste to upgrade the R&P and still use the small TJ tubes and C's.
Unread 07-21-2014, 07:02 AM   #11
ECGS
Vendor
ECGS's Avatar
Ready to build
919-672-2705
Unread 08-23-2014, 09:16 PM   #12
STRATTON
can the jk axles for a tj, be made with lockers other then thats listed on the website or the factory lsd ?
im sure you wont read this by monday, but i will be in contact with you then.
thanks.
stratton.
STRATTON is offline   Reply With Quote Quick reply to this message
Unread 08-25-2014, 08:22 AM   #13
ECGS
Vendor
ECGS's Avatar
We will be releasing a Standard 44 in the next 30-45 days we are waiting for our USA made casting to come in. Standard 44 will be able to run any locker, posi, or open carrier you want. If you want the larger JK ring and pinion then you have to run an ox locker, ARB, or JK elocker.
919-672-2705
