TJ BDS 2" suspension lift!! FINALLY a GREAT 2" lift at a GREAT price! - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > TJ BDS 2" suspension lift!! FINALLY a GREAT 2" lift at a GREAT price!
Ruffstuff Axle Simple Swap Kit!Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineThe Original 3/8" Ruffstuff Diff Cover!
Unread 03-24-2015, 05:54 PM   #1
Rockridge4WD
Vendor
Rockridge4WD's Avatar
2010 JK Wrangler
CHECK IT OUT TJ GUYS!! BDS 2" suspension lifts are PERFECT for anyone looking to improve the ride of their TJ, gain a few extra inches of clearance AND easily clear a 32" tire!
This is not a cheap budget spacer lift. This is a VERY affordable suspension lift, replacing your factory coils and shocks with HIGH quality, BDS components.
This 2" lift kit comes with four new Pro-Ride Coil Springs that will increase wheel travel and are capable of full coil bind. These coils are manufactured using high grade steel and are preset to not settle or sag. This kit is complete with BDS 5500 series shock absorbers for a smooth ride!
BDS is backed by the BEST warranty in the business! If you don't like what you get, SEND IT BACK! Plain and simple!
I can get you a great deal on this kit! Contact me direct and i'll get you set up!! Joel@rockridge4wd.com
Jeff@rockridge4wd.com
Call us! Toll Free: 888-411-8493
Rockridge4WD is offline   Reply With Quote Quick reply to this message
Unread 03-28-2015, 11:41 AM   #2
fd1505
Rear track bar relocation bracket necessary with this lift? And cost shipped to 21666. Thanks
fd1505 is offline   Reply With Quote Quick reply to this message
Unread Yesterday, 04:59 PM   #3
Rockridge4WD
Vendor
2010 JK Wrangler
PM SENT! Thanks!
Joel
Rockridge4wd
