TERAFLEX JKU 2.5" Elite LCG Long FlexArm Lift Kit w/ SpeedBumps!! - JeepForum.com
post #1 of 4 Old 04-08-2015, 10:58 AM Thread Starter
Rockridge4WD
Vendor
Rockridge4WD's Avatar
2010 JK Wrangler
Here we have it guys!! The Teraflex 2.5" ELITE LCG LONG FLEXARM SYSTEM!! This is one of the best kits on the market if you're looking for extreme handling and low center of gravity!!
The advantage and benefit of the TeraFlex JK 2.5" Elite LCG Suspension System for JK Wranglers is apparent the minute you put the pedal to the floor. With superior handling, responsive steering, ultimate off-road performance, and customizable suspension geometry, this system is miles ahead of anything else out there. TeraFlex continues to dominate the off-road market, and the Elite LCG reinforces that position. The Elite LCG Suspension can handle anything you can dish out. The Elite LCG Suspension System is the perfect solution for aggressive trail users looking for the most advanced Long FlexArm system available with a lift height that keeps the center of gravity as low as possible.
The Elite LCG features adjustable suspension tuning, and is accomplished through fully adjustable upper and lower long FlexArms that allow pinion, caster, anti-squat, and tire position configurations to be modified. This kit includes 2.5" lift coil springs, weld-on long arm bracketry, long adjustable FlexArms, front adjustable monster trackbar, front swaybar disconnects, rear swaybar links, rear trackbar bracket, SpeedBump bumpstops and all necessary hardware. This suspension system is designed to fit up to 35 tires (aftermarket wheels with 4.5 backspacing or less is required). Fits all JK Wrangler models including Rubicon & Unlimited.
This kit is IN STOCK and ready to rock!! At Rockridge4wd, Not only are you getting one bad A** lift, but you're getting superb customer service, knowledgeable assistance to your 4wd questions, QUICK shipping and a GREAT PRICE!!!
Let me hook you up with a smokin hot price on this kit!! Contact me direct!!!
Joel@rockridge4wd.com
Call us! Toll Free: 888-411-8493
Rockridge4WD is offline
post #2 of 4 Old 04-17-2015, 05:50 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
Hey guys! If you're not looking to get too crazy with your JK, but want ALL the advantages available, this is definitely the kit you're looking for!
Don't be led into thinking these long arm suspension systems are built for only hard core wheelers! These kits are designed to give you better handling and control ON road as well! If you have the chance to drive a lifted vehicle with short arms then drive one with long arms, do it! You will feel the huge difference!
This 2.5" system will keep you low to the ground and still give you plenty of upper hand when on the trails! Tall lifts are over rated. This is the way to go!!
Contact me direct and i'll hook you up!!
post #3 of 4 Old 07-18-2015, 02:35 PM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
The advantage and benefit of the TeraFlex JK 2.5" Elite LCG Suspension System for JK Wranglers is apparent the minute you put the pedal to the floor. With superior handling, responsive steering, ultimate off-road performance, and customizable suspension geometry, this system is miles ahead of anything else out there. TeraFlex continues to dominate the off-road market, and the Elite LCG reinforces that position. The Elite LCG Suspension can handle anything you can dish out. The Elite LCG Suspension System is the perfect solution for aggressive trail users looking for the most advanced Long FlexArm system available with a lift height that keeps the center of gravity as low as possible. The Elite LCG features adjustable suspension tuning, and is accomplished through fully adjustable upper and lower long FlexArms that allow pinion, caster, anti-squat, and tire position configurations to be modified.
This kit includes
rear swaybar links,
SpeedBump bumpstops
necessary hardware.
This suspension system is designed to fit up to 35 tires (aftermarket wheels with 4.5 backspacing or less is required). Fits all JK Wrangler models including Rubicon & Unlimited. Note: Cutting & removal of factory bracketry and Welding is required for installation of this kit. Driveshaft modifications are recommended with this suspension system. 2012+ JKs require exhaust spacers (#2610000) or other exhaust modification for proper driveshaft clearance.
If you are looking for an aggresive looking Jeep, that can take on your wheeling adventures with SPEED, then look no further then this kit from Teraflex. Long Arm Suspension, with Speedbumps paired up with some great shocks, will give you the BEST driving experience out there. On road and Off Road!!
Contact Erin@Rockridge4wd.com for you quote! Don't worry, we will take care of you!
CLICK HERE TO VIEW ON OUR SITE!
https://www.youtube.com/watch?v=poz0lpGP0m8
post #4 of 4 Old 09-16-2015, 11:45 AM Thread Starter
Rockridge4WD
Vendor
2010 JK Wrangler
Who wants the HOOK up on the best 2.5" lift on the market?! This is a COMPLETE 2.5" long arm system featuring adjustable suspension tuning, and is accomplished through fully adjustable upper and lower long FlexArms that allow pinion, caster, anti-squat, and tire position configurations to be modified. This kit includes 2.5" lift coil springs, 9550 VSS shock absorbers, weld-on long arm bracketry, long adjustable FlexArms, front adjustable monster trackbar, front swaybar disconnects, rear swaybar links, rear trackbar bracket, bumpstops and all necessary hardware.
You're not going to find a 2.5" lift kit as advanced as this Teraflex LCG system. Teraflex is miles ahead of the competition in innovation and fine tuning.
Not only will this system give the ultimate off road experience, but the onroad comfort and handling will be like nothing you've ever experienced!!
Contact me direct and i'll get you hooked up with a GREAT deal on this system!!
CLICK HERE to read up on this system on our website!
You may not post new threads
