Teraflex JK LCG PRE-RUNNER KIT! ULTIMATE OFF ROAD PERFORMANCE! - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > Teraflex JK LCG PRE-RUNNER KIT! ULTIMATE OFF ROAD PERFORMANCE!
New! JK/U skid plate system.FS: Wrangler RGB Multicolor Fog Light LEDs: Awesome EffectIntroducing MONSTALINER™ UV Permanent DIY Roll On Bed Line
Unread 03-19-2015, 05:51 PM   #1
Rockridge4WD
Vendor
Rockridge4WD's Avatar
2010 JK Wrangler
Here it is guys! The BADDEST lift around!! This is the Teraflex LCG Pre-runner kit designed for the most extreme off road conditions while maintaining a smooth on road ride!
The TeraFlex JK LCG PreRunner Suspension system combines all of our top-of-the-line components into a purpose-built speed system. The PreRunner system is designed to minimize unnecessary rotational mass, and maximize complete wheel travel.
All of these may sound very similar to the already proven Elite LCG suspension system, but the PreRunner specifically focuses on the speed aspect of performance.
The TeraFlex LCG PreRunner Suspension is designed for wide-open baja inspired driving. For maximum performance 35” tires are recommended, with minimal curb weight (less than 4k lbs), and is designed for use with OEM axle housings (to allow maximum up travel).
The TeraFlex JK LCG PreRunner Suspension system features:
• TeraFlex Elite LCG long arm geometry
• SpeedBump bumpstops to provide progressive compression during high speed suspension movement
• HD limiting straps prevent damage to suspension at high speed during dropout
• Extensive gusseting and brackets to beef up critically weak areas and prevent potential damage
• Coil spring retainers prevent the springs from unseating during full suspension extension
For ultimate performance, as engineered, TeraFlex recommends the use of Fox Racing Shocks which have been specifically engineered, designed, and valved to work in conjunction with TeraFlex LCG suspension geometry, and TeraFlex SpeedBump bumpstops. The Fox Racing Shocks are not included with the LCG PreRunner Suspension system, but are available separately!
This kit will transform your JK into a smooth family vehicle during the week and a full off roading machine on the weekend!!
Rockridge4wd takes pride in our customer service and rock bottom pricing! We can get you deep discounts on all teraflex suspension systems and get it shipped to you quickly!
Get in on this crazy teraflex system by contacting me direct at Joel@rockridge4wd.com! I'll get you the best price we can give!!
Jeff@rockridge4wd.com
Call us! Toll Free: 888-411-8493
Rockridge4WD is offline   Reply With Quote Quick reply to this message
Unread 05-05-2015, 05:42 PM   #2
Rockridge4WD
Vendor
2010 JK Wrangler
What's up guys!! I'm doing a LIMITED TIME special on the Teraflex JK prerunner suspension system!
This is one of the best suspension systems your going to find! Complete with teraflex LCG Long flex arms, bump stops and limiting straps! This system will give you ULTIMATE off road handling and a nice smooth on road ride with great stability and control.
Have you ever wanted to open your JK up on a bumpy dirt road and hit 70 over washboards?! This system will do that and then some!!
I can throw in a set of FOX IFP 2.0 shocks with this kit at a great price as well! Contact me direct for a SMOKIN hot price on this one of a kind system!!
DEAL ENDS THIS WEEKEND!!
