TeraFlex JK 2/4 Door 2.5" Lift Kit!! DEALS AT ROCKRIDGE4WD!! - JeepForum.com
Go Back JeepForum.com > Vendor Display > Vendor Display > TeraFlex JK 2/4 Door 2.5" Lift Kit!! DEALS AT ROCKRIDGE4WD!!
Introducing MONSTALINER™ UV Permanent DIY Roll On Bed LineRIGID LED Light Blowout Sale - All Sizes, All Series, all USA Standard Chromoly Front Axle Shaft Kits with Dana 30 4
Unread 04-15-2015, 12:04 PM   #1
Rockridge4WD
Vendor
Rockridge4WD's Avatar
2010 JK Wrangler
What's up guys!! Who's looking for a NICE, simple 2.5" lift for their JK?! I'm ready to hook it up!! HERE IT IS!!
The 2.5” lift kit is an ultra simple lift kit designed for the budget minded no-frills enthusiast! The kit is available in three configurations for your desired performance level. The basic lift includes all of the essential items needed (some form of shock modification will be required- either adapters or new longer shocks). This kit will allow you to run up to a 35” tire (aftermarket wheels with 4.5” backspacing or less are required). Fits all JK Wranglers including Rubicon and Unlimited.
The first configuration of this lift is the box kit with no shocks. This is the ideal configuration for someone looking to upgrade their shocks to a better shock. Such as FOX IFP 2.0 shocks?!
The second configuration is with shock adapters. This will allow you to utilize your factory shocks.
The third configuration comes with all 4 Teraflex 9550 shocks.
I can hook you up with a great deal on this teraflex 2.5" lift! Contact me direct and take advantage!!
Joel@rockridge4wd.com
sales@rockridge4wd.com
Call us! Toll Free: 888-411-8493
Rockridge4WD is offline   Reply With Quote Quick reply to this message
Unread 04-15-2015, 12:05 PM   #2
Rockridge4WD
Vendor
2010 JK Wrangler
Just a heads up!! The 4 door kit is currently on back order! 2 door kit is available!! I will update with the 4 door kit is available unless you want your name on the back order list!
Unread 04-29-2015, 12:11 PM   #3
Rockridge4WD
Vendor
2010 JK Wrangler
Still running some GREAT deals on these Teraflex 2.5" suspension kits! You've got 3 options with this kit!
Kit with no shocks, kit with shock extensions or kit with all 4 teraflex 9550 shocks! Teraflex is still out of stock on the 4dr kit with all 4 shocks, but the rest are good to go!!
This kit will allow you to easily clear 35" tires, and keep your factory ride OR better!! Teraflex coils have a great spring rating and will handle the weight of bumpers and winch very well!
Contact me direct and i'll get you hooked up!
Unread 05-06-2015, 05:02 PM   #4
Rockridge4WD
Vendor
2010 JK Wrangler
Who's looking for a smokin hot deal on this Teraflex 2.5" coil lift?! I'm running a Teraflex special on all lifts through the end of this week! If you've been looking, NOW is the time to buy!
This is a nice system that will improve your on road and off road ride and provide you with enough clearance to easily clear 35" tires. You've got 3 options with this kit. NO shocks if you plan on running an upgraded shock. W/shock extensions if you plan on running your stock shocks. OR W/all 4 teraflex 9550 shocks!
Let me know which set up youre looking for and i will hook you up!
