TERAFLEX JK bumpers and sliders!! - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > TERAFLEX JK bumpers and sliders!!
FS: Jeep Fog Light LED Bulbs! Several Brightness Options! 97-06 TJ 4-6" long arm upgrade **DEALS AT ROCKRIDGE4WSmittybilt Seat Covers and Tailgate Cover
Unread 08-05-2015, 04:07 PM   #1
Rockridge4WD's Avatar
2010 JK Wrangler
Check this out guys! Have you seen the Teraflex front and rear bumpers and rock sliders for JK?
The Teraflex bumpers have a very nice design and BUILT strong to handle the off road abuse!!
The TeraFlex JK Epic front bumper for the JK Wrangler is designed to offer ultimate rock protection, and match the design styling of the JK’s body. The Epic front bumper is designed with an integrated winch mount. The bumper features recessed mounting, allowing taller winches to take up less grill space to increase radiator air flow for maximum cooling. This bumper will fit centered winches - including the Warn Zeon. A separate bumper is available for standard offset drum winches. A 1.75" mandrel bent tube guard protects the winch, grill and radiator from potential damage. Integrated D-Ring mounts aid with recovery equipment. The Epic bumper also allows the use of the factory fog lights to retain factory styling and technology
The TeraFlex JK Outback rear bumper for the JK Wrangler is designed to offer ultimate rock protection, and continue to match the design styling of the vehicle’s body but still offer the protection needed to allow the 4500+ lb. vehicle to push over rocks and obstacles. The rear bumper features a recessed spare tire well, and can be paired with the TeraFlex HD hinged tire carrier and mount to allow easy access to the rear of the Jeep® (must be ordered separately). Comes in textured black powder coat finish.
TeraFlex JK Rock Sliders are constructed from extruded 6063-T5 aluminum, making them extremely strong and light weight at the same time. They are over 1/4” thick in key strength areas to provide structure and strength. They are easy to install with few modifications to your vehicle (some drilling required). Rubber beading is included to prevent any scuffing between the sliders and the body. These sliders are media blasted, chemically etched, and primed prior to the final UV resistant powder coat finish.
Rockridge4wd can hook you up with some of the best pricing you've seen on these teraflex bumpers and sliders!!
Email me direct for a DEAL!! Joel@rockridge4wd.com
Call us! Toll Free: 888-411-8493
Rockridge4WD is offline   Reply With Quote Quick reply to this message
