TeraFlex Speed Bump KIT for Jeep JK w/ 3", 4" or 6" Lift...THIS IS A MUST! - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > TeraFlex Speed Bump KIT for Jeep JK w/ 3", 4" or 6" Lift...THIS IS A MUST!
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineNEW ZJ Grand Cherokee Tube DoorsGibson WK HEMI 3" Catback - 5 Day Special!
Unread 07-18-2015, 02:47 PM   #1
Rockridge4WD
Vendor
Rockridge4WD's Avatar
2010 JK Wrangler
TeraFlex SpeedBump bumpstops are an innovative composite bumpstop system designed for high-performance JK Wrangler applications. The true progressive nature of the SpeedBump bumpstop allows for the reduction of suspension compressing impacts and the associated harsh bumpstop bottoming. The absorption of harsh impacts experienced off road or even on a poorly maintained highway will reduce the risk of axle housing bends as well as provide an increased ability to maintain vehicle control. TeraFlex SpeedBumps feature performance tuned closed-cell nitrogen charged microcellular polyurethane technology providing a true progressive bumpstop that will not fade or dissipate under extended heavy use. Microcellular polyurethane technology is not affected by temperature extremes, and retains thermal and sub-zero temperature flexibility. The Delrin acetal resin polymer shaft is self-lubricating to allow thousands of continuous cycles without wear or abrasion. The external shaft seal further prolongs shaft life by wiping and cleaning the shaft to prevent contaminants from entering the SpeedBump housing. The maintenance free SpeedBumps require no custom adjustment or tuning.
The simple bolt on installation requires removal of the factory bumpstop bell (front applications only) no welding is required. This kit includes two front SpeedBump and two rear SpeedBump bumpstops, front adjustment spacers, and front lower bumpstop strike pads.
After you install these Speed Bumps, you will be out trying to jump your Jeep. Now pair them up with some Fox Shocks and you will have a fast machine off road and on!!
Check out the video's below. Contact Erin@Rockridge4wd.com for your quote on a set of these.
Click below to view on our site
For 3" Speedbumps
4" Speedbumps
6" Speedbumps
http://www.youtube.com/watch?v=poz0lpGP0m8
http://www.youtube.com/watch?v=6PF1Rwwe7WE
sales@rockridge4wd.com
Call us! Toll Free: 888-411-8493
Rockridge4WD is offline   Reply With Quote Quick reply to this message
