TeraFlex TJ 4" Lift Kit!! WANT A DEAL?! - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > TeraFlex TJ 4" Lift Kit!! WANT A DEAL?!
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineSave 17.76% for the 4th of july with ruffstuff specialtiesJuly 4th Sale Event! and Yes, We're Open!
Unread 05-28-2015, 01:11 PM   #1
Rockridge4WD
Vendor
Rockridge4WD's Avatar
2010 JK Wrangler
Check this kit out TJ guys!! This is the Teraflex 4" lift with all 4 teraflex 9550 shocks!!
The TeraFlex TJ 4” Suspension Lift Kit delivers massive trail performance without breaking the bank. This kit includes 4” lift coil springs, 9550 VSS shock absorbers, dropped pitman arm, front swaybar quick disconnects, rear swaybar links, rear trackbar bracket, bumpstops, brake line extension brackets, transfer case lowering kit and all necessary hardware. This kit will allow you to run up to a 35” tire. Fits all TJ Wrangler models including Rubicon & Unlimited.
Teraflex suspension developed the FIRST TJ suspension system on the market! If anyone knows what TJs are all about, it's these guys!!
Here's a side note. Lifting 4" may cause driveline vibration. It is recommended that you make some form of driveline modification such as slip yoke eliminator and a minimum of 4 adjustable control arms. NO WORRIES!! I can hook you up with deals on those as well!!
Contact me direct for a deal!! Joel@rockridge4wd.com
sales@rockridge4wd.com
Call us! Toll Free: 888-411-8493
Rockridge4WD is offline   Reply With Quote Quick reply to this message
