TJ 5.25" Speaker Adapters - NalinMFG - Page 4 - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > TJ 5.25" Speaker Adapters - NalinMFG
Poison Spyder DeFenders™ - "Tubeless" Jeep FendeBaseline 4x4 Lifetime Warranty 4340 Chromoly Axle Shaft KiJcrOffroad new Crusader TJ/YJ/CJ Bumpers available!!
Unread 02-17-2012, 05:58 AM   #46
NalinMFG
Vendor
NalinMFG's Avatar
Originally Posted by NalinMFG View Post
No one would be interested in some tweeter mounts/brackets would they?
I have received a good bit of interest in these. What sizes/brands are you interested in running? I currently have 4 prototype sizes.
Andrew Nalin
NalinMFG.com
5.25" TJ Speaker Adapters
Facebook Like for a 10% Coupon Code
NalinMFG is offline   Reply With Quote
Unread 02-17-2012, 08:00 AM   #47
05RubiLJ
As I mentioned on my FB post to you last week, I am installing Polk DB5251 in the front. Just painted my 5.25" brackets and looking forward to these. Pics coming soon.
Thanks for posting the tweeter bracket pics. Have you noticed if the door straps get in the way when the door is closed in this position?
05RubiLJ is offline   Reply With Quote
Unread 02-17-2012, 08:27 AM   #48
NalinMFG
Vendor
NalinMFG's Avatar
Looking forward to them!
Door straps fold in just above them, not an issue.
I am still in the process of determining what sizes to put into production for the tweeter mounts. Potential customer input is greatly appreciated!
Andrew Nalin
NalinMFG.com
Unread 02-17-2012, 11:00 AM   #49
NalinMFG
Vendor
NalinMFG's Avatar
2 sets from this morning shipped!
Andrew Nalin
NalinMFG.com
Unread 02-18-2012, 05:30 AM   #50
05RubiLJ
Painted, Polk DB5251 bolted up, ready and waiting for tweeter brackets
Unread 02-18-2012, 09:23 AM   #51
NalinMFG
Vendor
NalinMFG's Avatar
Looking good, is the tweeter that comes with the DB5251 components the DB1001? I might have a prototype set I can send you, Ill check my dimensions when I get back today.
Andrew Nalin
NalinMFG.com
Unread 02-18-2012, 09:34 AM   #52
05RubiLJ
Yes, they are the DB1001 - 2 1/16" mounting cup. Just let me know how to order them.
Unread 02-18-2012, 03:27 PM   #53
NalinMFG
Vendor
NalinMFG's Avatar
05RubiLJ,
These are designed to be flush mount so you wont need the mounting cup. I have a prototype set that is withing a few hundredths of 2"...if you have a set of calipers and want to check I'd be glad to send them your way. I will have some 2" ones cut in the next speaker adapter batch.
I actually ordered some MM5251's from SonicElectronix early this morning, I'll be able to check out their tweeter dimensions first hand if you are unable to. I suspect the DB1001 is going to be the main seller.
http://www.sonicelectronix.com/item_...%5BIgnore%5D=1
Took some pictures of the 1.75" mount with some old Pioneer's:
Just took it out of the press brake.
Bolted it to the door pin for those of you that might be scratching you head on how it mounts.
How the tweeter flush mounts.(I unscrewed the metal retainer, slid it in, then re-installed because it is an exact fit around the tweeter). Note: The pin bolts to your tub, I used some nuts that I had laying around to simulate it for these pictures.
Front view of tweeter.
In the Jeep. Does not interfere with door strap, and could not get my foot near it without blatantly trying.
Tried to take this roughly where my head would be, while still being able to see it through the wheel.
I am about 15 speaker adapters sales away from cutting another sheet, several sizes of these will be on that sheet. Should be before the end of the month.
Andrew Nalin
NalinMFG.com
Unread 02-18-2012, 04:29 PM   #54
05RubiLJ
This is how the Polk tweeters mount up. 2 1/16" cup
Unread 02-18-2012, 05:02 PM   #55
NalinMFG
Vendor
NalinMFG's Avatar
Guess I'll be doing some 2-1/16" ones too! I wonder why their manual says a 2" hole saw? I agree with you that those need 2-1/16".
http://www.polkaudio.com/downloads/m...CoaxManual.pdf
Andrew Nalin
NalinMFG.com
Unread 02-19-2012, 01:31 PM   #56
05RubiLJ
I did not have a 2" hole saw but I did find a 2" mailer tube and it drops right in. I also had some 2" schedule 40 PVC (measured 2 3/64 ID) and it had a bit more play in it. After some testing, I think 2" should be fine for Polk DB1001,
Unread 02-19-2012, 01:50 PM   #57
NalinMFG
Vendor
NalinMFG's Avatar
The one's I've drawn on the sheet so far have a hole a few hundredths larger than 2". I appreciate your willingness to share the dimensions!
Andrew Nalin
NalinMFG.com
Unread 02-19-2012, 03:51 PM   #58
Marauder_Pilot
Marauder_Pilot's Avatar
Just want to say that I used these to replace my factory speakers with some new Polk Audio speakers, and they were worth every penny! Solid as hell, went in with no fuss, no rattles, perfectly sized, everything I could have hoped for.
The new speakers aren't bad, either.
Also, have you guys given any thought to back seat and/or center console mounting brackets? I'd like to be able to mount a smaller speaker behind the backseat, around where the rollcage mounts to the tub.
"Buying a Jeep for on-road handling is like downloading porn to savor the cinematography."
-TTAC
| ARB/Old Man Emu | Northridge 4x4 Canada | Warn | Modern Classic Enterprises | American Expeditionary Vehicles | GenRight | Poison Spyder | OR-FAB | Metalcloak | East CoastGear Supply | JKS | M.O.R.E. |
2000 Jeep Wrangler TJ Sport-OME HD Lift, ProComp bumper, 32" BFG TA K/Os
1994 GMC Sierra 1500 2WD-Stock
2010 Kawasaki KLR650-Stock
Marauder_Pilot is offline   Reply With Quote
Unread 02-19-2012, 06:26 PM   #59
NalinMFG
Vendor
NalinMFG's Avatar
Thanks Marauder
I may not be picturing what you're describing. An open air mount like the tweeters, but for speakers? Speakers need to be in some type of an enclosure for optimal sound.
Andrew Nalin
NalinMFG.com
Unread 02-19-2012, 11:44 PM   #60
NalinMFG
Vendor
NalinMFG's Avatar
Happy President's Day!
Andrew Nalin
NalinMFG.com
